First post, by bionicsa
Hello everyone!
I've finally got my hands on a Libretto 70CT after owning one about 20 years ago, selling it, then wanting another one ever since!
When pressing the power button, it turns on, the hard drive spins but the screen is black
Pressing the power button holding F12, the unit turn on a the screen very dimly shows a message about updating the BIOS.
I've taken the 1.6GB hard drive out and connected it to my main PC via an IDE to USB converter, and it works perfectly, i can see all the files on it.
I've partitioned an old 40GB IDE hard drive so its got a single 2GB partition on it, popped this in the Libretto, and there's no change to the behavior I've written above.
Upon opening the unit up, i could see that the backup battery has spread some corrosion onto the motherboard, see image 1.jpg.
I cleaned it up with some alcohol and vinegar, and it looks much better, see image 2.jpg.
My main concern it with the parts circled in image 3.jpg.
I have purchased an SD to IDE adapter, formatted a 4GB SD card in FAT with a 2048kb allocation unit. When i put this in the Libretto and turn it on, the HDD light stays on, and the same behavior occurs as i mentioned above, see image 4.jpg.
I do have a CF to IDE adapter on order, along with a 4GB Transcend Industrial CF card.
Anyone experienced anything like this before, and secondly, does anyone have any ideas on what to do next?
Reply 1 of 4, by bionicsa
Anyone got any help they would like to offer?
Reply 2 of 4, by dukeofurl
Do you have the docking station with a VGA out? I'd use that to at least finish configuring the machine and ensure everything else but the screen is working. No specific thoughts, but high level in addition to checking the board where it was damaged by the battery, I'd check any ribbon cable that is used with the screen, those often fail on 30+ year old small devices. Is there a backlight? Maybe you can rig something else up to illuminate it... Maybe there are issues with the screen itself... sadly I don't think there is a modern replacement screen or guide for hacking something else into a libretto yet.
Reply 3 of 4, by bionicsa
Ive now fitted a replacement backup battery and im getting 2.5v across it.
@dukeorearl, the screen itself it fine, it shows a message when powering on the unit pressing F12 'Ready for BIOS update, insert diskette'
I now have my 2GB Transcend Industrial and adapter, im hoping a user on here send me a clone image for it, from this thread Toshiba Libretto 50ct blank screen on boot
Reply 4 of 4, by bionicsa
I've tried using another HDD with the above image but no change, still black screen on boot, and message about updating BIOS on power+f12.
I have put the original HDD onto my normal PC, and it spins up and is accessible, so doesn't look like a hdd issue.
Next things to try are: getting some floppies, loading the BIOS update and attempt to update bios when it asks. Floppies are en route from ebay.
Try a different power supply. I did read sometimes the PSU doesn't give the correct power and a new PSU solved the issue. PSU en route from Amazon.
