BEEN_Nath_58 wrote on 2026-01-10, 21:05:
I am looking for one that's sufficient for a personal user. Cherry on top, stable and a lot of available packages.
"Stable" in the context of Linux distributions means stable API (in case you're not already aware). Debian is one such example, the APIs of libraries and the kernel are held stable for the life of that version, and often that means the applications as well. Ubuntu LTS, and its downstream Linux Mint, is another example though they make exceptions for the desktop version where HWE (hardware enablement) allows the kernel and Mesa to update roughly every 6 months (shortly after the next non-LTS version of Ubuntu). RHEL (and its upstream CentOS Stream) is yet another example though in this case it has a franken-kernel where the version number is the same but subsystems are backported from newer kernels (those that matter to paying enterprise customers); also desktop-related components like Mesa, GNOME, and some desktop applications are updated every 6 months.
BEEN_Nath_58 wrote on 2026-01-11, 18:58:
I guess I should step on the Arch train this time
Arch is almost at the other end of "stable" where basically it's not, everything and anything is more or less upgraded as upstream updates and there are no fixed releases for the distribution.
Somewhere in between are those that are updated every 6 months like non-LTS Ubuntu and Fedora.
I suggest making a list of which of the "lots of available packages" you need and see which distribution(s) have them (and how often they're updated).
BitWrangler wrote on 2026-01-11, 03:48:
For pre-2010 machines, look at "Puppy".
I'd set that date quite a bit further back, I still run Fedora KDE on a 2008 AM2+-based system (Athlon 64 X2, 4GB RAM, 780G iGPU) which was my previously daily desktop; I basically just kept updating the installation it's had on it. Recently I installed Fedora 43 LXQt on a similar vintage ThinkPad T400 (Core 2 Duo P8600, 3GB RAM, GMA X4500MHD iGPU, 160GB HDD), takes about a minute to boot (vs. XP which boots in half the time) but is pretty usable after that, if a little sluggish compared to much newer machines.
