Linux distros to consider?
First post, by BEEN_Nath_58
Choosing a Linux distro has been difficult for me, specifically shifting from Linux Mint for a change. I moved to Debian 13, only to see that many apps I use don't have the packages installed and I get to a loop to install them.
Obviously I imagine everyone would like to save their time choosing one that's tailored for their purpose.
I am looking for one that's sufficient for a personal user. Cherry on top, stable and a lot of available packages. Also how would I choose a fork of the major OS?
Reply 1 of 21, by The Serpent Rider
CachyOS, Mint LDME, Nobara, Bazzite. Based on Arch, Debian, Fedora, Fedora. If you want stable, just scratch Arch from that list.
Reply 2 of 21, by BEEN_Nath_58
The Serpent Rider wrote on 2026-01-10, 21:16:
Why has Bazzite seen a higher "promotion" lately compared to, say, elementaryOS or Gentoo or even CentOS Stream
Reply 3 of 21, by Joseph_Joestar
BEEN_Nath_58 wrote on 2026-01-10, 21:30:
It's a gaming focused distro.
For people who want to play games without too much hassle, Bazzite is the one to go for.
Reply 4 of 21, by Matth79
Until a realistic general release of SteamOS, Bazzite is probably the best way to get Steam (and some other launchers, Lutris etc) up and running with minimal fuss.
Reply 5 of 21, by jheronimus
Honestly, Flatpak mostly solves this problem. So I just use Debian + flatpak
I was in a similar boat, and I'd say the biggest selection of software would be ArchLinux's AUR. The downside is that while ArchLinux itself has been pretty solid in my experience, AUR packages do break routinely after updates.
MR BIOS catalog
Unicore catalog
Reply 6 of 21, by lti
I haven't used Bazzite, but a lot of the modern PC community is focused on gaming (to the point of being obnoxious). I haven't heard anyone talk about Gentoo in a long time, and I thought CentOS was more of a commercial server-focused distro.
I think there are two definitions of stability. There's the Debian "use old versions of packages with security patches only" definition, and there's the "doesn't crash" definition. At this point, I'm not too sure that desktop Linux is "doesn't crash" stable anymore, but it was in the past.
The Arch AUR and Ubuntu PPAs are probably the largest collections of weird third-party stuff (including drivers - for example, Hauppauge releases their drivers as PPAs, and then they get unofficially ported to the AUR). If you don't need third-party drivers like that, Flatpak and AppImages are good for software and not distro-specific.
Reply 7 of 21, by lawyerpepper
PopOS gets high marks from users, especially the new Cosmic desktop. Personally, I’m fine with Debian, but I’ve been using Linux on and off since the 90s.
Reply 8 of 21, by BEEN_Nath_58
Yeah PopOS, that's another that rings the gaming name.
Another one I hear a lot is Zorin OS for the fact it looks a lot like Win, but I don't know it's other aspects
Reply 9 of 21, by wierd_w
I use xubuntu on my big pc, but use bazzite on my gpdwin4.
Bazzite's immutable FS is a pita, imo. I only use it on my win4 because steamos isnt an option. I have to run a script to reconfigure zram swap, because the maintainer does not reference a user writable conf for that. (Grumble)
Reply 10 of 21, by Robin4
Iam using Cachyos my self on my living room computer.
Tried Bazzite, but was to closed to me with using the terminal. Maybe great for gaming only. Not for gaming + desktop use.
Reply 11 of 21, by BitWrangler
For pre-2010 machines, look at "Puppy".
Reply 12 of 21, by DracoNihil
I've been using Void Linux for the past 6 years now without a problem. It's a rolling release distro with it's own package manager and uses "runit" for the init process.
They have a policy of only packaging stable, non breaking (as in try to avoid ABI incompatibility and SONAME bumps) releases though if a major library has a breaking change then all packages depending on it are updated and in case of breakage, patches written to resolve the break if possible.
The base system install is very barebones like Arch, so if you're used to that kind of initial setup hurdle there's nothing really wrong with the distro. The package system is described here and is comparable to BSD "ports system".
I actually run my system with several locally custom built packages without problems. Manual intervention obviously needed in the event of SONAME changes but nothing impossible to fix.
― Κυνικός Δράκων
Reply 13 of 21, by BEEN_Nath_58
I guess I should step on the Arch train this time
Reply 14 of 21, by jtchip
BEEN_Nath_58 wrote on 2026-01-10, 21:05:
"Stable" in the context of Linux distributions means stable API (in case you're not already aware). Debian is one such example, the APIs of libraries and the kernel are held stable for the life of that version, and often that means the applications as well. Ubuntu LTS, and its downstream Linux Mint, is another example though they make exceptions for the desktop version where HWE (hardware enablement) allows the kernel and Mesa to update roughly every 6 months (shortly after the next non-LTS version of Ubuntu). RHEL (and its upstream CentOS Stream) is yet another example though in this case it has a franken-kernel where the version number is the same but subsystems are backported from newer kernels (those that matter to paying enterprise customers); also desktop-related components like Mesa, GNOME, and some desktop applications are updated every 6 months.
BEEN_Nath_58 wrote on 2026-01-11, 18:58:
Arch is almost at the other end of "stable" where basically it's not, everything and anything is more or less upgraded as upstream updates and there are no fixed releases for the distribution.
Somewhere in between are those that are updated every 6 months like non-LTS Ubuntu and Fedora.
I suggest making a list of which of the "lots of available packages" you need and see which distribution(s) have them (and how often they're updated).
BitWrangler wrote on 2026-01-11, 03:48:
I'd set that date quite a bit further back, I still run Fedora KDE on a 2008 AM2+-based system (Athlon 64 X2, 4GB RAM, 780G iGPU) which was my previously daily desktop; I basically just kept updating the installation it's had on it. Recently I installed Fedora 43 LXQt on a similar vintage ThinkPad T400 (Core 2 Duo P8600, 3GB RAM, GMA X4500MHD iGPU, 160GB HDD), takes about a minute to boot (vs. XP which boots in half the time) but is pretty usable after that, if a little sluggish compared to much newer machines.
Reply 15 of 21, by BEEN_Nath_58
jtchip wrote:
Arch is almost at the other end of "stable" where basically it's not, everything and anything is more or less upgraded as upstre […]
That's true, I contradicted my own statement. Since I can't settle on something Debian based. I decided to choose Arch since it's getting rolled in for gaming OSes, and it gives the feeling that things will be rolled in fast, and more often than not, stable. How far that belief goes, I don't know.
I am still open to choose something that suits me better, and I might prefer something mutable (still) yet knowing things can break. I wish to learn things on the way.
Talking of repositories, I don't know where to find them correctly. I needed a 32bit library, which I couldn't find for Debian but it existed for Arch although 2yrs old
Reply 17 of 21, by BEEN_Nath_58
jtchip wrote on 2026-01-12, 03:01:
BEEN_Nath_58 wrote on 2026-01-12, 02:46:
https://repology.org/ and https://pkgs.org/ are 2 such sites with lists of packages by distribution.
For instance, I am looking for a 32-bit version of alsa oss. In Ubuntu, I couldn't get one with apt and in the 2 sites, I managed to find alsa for both Arch and Ubuntu. However, I can't seem to find in Repology if the binary is 32-bit supported (i386,i586,i686..) or only amd64. However in pkgs I found a "lib32-alsa-oss-1.1.8-5-x86_64.pkg.tar.zst" for Arch Linux Multilib, which might be the file I need?
I am quite new to this, so a reassurance would help
Reply 18 of 21, by wierd_w
If it's a very old package, then you can probably get it in an older release.
Debian has a package searcher on their homepage.
https://www.debian.org/distrib/packages
Looks like you want osspd-alsa i386?
(OSS proxy daemon over ALSA. Gives an OSS interface with 'newer' ALSA backend. Apparently also supports PulseAudio backend.)
https://packages.debian.org/search?suite=all& … ords=osspd-alsa
Manual installation with dpkg is possible, but caveat emptor.
Reply 19 of 21, by BEEN_Nath_58
wierd_w wrote on 2026-01-13, 18:36:
If it's a very old package, then you can probably get it in an older release. […]
The application I was trying to run was looking for libaoss.so. The tar file I linked has 1 so file so I am assuming that's the correct one.
I don't think it's osspd, and still I don't know what this libaoss is other than that it relates to audio
