Reply 30760 of 30772, by TechieDude
So, today I had to downgrade my overkill Win9x PC from a GeForce 4 Ti 4600 128MB to GeForce 4 MX440 128MB DDR, due to some weird artifacts. At least it is AGP 8x and still has 128MB DDR, but it remains a rebranded GF2 DX7 GPU. I'm not sure the GPU is really dead, though. It seems like an actual BGA problem, because squeezing the cooler affects the artifacts, but I don't know for sure either way. It's not like I have a BGA rework station either, so...
The lower end GPU still runs the games fine, so it's not that bad. I also noticed that GeForce 3 and 4 GPUs are kinda hard to find around here, while pretty much anything else (except 3dfx of course) is fairly common.
Might as well share the full specs of my system:
Spoiler
  • Board: ASRock775i65G R3.0
  • CPU: Intel Pentium Dual-Core E5800 3.2GHz
  • RAM: 2GB (2x1GB DDR400)
  • GPU: GeForce 4 MX440 8x 128MB DDR
  • HDD1: WD400JB-00ENA0 40GB IDE
  • HDD2: WD800JB-00JJC0 80GB IDE
  • OS 1: Windows ME (+ Unofficial Service Pack, PATCHMEM)
  • OS 2: Windows XP Pro SP3 (+ POSReady2009 Updates)
  • OS 3: Devuan 6 32-bit (broken mess, might reinstall, GRUB makes multiboot easy)
The only issue I really have with the system is that it takes a bit to POST, but one it does, it works fine.
Reply 30761 of 30772, by nali
Indrid_Cold_ wrote on 2026-02-08, 15:34:
Ultima VI italian translation completed
Nice !
I don't speak Italian, French so it's not for me, but for sure it will help for those who have problem with English.
Reply 30762 of 30772, by Indrid_Cold_
nali wrote on 2026-02-08, 19:10:
Nice !
If you'd like, I've saved every single text file pertaining to every specific character in the game—223 of them (some, at least ten, are blank and without any lines of dialogue)—if you'd like to try translating them or take a look (but be careful about the parts that absolutely shouldn't be translated, the lengths, the variables, etc.)—I think it might make translating them into different languages ​​easier. The U6Edit tool was a great help with this.
oLcUsdAvOQ
dKjMkCxaHA
jQm-leYqUg
UQwXrLz52A
Reply 30763 of 30772, by PC@LIVE
For this time I don't deal with motherboards, but with problems related to some PCI sound cards, I have three of the same model, two are branded CREATIVE LABS MODEL:CT4810, the other only CT4810, I think they are basically the same board, but there are some differences, I take care of the two CREATIVE LABS branded cards for the moment, they look like twins but near the microphone jacks (pink), the C20 in one is electrolytic, in the other it is an SMD.
The main problem with these cards is that when it is inserted into the PCI slot, the PC does not start, that is, it does not start at all!
It looks like a short problem, and the power supply intervenes preventing it from starting, if we remove the sound board, the PC works without any problem!
First of all I checked if between the PINs of the comb (PCI), there was a problem between the ground PINs and those of the voltages (3.3V 5V 12V, and -12V), there is no -5V, but I think it is only used by ISA slots, however no short (surprise!), I thought I saw the continuity in a PIN!
In short, a little surprised (but not too much), I concentrate looking among the electrolytic capacitors, the values of some are a bit strange, but having been tested on board, it is possible that these values are influenced by other components on the circuit.
I start looking everywhere, apart from the 24.576 quartz, which I can't verify, I try the rest with the tester on diode test, I start to check everything I see except the resistors, because these allow a current passage, so even if in short they can't prevent the PC from starting, the capacitors instead, often connect to ground, so if it's short, it would explain why the PC doesn't start.
By now, I had tried to control practically everything, in reality I had left out a part that I thought could not be important, however today I tried to see if the inside of the jacks had a problem, and even there everything was normal, so now short of ideas, I try to check some SMD next to the microphone jack and LINE-IN, to make it short (!), I find three short SMD capacitors, it's C1 C2 and C3.
Today I won't be able to finish the job, because all three defective capacitors will have to be removed, from both boards, and then they will have to be replaced with others, unfortunately I don't know the original values, the C3 looks brown, while C1 and C2 are purple-gray, in short, I'll see if I can find other capacitors the same, on scrap motherboards.
It remains to be seen if replacing these SMDs will solve this startup problem, I guess so, but before welding the spare ones, I would also check the resistors next to it, in short, it seems that the resolution of the fault is possible, if I succeed I will have recovered a couple of PCI sound cards, the third card instead, I should examine it better, but I anticipate that the three SMD capacitors work, and so I have to look for another problem, I think I will have to start checking everything all over again.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 30764 of 30772, by RetroGear1
Just wrapped up completing a 2004-2009 setup with a P4 Cedar Mill 651 @3.4 on a micro ATX Gigabyte GA-g41m mobo with 2 sticks of 1g ram from OCZ ddr2 800 and a velociraptor 160gb hdd. An ATI X800XL takes care of the graphics. Also a Plextor dvd drive. Still waiting on a 1.44 mb floppy drive to arrive to complete the build.
Using an Antec mid tower and a Dell 2007wfp 20 inch monitor. My old psu didn't work so picked a relatively cheap psu from Azza 550w.
It's been a lot of fun getting back to the retro stuff.
Reply 30765 of 30772, by RetroGear1
Coudnt upload the pic, possibly due to not enough postings?
Reply 30766 of 30772, by bjwil1991
Within the last week or so, I've been working on restoring/repairing/modifying my Game Boy collection: 2 GBP, 1 GBL, and 1 GBC. The GBL had its display and EL replaced, the buttons/membranes replaced with GITD ones, the power switch has been repaired, the corrosion has been removed, the shell has been replaced with a shitty one (gotta get an OEM one and repaint it to make it look like new), but it looks okay (damn standoffs snapped like my back), the power LED has been replaced with a green LED, new negative battery terminal installed, new contrast wheel installed, new DC jack installed, new headphone jack installed, and new speaker (GITD) installed.
GITD is glow in the dark for those who are wondering what that means.
The GBPs had the shells swapped, new IPS displays, rechargeable USB-C batteries, new contrast/brightness wheels installed, and the one GBP had the power LED mod installed, but I had to fix it up so it'll look better, plus the power switch had the internal part taken out for the GBL since the original internal part for that switch quit working on me, so that GBP will be getting a new switch installed.
The GBC has a new shell, new buttons, laminated OLED touchscreen (for OSD) display, new speaker, new membranes, new IR cover, new switch for the shell, and kept the battery setup I've had for about a couple of years (charges via the DC jack).
My plan is to get another GBL to restore, get an OEM shell for the other one, get new stickers made for both consoles, and spruce them up to make them look factory original. That and a GBA SP that needs one specific part to make it work, but that's another story in of itself (I got one that was water damaged and didn't think about it after the fact that it needs $200 worth of parts to make it work and ended up scrapping it).
Reply 30767 of 30772, by Private_Ops
RetroGear1 wrote on 2026-02-08, 21:06:
Nice. I put together a Core 2 E6550, 2GBs DDR2, and an X800XL. I look at it as if someone grabbed some cheap parts off ebay in the late core 2 era.
I tired my Pentium 4 660 in it first before switching to the E6550. The difference in Dawn of War (the 1st one) was astonishing. Uses an Asus board with the late revision 945GC chipset that unofficially runs at 1333FSB.
Reply 30768 of 30772, by PTherapist
Had to replace a Dallas chip in 1 of my PCs due to a dead battery, luckily it was socketed. I bought a couple of new old stock Dallas chips about 9 years ago, which this chip was 1 of, so it did pretty well lasting for 9 years.
I put the 2nd unused chip in and the PC is all working great again. I doubt it will last another 9 years, but I'll probably replace it with a modern CR2032 modification when it finally dies.
This particular Socket 5 PC exhibited bizarre behaviour with a dead battery - as well as not saving any BIOS settings, it was also giving me a CPU clock speed of 150MHz instead of 166 and only half the installed RAM was showing as available. I booted into Windows 95 and performance was absolutely dreadful. It's crazy how so much of the system's operation is reliant upon a single replaceable chip!
Reply 30769 of 30772, by Ozzuneoj
After finally fixing the PS/2 keyboard and mouse issues on this board after 8 years, I decided to test another board that I had just recently replaced some caps on. It is an Abit IS7-E, which is a fantastic Intel 865PE board. To my astonishment (and disgust, honestly) the PS/2 ports wouldn't work on this board either. It was totally dead... no lights on the keyboard or PS/2 mouse.
Long story short, this board has a jumper in the top right corner that either enables or disables power to the USB ports when the system is off. With it enabled and with the BIOS set properly, you are able to power on the system with the mouse or keyboard. On my board, these pins were bent up and and had no jumper on them. Big surprise, when I put a jumper on it, everything is fine! So, for the PS/2 ports to receive power at all, the jumper needs to be in the "disabled" position (1-2) at least, or in the "enabled" position (2-3) if you want the ports to also be powered when the system is off.
Because of the ridiculously exposed placement of these pins, I'm sure I'm not the only one who has experienced this. In fact, on TheRetroWeb there is a picture of one of these boards in a really abused state with half of it's components removed and those specific pins are all mangled and missing their jumper.
PSA: If your PS/2 ports aren't working on an ABIT IS7-E, be sure that PS2-PWR1 has a jumper on it!
There are also similar jumpers for powering the USB ports, but they are down near the middle of the board and are much less likely to get plucked off accidentally.
Reply 30770 of 30772, by appiah4
Back from a hiatus. Recapped two motherboards successfully.
Reply 30771 of 30772, by Nexxen
appiah4 wrote on Yesterday, 22:02:
hmmm... Nice!
Congrats for the job: the most boring chore of all!
Did they have issues before recapping?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 30772 of 30772, by appiah4
Nexxen wrote on Yesterday, 22:41:
hmmm... Nice! Congrats for the job: the most boring chore of all! […]
hmmm... Nice!
One of them had every single cap around the CPU area totally exploded and did not post at all. The other had bloated caps in the VRM and RAM area, POSTed but I never stress tested it, I doubt it would have gotten very far. They both work very well now.
I did not go for top quality caps, honestly I never do unless I am recapping something I plan to use frequently for very long like a piece of high end audio equipment or a game console. For things like motherboards I may probably use once or twice in the next five years I just use Koshin Low ESR caps and call it done. They are cheap, reliable (IME) and get the job done.
