Reply 1160 of 1172, by red-ray
red-ray wrote on 2026-02-25, 16:04:
Have a look at strapInfo0 VMI_HD2, my reading is that it would like to run @ 66 MHz rather than it is running @ 66 MHz. Does it change if you set things to run @ 33 MHz?
Jackhead wrote on 2026-02-26, 15:03:
Same value when i set 33MHz. For testing i had only the gpu on the pci bus, same value on 33 and 66.
Thank you, it's as I suspected then so strapInfo0 VMI_HD2 does not tell us what the PCI speed really is 🙁
Given this I suspect it's not possible the report the actual PCI speed for Voodoo 5 GPUs.
It might be worth asking the guy who developed the 6000 clone, he may know a way to tell the PCI bus speed the Voodoo 5 is using.
Reply 1161 of 1172, by Disruptor
red-ray wrote on 2026-02-26, 14:20:
I just don't get it, I have made it abundantly clear I don't wish Disruptor's disruptive posts to be made any threads I start so […]
red-ray wrote on 2023-04-07, 22:41:
I am bored with Disruptor asking questions and not providing the information I need to sensibly answer them so have muted Disruptor.
I just don't get it, I have made it abundantly clear I don't wish Disruptor's disruptive posts to be made any threads I start so why do they keep happening?
Nothing has changed, he still asks questions and fails to attach the SIV save files that I would need were I inclined to answer them.
Disruptor wrote on 2026-02-26, 10:06:
The [Machine] screenshot shows that internal L2 is not shown on this screen but the external cache is declared as L2 although it is a L3 here in fact.
As for [Machine] not reporting the L3 cache then clearly this is a bug in the motherboard BIOS so the BIOS needs to be fixed as it's the BIOS that set's up the SMBIOS data that SIV and other utilities report.
I am sorry again, but I include your requested debug files here. I just did not know how to generate them, I just had to scan 9 pages of the thread until I got the idea to crawl in your change logs.
I saved them from command line now. And now I see that what you call Menu has to be called by pressing Alt + Space. I haven't seen that, perhaps it is documented because it is smart.
I usually scan first and last page before I add comments.
These old boards were created long before K6-3 existed at all. So original BIOS did not care at all about a secondary internal cache of the CPU. Chkcpu's (Jan Steunebrink) J.3 BIOS patch just modifies the BIOS in that way that these processors would be initialized at all. Please don't expect too much from these old legacy machines. On some other parts your great (non-ironic!) programme gets L3 information at all.
And my comment on the memory allocation was not disruptive at all. It just was a hint to look on or change a malloc() or similar call.
Edit: SMBIOS outputs are from bad quality. I don't trust them on old machines. It is probably not your fault then. HWinfo is not better at all.
I hope this will help.
Peace.
Reply 1162 of 1172, by red-ray
red-ray wrote on 2019-08-22, 10:17:
[*]Assuming SIV starts OK I would like the save files generated do doing Menu->File->Save Local so I can check things in detail. I am happy for these to be posted, PMed or emailed.
Disruptor wrote on 2026-02-26, 16:53:
I am sorry again, but I include your requested debug files here. I just did not know how to generate them, I just had to scan 9 […]
I saved them from command line now. And now I see that what you call Menu has to be called by pressing Alt + Space. I haven't seen that, perhaps it is documented.
Given the very first post in this thread clearly specifies how to generate SIV files I am at a loss as to why why you specified "I just had to scan 9 pages of the thread until I got the idea to crawl in your change logs". All I can assume is that you are trying to be disruptive by posting misleading information. Please stop posting to threads I have started.
The K6-3 was launched on 22-Feb-1999, the BIOS date is 01/07/00 so you statement is incorrect. Please stop posting this incorrect disruptive information to threads I start.
Why don't you do as I asked and stop posting to threads I have started?
Given "Chkcpu's (Jan Steunebrink) " does all you wish for then I suggest you stop using SIV and use it.
I get the impression you feel you could develop a far better utility than SIV is and suggest you stop harassing me and do so.
I am hoping I won't have to reply to any more of your disruptive posts, but I won't be holding my breath.
Reply 1163 of 1172, by Disruptor
I now have great additional informations for you.
It seems I've been wrong with the Windows 98 run. I am surprised! It does not show any significant difference in the 384 and 512 kB output too on the tests with 256 MB of RAM.
But!
I have done further tests that took me 3 hours of time:
1) Windows 98 native (256 MB RAM, 64 of it inside cacheable area of onboard L3 cache)
2) Windows 98 with MaxPhysPage=4000 in [386Enh] of system.ini (limits to 64 MB RAM)
3) Windows 2000 native (256 MB RAM, 64 of it inside cacheable area of onboard L3 cache)
4) Windows 2000 with /maxmem:64 in boot .ini (limits to 64 MB RAM)
5) Included all save files. DMI files could not be created on Windows 98.
Do you have your testing area below 64 MB of RAM or above?
Edit: Added the word "significant" and reordered tests to match the order of the pictures.
Reply 1164 of 1172, by Disruptor
red-ray wrote on 2026-02-26, 17:49:
Given the very first post in this thread clearly specifies how to generate SIV files I am at a loss as to why why you specified […]
Oh, I'm reading your post now.
Sorry for me not finding the menu in your program. There is no button called "menu". As I have written, it took me a while to find out it can be activated by pressing Alt - Spacebar.
Sorry for testing your program.
It shows me that my L3 cache is working - but only when I limit my operating sytem to not use more memory than the cacheable area.
It is incorrect that Chkcpu (Jan Steunebrink)'s BIOS patch does all I wish. It does not care about external cache at all. It is not a measuring tool like yours.
Please don't call every post from me disrupting. Even when a surprise for you may be disrupting in fact.
Some of the information is quite interesting - if not for you then for other vogons, I'm sure.
And about the BIOS date. The BIOS date does not matter here because the original BIOS from that date did not support K6-3, K6-2+ and K6-3+ at all.
It is Jan "Chkcpu" Steunebrink's BIOS project which adds support for newer processors to BIOSes. BIOSes from manufacturers are considered complete when being released for the first time. There are just minor patches for errors and newer CPU releases but not updates you await or expect. That board is from 1997! It is a wonder that a K6-3 is running there at all.
Peace.
Edit: Added information about Jan Steunebrink's BIOS project.
Reply 1165 of 1172, by red-ray
Twisted Six wrote on 2026-02-24, 21:40:
If you're going to issue a fix later this week, just tag me back when you do. I'll see if I can find some time over the weekend or early next week to re-run the test if you like.
Thank you again, I have just released SIV V5.86 Beta-07 which should fix the BIOS R1.6\r\n 01/15/99 to be BIOS R1.6 01/15/99, it would be good if you generated new save files to confirm the fix is correct, I will be very surprised if it isn't.
Reply 1166 of 1172, by Twisted Six
red-ray wrote on 2026-02-27, 19:25:
No problem at all. It may be MOnday before I can get to it, but I'll get it done. 😀
If you tolerate this, then your children will be next.
Reply 1167 of 1172, by Disruptor
Thank you again, I have just released SIV V5.86 Beta-07 which should fix the BIOS R1.6\r\n 01/15/99 to be BIOS R1.6 01/15/99, it […]
The full list of changes is:
file.php?id=237328
1)
First of all, I'd like to say that I have gotten a kind of arrangement with red-ray.
He feels harassed if he gets any technical help or suggestion - from anyone. So we'd like to avoid that in future.
Don't try to ask your question again in another way when you have not understood his first answer.
2)
Then he has answered my issue with the cacheable area on motherboards that have external cache (he calls them "FSB speed caches").
In short, he feels SIV's [Cache Latency] should reflect what a typical user mode program would see. Please accept that SIV therefore neither will care about cacheable area nor it will tell you about it.
3)
We did came in contact because I have reported him by eMail how my EISA 486-50 is handled by SIV.
I did get 2 other executables from SIV to give him further logfiles so he could improve EISA support, especially under NT4.
He told me: "Again, thank you for your help with testing SIV, yours is only the 5th EISA system it’s been run on that I am aware of, the 1st W95 and the 2nd NT4."
I can tell him: My system is the only EISA system where he has gotten logfiles from 2 different operating systems (Win95C and NT4).
Peace.
Reply 1168 of 1172, by Twisted Six
file.php?id=237328
Here ya go.
Reply 1169 of 1172, by red-ray
Twisted Six wrote on 2026-03-02, 20:18:
Here ya go.
Thank you, all my changes worked as I intended and all is now as it should be.
Reply 1170 of 1172, by Twisted Six
red-ray wrote on 2026-03-02, 20:43:
Here ya go.
No problem. I have a lot of weird & rare dual CPU retro rigs....if one of mine shows up and you need the dumps, just sing out.
Reply 1171 of 1172, by red-ray
Twisted Six wrote on 2026-03-02, 22:56:
Thank you, I will look out for your posts. I still recall when I got a SIV save file from a mixed AMD Athlon + Duron MP system on 22-Feb-2006, at the time I had not realised such a setup would work, I sill have the save file and running SIV in test mode it reports as below, unfortunately a lot of what SIV would now report is absent from the file, such as the disk drive temperatures and DIMM SPD data.
file.php?id=237603
Over the years I have been fortunate enough to be sent SIV save files from many uncommon MP systems, but never one from a Dual i486 or Dual PowerPC.
When I tried and run my Compaq W8000 with an Intel Xeon MP (Gallatin) 4MB 3.00GHz [C0] @ SL79V + Xeon MP (Gallatin) 2MB 2.70GHz [C0] @ SL79Z it failed to post, have you ever come across an asymmetric P4 Xeon?
Reply 1172 of 1172, by red-ray
I have just released SIV V5.86 Beta-08, the full list of changes is:
file.php?id=237818
