Reply 30760 of 30765, by TechieDude
So, today I had to downgrade my overkill Win9x PC from a GeForce 4 Ti 4600 128MB to GeForce 4 MX440 128MB DDR, due to some weird artifacts. At least it is AGP 8x and still has 128MB DDR, but it remains a rebranded GF2 DX7 GPU. I'm not sure the GPU is really dead, though. It seems like an actual BGA problem, because squeezing the cooler affects the artifacts, but I don't know for sure either way. It's not like I have a BGA rework station either, so...
The lower end GPU still runs the games fine, so it's not that bad. I also noticed that GeForce 3 and 4 GPUs are kinda hard to find around here, while pretty much anything else (except 3dfx of course) is fairly common.
Might as well share the full specs of my system:
Spoiler
  • Board: ASRock775i65G R3.0
  • CPU: Intel Pentium Dual-Core E5800 3.2GHz
  • RAM: 2GB (2x1GB DDR400)
  • GPU: GeForce 4 MX440 8x 128MB DDR
  • HDD1: WD400JB-00ENA0 40GB IDE
  • HDD2: WD800JB-00JJC0 80GB IDE
  • OS 1: Windows ME (+ Unofficial Service Pack, PATCHMEM)
  • OS 2: Windows XP Pro SP3 (+ POSReady2009 Updates)
  • OS 3: Devuan 6 32-bit (broken mess, might reinstall, GRUB makes multiboot easy)
The only issue I really have with the system is that it takes a bit to POST, but one it does, it works fine.
Reply 30761 of 30765, by nali
Indrid_Cold_ wrote on Yesterday, 15:34:
Ultima VI italian translation completed
Nice !
I don't speak Italian, French so it's not for me, but for sure it will help for those who have problem with English.
Reply 30762 of 30765, by Indrid_Cold_
nali wrote on Yesterday, 19:10:
Nice !
If you'd like, I've saved every single text file pertaining to every specific character in the game—223 of them (some, at least ten, are blank and without any lines of dialogue)—if you'd like to try translating them or take a look (but be careful about the parts that absolutely shouldn't be translated, the lengths, the variables, etc.)—I think it might make translating them into different languages ​​easier. The U6Edit tool was a great help with this.
oLcUsdAvOQ
dKjMkCxaHA
jQm-leYqUg
UQwXrLz52A
Reply 30763 of 30765, by PC@LIVE
For this time I don't deal with motherboards, but with problems related to some PCI sound cards, I have three of the same model, two are branded CREATIVE LABS MODEL:CT4810, the other only CT4810, I think they are basically the same board, but there are some differences, I take care of the two CREATIVE LABS branded cards for the moment, they look like twins but near the microphone jacks (pink), the C20 in one is electrolytic, in the other it is an SMD.
The main problem with these cards is that when it is inserted into the PCI slot, the PC does not start, that is, it does not start at all!
It looks like a short problem, and the power supply intervenes preventing it from starting, if we remove the sound board, the PC works without any problem!
First of all I checked if between the PINs of the comb (PCI), there was a problem between the ground PINs and those of the voltages (3.3V 5V 12V, and -12V), there is no -5V, but I think it is only used by ISA slots, however no short (surprise!), I thought I saw the continuity in a PIN!
In short, a little surprised (but not too much), I concentrate looking among the electrolytic capacitors, the values of some are a bit strange, but having been tested on board, it is possible that these values are influenced by other components on the circuit.
I start looking everywhere, apart from the 24.576 quartz, which I can't verify, I try the rest with the tester on diode test, I start to check everything I see except the resistors, because these allow a current passage, so even if in short they can't prevent the PC from starting, the capacitors instead, often connect to ground, so if it's short, it would explain why the PC doesn't start.
By now, I had tried to control practically everything, in reality I had left out a part that I thought could not be important, however today I tried to see if the inside of the jacks had a problem, and even there everything was normal, so now short of ideas, I try to check some SMD next to the microphone jack and LINE-IN, to make it short (!), I find three short SMD capacitors, it's C1 C2 and C3.
Today I won't be able to finish the job, because all three defective capacitors will have to be removed, from both boards, and then they will have to be replaced with others, unfortunately I don't know the original values, the C3 looks brown, while C1 and C2 are purple-gray, in short, I'll see if I can find other capacitors the same, on scrap motherboards.
It remains to be seen if replacing these SMDs will solve this startup problem, I guess so, but before welding the spare ones, I would also check the resistors next to it, in short, it seems that the resolution of the fault is possible, if I succeed I will have recovered a couple of PCI sound cards, the third card instead, I should examine it better, but I anticipate that the three SMD capacitors work, and so I have to look for another problem, I think I will have to start checking everything all over again.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 30764 of 30765, by RetroGear1
Just wrapped up completing a 2004-2009 setup with a P4 Cedar Mill 651 @3.4 on a micro ATX Gigabyte GA-g41m mobo with 2 sticks of 1g ram from OCZ ddr2 800 and a velociraptor 160gb hdd. An ATI X800XL takes care of the graphics. Also a Plextor dvd drive. Still waiting on a 1.44 mb floppy drive to arrive to complete the build.
Using an Antec mid tower and a Dell 2007wfp 20 inch monitor. My old psu didn't work so picked a relatively cheap psu from Azza 550w.
It's been a lot of fun getting back to the retro stuff.
Reply 30765 of 30765, by RetroGear1
Coudnt upload the pic, possibly due to not enough postings?
