First post, by Winstonwolfe
- Newbie
Hi all,
I’m running into a weird compatibility issue with a late-90s system and hoping someone has found a cheap VGA→HDMI converter that actually works in Award BIOS.
Hardware:
GPU: NVIDIA Riva Vanta
Motherboard: MSI BX Master (Award BIOS)
Display: modern HDMI monitor
OS boots fine
Problem:
I bought two different USB-powered VGA→HDMI active converters.
Behavior is identical on both:
✅ POST screen shows fine
✅ Windows output works fine
❌ Screen goes blank when entering Award BIOS setup
❌ Monitor reports no signal while in BIOS
So the adapter clearly locks onto 640×480 POST, but fails on the BIOS video mode.
From what I understand, Award BIOS often switches to 720×400 text mode, which many cheap scalers don’t support properly.
Has anyone found a budget VGA→HDMI converter that reliably works with:
late-90s cards
Award BIOS text mode
I know high-end scalers exist, but I’m specifically hoping for something in the cheap Amazon/eBay tier that is proven to work.
Any confirmed working models appreciated. 👍
MSI BX Master/P3 1000 Mhz/512MB/2xVoodoo 2 12MB SLI/GeForce 4Ti 4800SE/SB64 Gold/
