VGA Repair report collection
Reply 60 of 70, by ChrisK
Unbelievable. Very much appreciated!
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 61 of 70, by tehsiggi
ChrisK wrote on 2026-02-18, 13:13:
Very welcome. The X700 AGP is basically the X700SE PCIe but with the full chip enabled. They went for DDR1 due to cost.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 62 of 70, by JammyPajammies
tehsiggi wrote on 2026-02-18, 07:52:
Keep it up! Regarding the schematic, there you go!
I wonder if there is any issue with memory, as the pattern with the colors in your first picture is very repetitive.. you could try to find a version of MATS for that cart RAM chips layout on Quadro 980 XGL
Whoa, that was way fast! Thanks for the schematic! This is close enough to the NV28 on my card (NV28 seems to have a few extra capacitors at the outer top left/right edge and center bottom-middle) that with a reference image with color differentiated capacitors, I am able to determine the values of the capacitors that need help. geforce_4_ti_4800_r.jpg
The attachment Cap Reference.jpg is no longer available
The schematic + external reference image confirmed my suspicion that my card's cap colors didn't make sense. Of course, my first attempt with the shoehorned 2000pF capacitors was the actual closest to actual spec.🤣 The 4.7uF 0805s that I put in are correct, but I got the 0.01uF capacitor on the data lines wrong by a factor of 5 (I put in a 2000pF), whoops.
On the point about memory, the artifacts could have been caused by trapped isopropyl under the chip(s) from when I was cleaning flux off after attempt #2 or a result of the capacitor values from that attempt. The benchmark screenshot from my previous post was made after attempt #3 and ran without any artifacts (I was watching the whole time), so I would hope that the memory is ok. In any case, I am going to hold off on trying MATS until I get the correct value caps back on. I will update when I have news to share! 👍
Reply 63 of 70, by JammyPajammies
Attempt #4 using the schematic specs completed. All done with this one I think. Embarrassingly, it seems that my display setup (PC -> Extron VGA splitter -> monitor) was the main culprit behind the smearing/ghosting with this particular card. 🤦
The attachment IMG_20260221_161412.jpg is no longer available
Performance is fine, no artifacts on benchmarks, only one minor issue remains that isn't a deal breaker: There is coil whine or some other squealing in the 10-14kHz range from the card that starts as soon as I power on the PC but goes away and stays away the moment I put a load on the card, i.e. start a 3d mark run. This problem persists with a different fan plugged in and doesn't seem to happen at all if I disconnect the fan. I always thought that coil whine was positively correlated with component load, but I guess that's not always necessarily true. 🤷
The attachment all_repairs_stop.png is no longer available
The attachment IMG_20260222_113335.jpg is no longer available
The attachment IMG_20260222_113246.jpg is no longer available
Hot air station is still a few weeks out, so eventually I might try to get the mlccs to sit a little more flush using it, though I don't know or think it really matters all too much.
Reply 65 of 70, by JammyPajammies
tehsiggi wrote on 2026-02-22, 21:18:
Whining of the regulator could be due to the compensation network of the switching regulator not matching the output stage with the new caps.
Glad the card works.
You nailed it again! I looked at the schematic for the specs of the big electrolytics. Indeed, the big tall cap in the previous post needed an ESR in the range of 170mOhm and the one directly above it needed a bit more resistance as well. I finally got to use caps that I salvaged to practice desoldering years ago for something. No more high pitch whining! And I can finally justify having random caps on hand. 😆
The attachment IMG_20260222_154840.jpg is no longer available
Reply 66 of 70, by ChrisK
Does anyone know if it's possible to mix RAM chips from different manufacturers on a Ti4200 (NV28)?
I have a card with two allegedly defective chips from ESMT with 3.6ns in TSSOP-66 package. Those are relatively hard to get and would cost more than twice what the card itself was.
Apparently there are four strapping bits for the RAM type but I can't make anything out of the different variants since I don't know the meaning of the individual bits. There's also little information in the commonly available schematics. Must have to do with memory organization and termination themes but like said, exact information in missing.
I'd have some Hynix or Samsung chips with same speed grade available. But will either of them work in the current/mixed configuration?
I'm not that anxious in switching all eight...
Reply 67 of 70, by tehsiggi
ChrisK wrote on Yesterday, 13:23:
Does anyone know if it's possible to mix RAM chips from different manufacturers on a Ti4200 (NV28)? I have a card with two alleg […]
Have you checked the datasheets with regards to the timings? If they are comparable and the supply voltages as well, i don't think there should be that much of a difference. Got any part numbers to look at?
Reply 68 of 70, by ChrisK
Was more focused on getting the original ones until now. My inner Monk demanded it...
The others came up while searching. Wasn't sure if they could be an option.
M13L128168A-3.6 (original)
https://datasheet4u.com/pdf-down/M/1/3/M13L12 … 68A_EliteMT.pdf
K4D261638F-TC36 (replacement option 1)
https://www.alldatasheet.net/html-pdf/86665/S … K4D261638F.html
HY5DU281622ETP-3.6 (replacement option 2)
https://datasheet.datasheetarchive.com/origin … /DASF003295.pdf
Edit: had to correct the third link. Somehow they got a "DDR" and a "gDDR" variant at Hynix with the exact same part number but different timings!?
Reply 69 of 70, by ChrisK
So I think we've a showstopper called VDD.
ESMT has it at 3.135V to 3.6V while the others are at 2.375V to 2.625V. So it seems no mixing possible in this case.
Would you concur, tehsiggi?
