First post, by Predator99
Does somebody have a manual / jumper setting for this card? Otherwise I will report here what I find out.
The ET4000AX is labeled "P/N:2140"
The attachment ET4000 2140.jpg is no longer available
Its this card:
https://theretroweb.com/expansioncards/s/unknown-2140-rev-c
Its interesting because it has EGA and VGA out. And the ET4000 should be a fast card.
I dumped both ROMs:
The attachment TSENG ET4000 2140.zip is no longer available
This is not a product of IBM (IBM is a trademark of International Business Machines Corp.)
Copyright(c)1988 Tseng Laboratories, Inc. 09/14/90 V8.01
Enhanced VGA BIOS MODEL:2140. 09/14/90
I got the card with all 4 DIPs "OFF". When powering on, VGA-out shows a a sharp and crystal clear picture on my DELL LCD, much much better than a more modern PCI-VGA.
The attachment VGA.jpg is no longer available
At the same time, BIOS screen is output on the digital EGA-connector!
The attachment 1.jpg is no longer available
Reply 1 of 3, by Predator99
After the BIOS-screen, the PC boots with VGA-out. EGA is black / no signal.
I tested some video modes with checkit. With 2 modes, signal was activated on the EGA-out.
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
Will try some DIP settings the next days too see what changes.
Reply 2 of 3, by Predator99
OK thats interesting...output on EGA seems to be always the same as on VGA. Duke3d (320x200x8) is also displayed on EGA, with wrong colors of course (DIP3=ON, DIP1,2,4=OFF)
Dont know if I would connect my EGA monitor to this, but I will check the freqencies of this mode.
The attachment Screenshot 2026-02-21 140152.png is no longer available
Reply 3 of 3, by Peter z80.eu
Are there any news related with this ET4000 card with EGA output (and VGA mode image) ?
I know, it was about 220 days ago, but it's still interesting if you have a portable PC like the Siemens PG750, which has only a build in TTL (EGA) monitor.
It is an ET4000 with 6 crystals, so there is a good chance it can cover a lot of different frequencies...
