First post, by Alesia
This is kind of a vent post I'll admit, but I'd appreciate any ideas anyone might have. I have this Kaypro 10 that I've been trying to get running that won't post, it just warms up to a blinking cursor.
So far I have:
- Verified the voltages (all are rock solid and right on the numbers with everything connected)
- Re-socketed and de-oxited every socketed chip and connection
- Attempted to clean the floppy drive however it's read head was dangling loose when I opened it so that was ruined well before I got the machine.
- Opened up the keyboard to find socks stuffed into it that had absorbed moisture and rotted the backside of the keyboard pcb and inside of the keyboard casing, over half the keys do not work. Tried to find the Ebay listing that had kaypro keyboard PCBs of the same type, but could not find it, so replacement seems impossible (or prohibitively expensive) Abated what rust I could, mostly to save the casing before it got too bad.
- Soldered down a resistor that had a cracked solder joint (successful)
- Disconnected all peripherals to see if a minimum configuration helped (did not).
- Suspected Bios/ROM issue and tried to find replacement Kaypro 10 roms for sale, unsuccessful.
Things that are working:
Power Supply, Vent fan, CRT, and at least 1 case LED. Possibly hard drive, but I haven't put that into my Nec V20 powered system to check so it's an unknown still, very good cosmetically though.
I haven't taken a multimeter or scope to much admittedly, but I'm starting to struggle mentally with how many parts are bad vs good and I am *terrible* at reading electrical diagrams so I don't even know where I would start testing. The keyboard being completely rotted is pretty deadly to the project as a whole. I would appreciate some opinions on if I should proceed trying to fix the thing, give up, something to test, idk. My brain is a bit fried from banging away on this for several days straight.
