Pushing a 486 beyond 200MHz - achievable?
Reply 40 of 51, by noshutdown
rmay635703 wrote on 2026-02-11, 22:45:
The proprietary bus is why nobody cloned into ppro, the “pentium” bus was nothing special besides being pipelined more deeply with a longer burst cycle. The next address and burst was what was different, whether those could be handled by a simple hold and release is unknown to me.
Certain old 3rd party pentium motherboards used chipsets that stuck to 32bit memory transfers, so besides speed the chip was already being interfaced to 32 bit boards at retail
what? any info on pentium chipsets using 32bit dram? should have been as slow as pod.
i remember some people claimed opti chipsets to be the slowest for pentium, but even those boards seemed to demand two symmetric simms in a bank.
Reply 41 of 51, by rmay635703
noshutdown wrote on 2026-02-12, 01:23:
I had a p60 that came with a single simm and vlb, was slow and is long since ecycled , I thought it was an UMC or OPTI but it’s been a long time.
Reply 42 of 51, by Anonymous Coward
There's an issue of PC Magazine which reviews all of the early pentium systems and lists which ones do 32/64-bit cache and main memory.
OPTi had a couple of 5V Pentium chipsets. The cheapest one supported both 486 and Pentium, and had 32-bit DRAM. They definitely supported single SIMM operation, because I had one too.
Reply 43 of 51, by OzzFan
rmay635703 wrote on 2026-01-31, 00:45:
Certain old 3rd party pentium motherboards used chipsets that stuck to 32bit memory transfers, OPTi 82C571 , so besides speed the chip was already being interfaced to 32 bit boards at retail
The OPTi 82C571 was a 486 chipset that only worked with 486-to-Pentium OverDrives. It didn't work with Socket 5/7 Pentiums. All Pentium-compatible chipsets required 64bit path to memory.
Hobbyist Developer : https://www.shelteringoak.com/du/
Reply 44 of 51, by OzzFan
Anonymous Coward wrote on 2026-02-12, 02:54:
Some Pentium motherboards allowed the system to boot with a single SIMM installed, but this does not mean the memory bus was 32-bit. The chipset still had a 64bit memory bus. A single SIMM populated only half the bus as a degraded, fallback operation (interleaving disabled, half bandwidth). This is not the intended configuration. Intel's own documentation for the 430FX and 430VX chipsets explicitly describe the degraded mode.
So yeah, you could run a Pentium with a single SIMM but the chipset itself still provided a 64bit path to memory. But no chipset was designed to work with both 486 and real Pentium class chips in 32bit memory mode.
Reply 45 of 51, by OzzFan
feipoa wrote on 2026-02-11, 14:19:
OzzFan wrote on 2026-02-10, 17:33:
I'm also not quite sure why Intel's offering was referred to as "shitty" either. For what it was, I think it is an excellent product.
Probably because very few socket 3 motherboards worked with the POD when L1 was in write-back mode. Has anyone made a list? I'd be surprised if it topped more than a dozen motherboards. I can only think of 3.
That just means loss of performance while running in write-through mode. That doesn't make the chip shitty. It's a workaround for boards that don't support write-back mode.
Reply 46 of 51, by Anonymous Coward
OzzFan wrote on 2026-02-12, 14:12:
Sis 5571 could operate like that I believe. Not sure if intel chipsets supported it though. The opti budget chipsets we’re definitely not 64 bit though, and it’s clearly stated in the brochure which is on bitsavers.
https://bitsavers.org/components/opti/brochur … ochure_1993.pdf
Reply 47 of 51, by OzzFan
Anonymous Coward wrote on 2026-02-12, 15:43:
That brochure is from 1993, the same year the original Pentium 60 & 66MHz chips were released. I see no evidence that an actual motherboard was made for both Socket 2/3 486 and Socket 4/5 Pentiums were actually made. OPTi was probably working from limited or inaccurate data from Intel at the time. The best explanation is that the brochure was referencing the then-upcoming 486-to-Pentium OverDrive and not a true Pentium chip.
Reply 48 of 51, by Anonymous Coward
While rare, they do exist. TMC/MyComp seemed to have a special affinity for them.
https://theretroweb.com/motherboards/s/tmc-my … p-mynix-pat45pv
Enjoy.
Reply 49 of 51, by OzzFan
Anonymous Coward wrote on 2026-02-12, 16:35:
Enjoy.
Ok, I stand corrected on that point, however, it only supports Socket 4 Pentiums which were clocked slower than the 486-to-Pentium OverDrive. From the documentation I'm reading, the Socket 4 Pentiums could run with a 32bit memory subsystem, but Intel was quick to abandon Socket 4 in favor of Socket 5.
Which brings us all the way back to the original statement: why didn't CPU upgrade manufacturers produce a faster speed Pentium for 486 systems? Because the faster variations would not work with 486 class chipsets. That statement still holds true.
Reply 50 of 51, by Anonymous Coward
Intel actually did have plans for a faster POD for 486 systems. I believe it was to be a 100Mhz model, but it was cancelled because the market already moved on.
Also I want to say that at least one socket5 motherboard uses that dreadful opti 571/572 chipset. There were also boards made with similar crappy chipsets from UMC and Forex.
Reply 51 of 51, by waterbeesje
One of my VXpro based boards, a Pc Chips M537 variation, certainly does support running in 32b ram mode. One stick of anything that smells like 72 pin is ok, nor picky at all.
This probably is one of PC Chips' methods to create ultra cheap solutions for lowball builders.
The board itself is very compatible but rather slow. Besides that, the Sdram slots don't seem to work.
The VXpro seems to be an Apollo VPX/97 rebrand, looking at Theretroweb.
The speed penalty for 32b ram (1 stick) versus 64b ram (2 or 4 sticks) is over 50% of ram throughput according to speedsys. Using 8MB Edo sticks.
Besides that, it should be somehow be possible to look at this the other way around: using a 5x86 with an adapter to use it on a Pentium chipset. Losing performance for being only 32b and thus half of the cycles, but the stable 60/66/75MHz bus speed wel be helpful
Stuck at 10MHz...
