RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3260 of 3298, by sharangad
FIFA 99 does indeed work with RRedline. You just need to have your regkeys set like this:
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\EA SPORTS\FIFA 99]
"Thrash Driver"="verite"
"Group"="D3D"
"D3D Device"=dword:00000000
"Triple Buffer"=dword:00000000
"Hardware Acceleration"=dword:00000001
"Thrash Resolution"="640x480"
Unfortunately it doesn't work with RReady, I get this:
13:18:38.319 30816 [0] AsyncThread startup thread id 30816
13:18:38.319 30816 [0] Thread started
13:18:38.319 25464 [0] GLContext wglMakeCurrent failed 0x000007D0
13:18:38.320 25464 [0] GLContext wglMakeCurrent failed 0x000007D0
13:18:38.320 25464 [0] Texture generation failed. Null tex is
This means that the pixel format the game chooses for the window can't be made OpenGL compatible. I tried using dgVoodoo's D3D dlls, without much luck. I'm going to try on the Stealth II.
On original hardware, RRedline is implemented on top of D3D, so it should work. Future Cop doesn't seem to work at all with any renderer on Windows 11.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3261 of 3298, by sharangad
It gets stuck at a black screen on original hardware.
I found out why it doesn't work with RReady. It doesn't pass a window handle (HWND) to VL_OpenVerite. So I added support to the routine to work it out and I get a black screen and a crash with this in the log, when detailed debugging is enabled:
15:01:08.730 26920 [0] V_IssueCmdBufferAsync cmdbuffer 0
15:01:08.730 26920 [0] VL_SetScissorX (0, 640) 00000280
15:01:08.730 26920 [0] V_AddToCmdList (Rendition) buffer id 1 requesting 2 slots. Current slot size is 0
15:01:08.730 26920 [0] VL_SetScissorY (0,480) 000001E0
15:01:08.730 26920 [0] V_AddToCmdList (Rendition) buffer id 1 requesting 2 slots. Current slot size is 2
15:01:08.730 26920 [0] VL_FillBuffer
15:01:08.730 26920 [0] VL_SwapDisplaySurface frame 3
15:01:08.730 26920 [0] V_AddToCmdList (Rendition) buffer id 1 requesting 2 slots. Current slot size is 4
15:01:08.734 8740 [0] && SwapBuffers (Exit) Polygons 0
15:01:08.735 26920 [0] VL_WaitForDisplaySwitch
15:01:08.735 26920 [0] V_AddToCmdList (Rendition) buffer id 1 requesting 1 slots. Current slot size is 0
15:01:08.735 26920 [0] V_IssueCmdBufferAsync cmdbuffer 1
15:01:08.735 26920 [0] VL_FillBuffer
15:01:08.735 26920 [0] VL_GetExtensions
15:01:08.735 26920 [0] Extension string V2K_Verite PixFmt_332 Specular PixFmt_4I Display1
15:01:08.735 26920 [0] Caught exception
15:01:08.735 26920 [0] Exception : Unknown source
15:01:08.735 26920 [0] Dumping
15:01:08.735 26920 [0] Calling MiniDumpWriteDump
15:01:09.354 26920 [0] Dump Complete
The exception seems to occur while unlock a mutex (a thread safety structure), after enqueuing a command buffer and it's repeatable. I think this app has been compiled with single threaded libraries or something. Even forcing single threaded affinity doesn't seem to help.
Reply 3262 of 3298, by sharangad
The windscreen in GPL is transparent only at the sides and solid in front with RReady. On original hardware it's fine. That's the flickering car model you saw in Monza and possibly at Silverstone, where the transparent section momentarily turned solid.
Reply 3263 of 3298, by RaVeN-05
Thank you , works good.
What i found after testing games is that DOS more under control and compatibility, when WIN games works faster and requires to play around with other fixes, things, wrappers, etc
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3266 of 3298, by sharangad
GPL windshield problem fixed:
https://nirvtek.com/downloads/RReady.Alpha.20251227.001.7z
MD5: 4e6b367318ab9bbc5aa9cc530c8fa575
It turned out to be a bug in the fragment (pixel) shader in how it handled the alpha colour for vertices with a per-vertex specular colour without a per-vertex alpha colour.
https://youtube.com/shorts/RIyJO-LNYbE?feature=share
https://www.patreon.com/posts/gpl-windshield- … ntent=join_link
Reply 3267 of 3298, by filipetolhuizen
sharangad wrote on 2025-12-26, 04:21:
RaVeN-05 wrote on 2025-12-25, 21:18:
Interstate '76: Nitro Pack have redline renderer zredline.dll, but can't activate it, will try on original hardware, i have access
It does work, it needs the -rredline switch (same as i76l, I think.
On windows you need the dgvoodoo D3D dlls and dxwnd. The help file for rready (click help) has a download link for a pre-configured build (other than the exes path).
Alternatively you can run Splash.exe in which you can choose your hardware directly from the launch menu.
-OT-
Tip: If you can get your hands on the Splash.exe from the old D3D patches before Gold Edition, it's worth the effort. Of course it'll only give Direct3D option for hardware acceleration but somehow it'll have much better graphics than the D3D from the new launcher. Also, replace the zglide.dll on Gold Edition folder with the one from Nitro Riders. It'll fix garbled graphics on glide mode with wrappers and Voodoo2.
Reply 3268 of 3298, by sharangad
filipetolhuizen wrote on 2025-12-27, 14:54:
Alternatively you can run Splash.exe in which you can choose your hardware directly from the launch menu. -OT- Tip: If you can g […]
-OT-
@filipetolhuize I didn't know there were different D3D modes.
I think Raven-05 is attempting to test the Rendition Redline mode support with nitro and i76. It used to work with just Dxwnd, but after a Win11 24H2 needs both Dxwnd and the DirectDraw and Direct3D wrappers from dgvoodoo to run.
I don't know what graphical differences exist between the D3D and RRedline renderers. Splash won't offer RRedlne unless the it and the game is set to run in Win98 compatibility.
Reply 3269 of 3298, by filipetolhuizen
sharangad wrote on 2025-12-27, 17:01:
@filipetolhuize I didn't know there were different D3D modes. […]
-OT-
I know this is about running on Redline, that's why I made an OT (off-topic) before mentioning D3D and Voodoo. For me, Splash.exe is offering every hardware option, but I76 requires a memory lie shim. I just tested the Rendition mode and it's running really well. However, I noticed inconsistent framerates using the latest build on every game I tried.
EDIT: Splash on Nitro Riders doesn't show hardware options, but Gold Edition does.
Reply 3270 of 3298, by sharangad
filipetolhuizen wrote on 2025-12-28, 22:32:
-OT-
I'll give that a go.
Ah ok. I think I know why the framerate is off. I'll post an updated build today which should fix it.
Reply 3271 of 3298, by sharangad
Filipe, could you try this and see if the framerate is steady now:
https://nirvtek.com/downloads/RReady.Alpha.20251229.001.7z
MD5: f04e465c8754ca20b2e21b3780a4ca4c
I tried to lower the CPU usage of the wrapper by using windows events to wake up timing critical threads, but it wasn't reliable, leading to random slowdowns and freezes. Now it should be back to busy waiting (running in a loop until stuff's available, eating up CPU cycles but very fast and responsive).
Reply 3272 of 3298, by filipetolhuizen
sharangad wrote on 2025-12-29, 04:16:
Filipe, could you try this and see if the framerate is steady now: […]
Tried with same games but seemed equal from the previous build. It's very noticeable on SODA. The intro demo doesn't run smooth as it used to and menus take more time to load. Latest build to run smoothly was from 02/12/2025.
Reply 3273 of 3298, by sharangad
filipetolhuizen wrote on 2025-12-30, 02:24:
OK, thanks for letting me know. It's not the changes I thought were responsible. I'll trawl through all the changes. It should be fixable.
But it does work with versions older than December 2nd right?
Reply 3274 of 3298, by sharangad
OK try this:
https://nirvtek.com/downloads/RReady.Alpha.20251230.001.7z
MD5: 4fff10da29382b663d1ad74a095c2c64
The only thing I found was a Sleep(0) which in the virtual Rendition command processor causes the render thread to idle and allow other threads to run. On older CPUs I guess this didn't hurt performance, but I think you have a much faster and newer CPU. I'm very confident that this will fix things.
This also highlights the fact that optimization depends on the performance of each generation of CPU used and I'll have to gate these things with an older CPU toggle in Rendition settings OR a different build of the wrapper for older generations.
Reply 3275 of 3298, by filipetolhuizen
sharangad wrote on 2025-12-30, 06:42:
OK try this: https://nirvtek.com/downloads/RReady.Alpha.20251230.001.7z MD5: 4fff10da29382b663d1ad74a095c2c64 […]
OK try this:
FPS are steady and smooth again with this build. Thanks again!
Reply 3276 of 3298, by sharangad
filipetolhuizen wrote on 2025-12-31, 03:31:
OK try this:
That's a relief! Thanks for confirming that.
Reply 3278 of 3298, by Makus
Hi sharangad, happy 2026 to you too!
And thank you for your very valuable work.
