Reply 100 of 107, by Oerg866
I cannot recommend anything because I'm not aware of any special functions that these CPUs have, but I may be wrong?
Oerg866 wrote on 2026-01-09, 11:49:I cannot recommend anything because I'm not aware of any special functions that these CPUs have, but I may be wrong?
https://www.heise.de/ct/ftp/98/19/224/
(in German)
You may need to change the ftp:// in the link to https://
Wow, thank you!!!
Question: can K6INIT also help to speed up a K6-3 / 400 on Win98SE?
Currently I am experimenting with K6-3/400, V1 and Q2.
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Sure. You may include it in your autoexec.bat
Hi.
Here's a test version that enables basic functionality on pre-CXT K6-2 and K6 CPUs . Let me know if it works for you, so I can make an official release.
The _D executable is a debug version.
Oerg866 wrote on 2026-01-10, 17:52:Hi.
Thank you, Eric.
I just tested it.
It changes text colour to green when output is redirected to a text file with ">"
K6-2 (non-CXT) hangs
K6 does not hang (oops, red MTRR < Not supported by CPU > not seen on picture due to blinking)
Ah. I see the problem. There is a distinction in models for the K6-2 where early ones also follow the K6 layout for the WHCR register. I will post a patch soon.
Disruptor wrote on 2026-01-15, 11:07:Thank you, Eric. […]
Thank you, Eric.
I just tested it.
Hello, please find here v1.4b which hopefully fixes this freezing issue:
<outdated>
EDIT: Hang on, the freezing issue seems to be unrelated. Stand by
EDIT2: Please test the attached version again
