Reply 80 of 244, by FullYes
RetroPCCupboard wrote on 2026-01-03, 09:58:It isn't the latest version. Just what was already on the machine. It is from April 2024. I could download the latest and rerun the tests.
That would be interesting if you are willing to do it. I had a look and cannot download the old version from his website to do the check myself
Installed the k6-2 400 today. Unfortunately it did not go smoothly. It bootloops after the initial memory count. I had a search and found out this could be related to “usb keyboard support”. This is disabled by default so I just needed to do a cmos reset. It still boot looped so I tried removing 1 stick of the 2 x 32Mb SDRAM that is in there and it then, as if by magic, booted fine.
I’m still investigating what’s going on. But in the meantime here are some updated results with just 32MB installed comparing to all of the tests with the Pentium with 64MB
66x3.5, 75x3.5, 83x3, 83x3.5 66x6
233, 262.5, 250, 291.6, 400
Quake 320x200
53.5, 59.9, 61.7, 66.5, 63.6
Doom, max settings
84.68, 94.19, 98.15, 103.59, 89.02fps
882, 793, 761, 721, 839 realticks
Chris’s 3d benchmark (320x200)
165.5, 185.8, 189.8, 206.3, 220.4 fps
275.8, 309.7, 316.4, 343.8, 367.3 (score)
PCplayer 320x200
59.5, 66.8, 68.0, 74.2, 95.0
Speedsys
L1: 425.89, 478.13, 460.29, 530.71, 1835 MB/s
L2: 185.05, 207.75, 230.81, 230.81, 202.83 MB/s
Memory: 130.04, 146.30, 162.62, 162.53, 112.92 MB/s
Processor benchmark score, 176.77, 198.42, 188.92, 220.40, 458.59
I’ll need to make a table or something as there’s a bit too much here now to digest.
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
