First post, by Alesia
This is kind of a vent post I'll admit, but I'd appreciate any ideas anyone might have. I have this Kaypro 10 that I've been trying to get running that won't post, it just warms up to a blinking cursor.
So far I have:
- Verified the voltages (all are rock solid and right on the numbers with everything connected)
- Re-socketed and de-oxited every socketed chip and connection
- Attempted to clean the floppy drive however it's read head was dangling loose when I opened it so that was ruined well before I got the machine.
- Opened up the keyboard to find socks stuffed into it that had absorbed moisture and rotted the backside of the keyboard pcb and inside of the keyboard casing, over half the keys do not work. Tried to find the Ebay listing that had kaypro keyboard PCBs of the same type, but could not find it, so replacement seems impossible (or prohibitively expensive) Abated what rust I could, mostly to save the casing before it got too bad.
- Soldered down a resistor that had a cracked solder joint (successful)
- Disconnected all peripherals to see if a minimum configuration helped (did not).
- Suspected Bios/ROM issue and tried to find replacement Kaypro 10 roms for sale, unsuccessful.
Things that are working:
Power Supply, Vent fan, CRT, and at least 1 case LED. Possibly hard drive, but I haven't put that into my Nec V20 powered system to check so it's an unknown still, very good cosmetically though.
I haven't taken a multimeter or scope to much admittedly, but I'm starting to struggle mentally with how many parts are bad vs good and I am *terrible* at reading electrical diagrams so I don't even know where I would start testing. The keyboard being completely rotted is pretty deadly to the project as a whole. I would appreciate some opinions on if I should proceed trying to fix the thing, give up, something to test, idk. My brain is a bit fried from banging away on this for several days straight.
Reply 1 of 13, by Shponglefan
Rust on the metal can be dealt with either by mechanical or chemical removal (or both).
Those circuit boards look like they have a *lot* of corroded traces. It's likely repairable, but would be a tedious job to do so.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 13, by Alesia
Shponglefan wrote on 2026-02-22, 23:13:
Yes, that was the backside of the keyboard. Probably 90% of it was like that, at that point you are just building a new keyboard instead of repairing one imo.
Reply 3 of 13, by DaveDDS
First thing I'd do about the ROM is ask in CCTAK "Classic computer collectors mailing list" - I'm sure somone there has an 11 and might be able to read the ROM content for you.
Never had an 11 - had a 4 and a 10 ... somwwhere along the way someone sent me source code to "Kypro-4 BIOS" - never looked at it much ... but it is up on my site. Depending on how similar the 11 is to a 4 - might be a place to start if you want to try and "make" something... (don't recall - BIOS might not be ROM content on CP/M .. could be a set of OS drivers)
If some of the keys work, then whatever the keyboard is using for a controller is still good. Worth checking with a multimeter if the non-working keys make contact (and you could try shorting the connections and see of the computer sees a key)
If enough of they keys themselves work (or you can find a "new" key that fits the tops)... and if you can make out where the traces would be, you could make a new circuit board - this could be laying out and making an actual PCB, or if you can clear away enough of the corrosion, reuse the existing one and tack wires key to key to replace the connections. Or do the same with a large protoboard after drilling holes for the keys... fortunately keyboards are simple!
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 4 of 13, by DaveDDS
Alesia wrote on 2026-02-22, 22:58:
... Suspected Bios/ROM issue ...
Curious why you suspect the ROM? There are lots of other reasons it might not try to boot.
Worth scoping the ROM select and see if it get accessed multiple times immediately after power-on/reset ... you should also be able to look at address lines and see if the code "wanders off" (usually happens with ROM errors)
Often when a ROM goes bad due to age, it's fairly obvious - lots of bits will be flipped, text will have obvious errors etc. (not all bits fail at the same time)
Have you tried reading it and seen what it's content looks like?
Been a long time since I looked at how a Kaypro starts, but most system ROMs have a checksum which the system tests at startup and aborts if it doesn't match... Usually not a complex function, a bit of disassembly should tell you how to calculate and test it (this test is usually done early on - also look for "ROM bad" type message and see if you can find the code that references it) once you figure out how it's tested, you can verify it independently.
Also, If it's an EPROM, as they begin to fail with age, they sometimes read "correctly" at lower supply voltages (this is the reason EPROM programmers in "FAST" mode do the programming at higher than 5v ... to make sure the device is "good and programmed").
Reply 5 of 13, by Alesia
DaveDDS wrote on 2026-02-23, 04:27:
Curious why you suspect the ROM? There are lots of other reasons it might not try to boot. Worth scoping the ROM select and see […]
The only reason I suspected it was because the boot ROM chip has it's light shield/cover removed (was not fallen off or otherwise in the case) It's been a while but I looked up the chip and it was a UV erasable chip, that combined with the no boot w/ no errors and the light cover being removed gave me the impression it had been wiped intentionally. I did look at getting a ROM reader/writer but a T48 kit is expensive enough I have to plan a month or two ahead of time to afford it, so it just hasn't happened. I don't think the character ROM is corrupted as a reset of the system causes all characters to flash on screen as the CRT resets and those characters seem to be all drawn correctly. It also has it's protective sticker.
I'll look into the mailing list, but I think the keyboard is going to be the wall with this project, designing a replacement myself is so far beyond my knowledge base that it's unlikely I'll ever attempt it. Maybe if the community figures out clone PCBs to be printed I could do that and move switches over/get new switches but with how far gone the current one is, repair isn't an option and doing a completely manual rebuild would be a massive time and money dump I just can't commit to.
Reply 6 of 13, by DaveDDS
Typical EPROMS (UV erasable ROMs) of that era had a glass cover built into the chip to allow UV light in to erase, and usually an opaque sticker over that (to avoid incidental UV light exposure)
When you say "light shield/cover removed" - do you mean just the sticer/cover over the chip, or has the glass part of the actual chi been damaged/removed (if the latter, they you're SOL) - if the former, know that EPROMS need a fairly strong/constant exposure to UV to be erased. I have a couple EPROM erasers which are florecent UV bulbs with run within an inch of the top of the chip (ie: very strong UV light) and it still takes at least an hour to fully erase a chip! - Before I had them, I tried direct sunlight and couldn't erase even after leaving out every day for over a month!
I'm assuming this chip was somewhat shielded inside the system where light levels would have been be very low?
Systems of that era typically used a direct memory mapped video screen. Sometimes with a "soft" controller (like the 6845), sometimes with a hard-wired "always on" one. Immediately at boot, the system would 1) program the video controller (if used, and if so no video characters would appear till this is done) and 2) clear the video memory to all spaces (blank - until this is done the video display shows whatever ramdom characters the RAM powered up with)
I'd look at all the larger chip on the mainboard and figure out it any of them is a video controller...
When you say "all characters flash" do you mean that you briefly see a screen of random characters which then goes blank (normal)
If there's a video controller, the presence of these characters means the controller IS being set up.
Going to blank means the system IS clearing the vido memory to spaces.
This suggests to me that system ROM is actually running (at least long enough to do these things) - had it been intentionally erased, then neither of these would happen.
It was not uncommon for these old systems to NOT output any text until they had booted.... I know the floppy drive is damaged, but have you connected it? - you should see it activate if the system gets far enough to try booting.
BTW, If you feel like "building something"....
Back in the 1980s I designed an EPROM programmer which could handle the most common EPROM types of the time (2716, 2732, 2754, 27128, 27256) - I still use it today (over 40 years later)
I used to sell the design, but I'm pretty sure that (like all my products) I've posted the design on my site for free now.
If you can clean away enough the the corroison to avoid "unintentional contacts" it wouldn't be hard to tack on wires to make the needed connections. I've done this for a few old systems over the years...
Reply 7 of 13, by DaveDDS
What exactly is the boot ROM chip?
Chances are it's small... IIRC CP/M itself contained "BIOS" drivers to access the hardware incl. disk... The ROM was kept small because 1) bigger ROMs were expensive/not-available, and 2) unlike PC BIOS, this address space was not used after boot (so why waste more than you had to)
To give an kind-of extreme example... my Altair had an early "NorthStar" single-density floppy disk card - it contained a boot "ROM" (hardware, not an EPROM) which was a whopping 256 bytes in size. It contained a subroutine to read 1 sector off the disk, and mainline code to use that routine to read a sector from the disk into RAM and jump to it. Needless to say it did not output any messages at any time (it didn't even know how to talk to the RS-232 terminal - which could differ from system to system)
That "new" 256 bytes would then (using the ROM subroutine) read the NorthStar OS into memory and launch it.
The only "boot messages" you got were:
1) The disk light coming on ment it was trying boot.
2) Failure of the OS to start ment "boot failed".
Reply 8 of 13, by Alesia
DaveDDS wrote on 2026-02-23, 11:59:
Typical EPROMS (UV erasable ROMs) of that era had a glass cover built into the chip to allow UV light in to erase, and usually a […]
The floppy drive was doing a seek test, but I had not considered swapping in another as I never got the "Kaypro 10 v x.xx xxx" splash screen. It's inclusion or exclusion did not change the fault symptoms, and I figured the seek test was probably performed by the floppy controller and not the mainboard. I could be completely wrong though. As for the rom I'm talking about, it's unlabelled on the Kaypro 10 technical manual's chip listing, but it's U42 in the lower right quadrant of the board right under the J9 connector. I did do a quick unscientific heat test and only the CPU and CRTC were getting warm (but not hot.) Every other chip was stone cold. The fact that the video is being blanked properly (?) is good though. I never got a boot failure message or any other indication that the POST/BOOT was failing aside from the forever blinking cursor. I do have a drive I can pull from another machine to test if you think it might do something, sadly I don't have a spare to just donate to the Kaypro. 5.25" 360k drives push over $100 in my area for some reason so I'm pretty slim on them.
Reply 9 of 13, by DaveDDS
Floppy controllers don't normally do "seek tests" .. The PC bios does a "seek test" to see if the drive is 40 or 80 tracks (Step out 45 tracks - enough to hit the stop on a 40 track drive), then seek back 44 tracks & see if the TrackZero sensor comes on)
Normally a drive steps to track 0 under control of the bootloader to access the boot track which is almost always track 0. Since the bootloaded doesn't know what track the drive was "left at", this almost always means step until track-zero sensor comes ON. (useful test - manually position drive to about 1/2 way and see if it homes head at startup)
As I said before, there may not be error messages ... A "splash" screen (if it exists) might be displayed by the OS as it boots.
Is the BOOT ROM in a socket? - If yes, remove it (which will guarantee the startup code won't run) and see if you still get drive seeking and screen clear after flash of random characters?
I'd guess no which will mean the boot rom was running before - if yes, it means the subsystems do more than was "usual" in that era.
Reply 10 of 13, by DaveDDS
Alesia wrote on 2026-02-23, 15:14:
... unlabelled on the Kaypro 10 technical manual ...
So.. do you have schematics? If so, count the address lines going to the ROM to determine its size! Also, how many pins?
Reply 11 of 13, by Alesia
DaveDDS wrote on 2026-02-23, 16:21:
Sorry it took me a few days to dig into this again, IRL stuff got in the way.
The ROM chip has 24 pins. I have no idea how to read the schematics, I just flipped through until I found the motherboard "map" of all the chips and connectors.
I tried manually putting the the read head to track 0 on the old drive, and also tried the other known good 5.25 floppy that I have and neither fixed the issue. They get the command to go to track 0/seek test/whatever, and the motor runs, but they never get the command to try reading the disk. The floppy disk should be good (?). I wrote it on my Hyundai turbo xt that has a good 360k drive and wrote using Teledisk for the teledisk td0 images that are up on retroarchive, pretty sure I picked the right image to attempt a boot to the hard disk as well, but the drives don't make an attempt in the first place so it's kind of irrelevant. The hard drive spins up with power but likewise never gets any commands.
I also made a big whoopsie and accidentally let the drive cage make contact with the power plug wiring which let out an almighty bang and tripped the breaker, but doesn't seem to have done much else (power switch was off thankfully and I wasn't shocked either.) Charred one of the power leads though. I broke my rule of unplugging the thing when I was messing around with the insides. I think I'm going to take a break from this as it's probably a bad chip somewhere rather then a configuration issue at this point, which I don't have the skills to hunt down. The hard drive still spins up, so I'll probably transplant that into my NEC V20 system that has room for it to see if it still works and get more experience troubleshooting with things that I don't care that much about compared to this Kaypro. Also take time to see if I can make the cable situation inside the Kaypro less prone to issues such as this somehow. Thank you for your help up until now.
Reply 12 of 13, by DaveDDS
When you're ready to have a further go at it, we'll try to help more...
I doubt you "big whoops" did any serious damage. The drive cage would have been grounded, so what you really did was ground a live power wire. The only damage that could have occured it if it overstressed a small cable/connection in the system (between the power cord and the drive).
Unfortunately (here in Canada at least), typical "main outlets" at 120v 15a which means by the time a breaker trips over 1800w are flowing... more than enough to overstress/burn most small connection points ... usually that doesn't happen in the time it takes the breaker to trip. It's also why my bench has a outlet server through a local 3A breaker.
A 24pin ROM of that era is probable a 2808(1k), 2716(2k) or 2732(4k) if you want at some point we can help you figure out the schematic to see exactly which one (you might even be able to tell with a couple simple measurements).
Just curious: Did you try pulling the ROM and seeing if the drive still steps to track0 at powerup?
Reply 13 of 13, by DaveDDS
Btw, I just asked "Professor Google" about they Kaypro 11 and it says the drives are single sided.
I don't know if the Kay11 used 8-secfors/track or 9 - which means your disks should be 160k or 180k
Make absolutely sure you have the right disk image and are re-creating it properly. I did find a few "uncertainties" about the way TD dealt with images, which is mainly why I wrote ImageDisk - if there are .IMDs available, I'd use those as you can know with much more certainty exactly what the original disk format was.
IMD does have a tool to convert .TD0s to .IMDs which will give you a lot more control over how the disk is written, you may have to do some screwing around to figure out exactly how to convert and write the disk, but at least you will have that capability.
BTW: If you want to experience actually running CP/M (which the Kaypro ran), you can boot it up with my "NorthStar Horizon/Vector 1+" emulator which is available on my site.
