Reply 120 of 130, by FullYes
RetroPCCupboard wrote on 2026-01-17, 09:34:
There are some DOS games like screamer 2 (in hi-colour, high res mode) and System Shock (at 640 x 480) that would most likely run poorly even on your K6-3. But, I think they are an exceptional case. Most DOS games will run fine, and these will too at lower settings
As promised, I gave system shock a try (the enhanced CD version) and it runs Great!! I had to put the mouse look patch on to make it playable. Man the standard controls are aweful! But the patch also offers other screen modes. Even 800x600 is playable. I am running it at 640x400 as this is perfect for my 16:10 1920x1200 display
I have been experimenting with slowing the system down too with k6init. For those buggy old adventure games, disabling the L1 cache seems to let me play day of the tentacle, monkey island etc using Roland emulation through the AWE64. I had already tried this with the Pentium but was unsure it would still work on the k6, day of the tentacle is notoriously problematic apparently. One game ive been wanting to try is LooM. I’ll try and install that tomorrow.
I finally closed the lid on this system today. I declare it finished.
The question remains. What do I do with the two Athlon builds?
Reply 121 of 130, by RetroPCCupboard
FullYes wrote on 2026-01-30, 22:55:
That's great. I hope it gives you many years of enjoyment
If you are happy with DOS performance on this machine then I guess you don't need DOS compatability on the athlon system. So maybe use the later board and keep it as Win98 only.
I have lost track of that your system configurations are now. Is it K6-3, with Voodoo 2000 and Athlon 3000+ with 5900XT?
Reply 122 of 130, by FullYes
You remember correctly!
Got two full Athlon systems effectively, and I’m thinking of doing as you say - build a system around the 3000+ using the DDR board I originally just bought just for the FX5900XT
I’m curious how it will behave in DOS using the Audigy. I don’t remember having much success with PCI sound cards in dos back in the day, but I think it’s down to the motherboard/chipset how well it works (or doesn’t). The Athlon XP setup I had in period was nforce2-based. I saw on here that nvidia chipsets don’t have good legacy support.
I need to revert the KT133A board back to standard so I can (probably) sell it. I have a pile of bits to go with it. Including an FX5200 which I bought as a backup. Doesn’t work in the DDR system but works perfectly in the kt133A 🤷🏼‍♂️
Reply 123 of 130, by RetroPCCupboard
If it were me, I'd keep the parts somewhere as spares. These retro parts are only going to get more rare and expensive and, being old, could die at any time.
Reply 124 of 130, by FullYes
I just have too many spares and complete systems and not enough space. If I had to get down to one retro system, I believe I would choose the socket 7. So i will prioritise spares for that. I’ll keep at least one spare video and sound card for each system. I have much more at the moment!
I fired up the Athlon system today. It’s currently still usinf the KT133A motherboard modded to run with the 3000+ in, clocked at 2266MHz (17x133) it posted straight away, but for some reason no video in windows. I’ve changed my monitor since I last ran this machine, and whatever mode mustn’t have been compatible. After much faffing with drivers, it’s now up and running
I decided to do some of (Phil’s) benchmarks to see how the dos performance is on such a machine
Quake320 - 322fps
Quake640 - 37.6fps
Doom -94.9fps (787 ticks)
Chris’3d-320 - 707fps
Chris’3d-640 - 132fps
PCPlayer-320 - 550fps
PCPlayer-640 - 63.3fps
Interesting that there’s such a big drop going up in resolution. Univbe isn’t supported on the 5900 as it’s already vbe3.0 (same as the voodoo3) I was looking for somthig else to try, like a k6init type program for the k7 - i could not find anything in searches, but I realised it’s right there in Phil’s benchmark pack - MTRRLFBE
Enabling this gave me much better results
Quake-640 - 121.4fps
Chris’3d-640 - 452fps
PCPlayer-640 - 246.2 fps
So about a 3-4x improvement
Don’t know why doom is so slow?? It’s slower than the Pentium MMX clocked 10x slower
Reply 125 of 130, by FullYes
I’ve been running this system pretty much all day at 2266MHz. Perhaps I was too hasty to abandon the platform?
No, the more dos games I’m playing, the more it feels wrong using this machine for them.
I’m also seeing some random file corruption here and there. Nothing major, but the odd piece of software or dos driver no longer works correctly or performs an illegal operation. Perhaps a side effect of the overclocked state, or something the via 686B South bridge was renowned for?
Time to make a Change. Pulled the 3000+ from the Soltek SL75-KAV kt133A and dropped it into the A7V333 which has been sat on the shelf since I stripped the case it was in
Up and running straight away. The BIOS reports a CPU multiplier of 5x and a clock speed of 1000MHz. Oh dear. Oh wait, it’s just some BIOS bug, the CPU is correctly identified on the POST screen (the first boot, the screen was obscured by a full screen logo) as a 3000+ and is running at its correct stock speed of 2166MHz. time for a couple of benchmarks
Some interesting results. All of the dos benchmarks are faster at 320x200 and slower at 640x480 than they were using the KT133A. MTRRLFBE no longer has any impact on performance on this board it would seem.
Quake320 - 369fps
Quake640 - 123.2fps
Doom -101.34fps (737 ticks)
Chris’3d-320 - 781fps
Chris’3d-640 - 391.5fps
PCPlayer-320 - 581fps
PCPlayer-640 - 200.3fps
Quite a big swing in some results. Quake at 320 is ~15% faster while PCPlayer 640 is ~20% slower. Doom is still weirdly slow.
I had not reported previously but I did have some speedsys results to compare. The KT133A had a memory score of 539MB/s while the A7v333 has a score of 863MB/s - I expected a much higher memory score here. Perhaps the via chipset doesn’t have great DDR performance, it was still fairly new at the time. I need to test more ram configurations and timings. As far as I can tell it’s pushing the ram already on the timings (2-2-2-5). This may be why I was having trouble getting this system to post with most of the DDR RAM sticks I have
Reply 126 of 130, by FullYes
I’ve been playing around with the Athlon some more. The 3000+ seems to be working without any stability issues on the A7V333. I did see some higher temperatures with this CPU in this board compared to when it was in the SOLTEK. So I’ve ended up putting a high rpm socket 370 fan on it and put the noctua fan on the socket 7. Doing so dropped the temps about 10 degrees, but at a high cost in terms of noise. The socket 7 is whisper quiet now though! I had bought the socket 370 cooler and fan when I got the k6-3, but the K6-3 barely gets warm.
I think this board doesn’t support high multipliers, but there is a workaround of some sort to allow the 3000+ to run at the correct frequency, 5=13 when the 5th multiplier pin pulled high. 13 being the correct multiplier for this CPU
What I fancied doing is increasing the FSB on a lower multi, just to see what this board is capable of. But I cannot set a multiplier lower than 5x (13x)
Somewhat ironic that I have the opposite problem in this motherboard!
I have some comparisons for you
With the Soltek board running at 17 x 133; 2266MHz (actual speed ~2275MHz)
3dm99: 14608 GPU, 33904 CPU -> the max I could get on this board was around 15000 / 35000 respectively
With the A7V333 board running at 13 x 166; 2166MHz
3dm99: 17690 GPU, 40083 CPU
And tweaked a little to get the same clock as the Soltek; 13 x 175MHz
3dm99: 18400 GPU, 42000 CPU (I forgot to write the CPU result down, but it was over 42000)
So in this benchmark just upping the FSB and swapping to DDR has increased performance by more than 20%
Reply 127 of 130, by FullYes
As I mentioned earlier in the thread, I also have an XP machine. I am selling a 980 TI, but thought it would be funny to try it in this machine before it goes
I had some trouble fitting it in the case 😇
The attachment IMG_8681.jpeg is no longer available
The two fast SATA Ports are right under the GPU as well. Managed to find some angled ones in my box of wires
Wasn’t sure if the PSU would be up to the job but it didn’t complain
Couple of benchmarks. 3dmark99 took some messing to get it going
The attachment IMG_8683.jpeg is no longer available
The attachment IMG_8685.jpeg is no longer available
This 2600k is stock and a few years older than the GPU. Not sure if these scores are any better than my GTX 460 (I’ll need to re-test!)
Not much happening with the other machines. I did have an issue with the socket 7. After playing unreal for an hour the other day, The screen went black. Took the lid off and both the CPU cooler and GPU voltage regulator felt quite toasty. I decided to wire the noctua cpu fan directly to the PSU rather than from the motherboard to see if that increased the RPMs, as it seemed to be turning quite slowly. I also swapped the PSU out for a more powerful Antec one. Running the machine again for a couple of hours with prime95 and unreal menu screen running didn’t create any more crashes, but I’ll need to keep an eye on it
Reply 128 of 130, by FullYes
Too many things to update in this thread. I’ve been having a bit of a clear out. Still not sold the 980 TI or the KT133A. This week I was given an AM3+ setup by my brother containing a Phenom II X6 1075T with some nice 1866MHz DDR3 RAM installed (that the Phenom can’t even make use of unless you overclock it) so I’ve nicked this for the 2600k. A quick test with the new ram, using the GTX460. I also increased the CPU multiplier to 42
The attachment IMG_8802.jpeg is no longer available
The attachment IMG_8781.jpeg is no longer available
A nice 80fps bump there!
Anyway this has become a tangent of a tangent and it’s really time I was back messing with more retro hardware
I wanted to play Mobil 1 rally championship / rally championship 2000. I remember having the demo and playing it over and over to try and get the best time. Me and a friend of mine became a bit obsessed with it. Anyway the PC of choice for this was the Athlon, though the K6-3 would moreorless meet the hardware requirements, I want to run it at 1600 x 1200
Well I still hadn’t gotten around to truly finishing off the final Athlon PC build. Apart from not being able to find a working black fronted floppy drive, I had not gotten around to setting up a sound card on this motherboard. I was planning to use the Audigy because it’s there and it came with this A7V333 that I’m using. So it must work, right?
Nope
The card does not show up in the PCI devices listing during the boot screen, but it is recognised in windows and all drivers install. I just get no sound. The device manager says I need to use the bios to give the device an IRQ. The bios does have an option for this, but no matter which slot I use and which irq I set, I get the same result.
Today i tried the Audigy in a windows XP test bench I have set up at the moment on (yet another) AM3 motherboard ive been using to test old PCI-E GPUs. And it WORKS on that. I need to try it in another win98 machine to see if it’s just a board-specific issue. (Audigy/Live and VIA chipsets don’t always get along, I know) But I don’t get why the card was installed in the original a7v333 machine I bought if it didn’t work. It’s all very strange!
Reply 129 of 130, by FullYes
No progress on the Athlon today. I decided to install rally champ on the socket 7 to see how well it would run. It ran…Ok. Not great though. A lot of low FPS situations. Also, a few crashes to desktop. The crashes seem to be related to the overclock. Run at 400MHz and all is well. So it’s back to stock configuration after lots of overclocking. Probably for the best!!
This is definitely a game for the athlon, so I will come back to this one
I then spent a few hours playing system shock on the socket 7 instead. Thanks for the suggestion @RetroPCCupboard I am really enjoying this one!
Reply 130 of 130, by RetroPCCupboard
Yep, System Shock is a great game!
