K6INIT: AMD K6-3/3+/2(CXT) initialization driver for MS-DOS
Reply 100 of 108, by Oerg866
I cannot recommend anything because I'm not aware of any special functions that these CPUs have, but I may be wrong?
Reply 102 of 108, by eliot_new
Wow, thank you!!!
Question: can K6INIT also help to speed up a K6-3 / 400 on Win98SE?
Currently I am experimenting with K6-3/400, V1 and Q2.
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 103 of 108, by Disruptor
Sure. You may include it in your autoexec.bat
Reply 104 of 108, by Oerg866
Hi.
Here's a test version that enables basic functionality on pre-CXT K6-2 and K6 CPUs . Let me know if it works for you, so I can make an official release.
The _D executable is a debug version.
Reply 105 of 108, by Disruptor
Oerg866 wrote on 2026-01-10, 17:52:
Hi.
Thank you, Eric.
I just tested it.
It changes text colour to green when output is redirected to a text file with ">"
K6-2 (non-CXT) hangs
K6 does not hang (oops, red MTRR < Not supported by CPU > not seen on picture due to blinking)
Reply 106 of 108, by Oerg866
Ah. I see the problem. There is a distinction in models for the K6-2 where early ones also follow the K6 layout for the WHCR register. I will post a patch soon.
Reply 107 of 108, by Oerg866
Disruptor wrote on 2026-01-15, 11:07:
Thank you, Eric. […]
Hi.
Thank you, Eric.
I just tested it.
Hello, please find here v1.4b which hopefully fixes this freezing issue:
<outdated>
EDIT: Hang on, the freezing issue seems to be unrelated. Stand by
EDIT2: Please test the attached version again
Reply 108 of 108, by cucgod
wow thanks for this tool!
this makes the k6 get a nice speedboost for me.
currently testing a k6-3+ 400 in a commwell s7ax board and i see a great increase in benchmark scores..
stock:
q1 12.3fps
3dmark2000 1165
/auto
q1 21.2fps
3dmark2000 1205
/auto /chipset
q1 28.2fps
3dmark2000 1513
