VST Midi Driver Midi Mapper
Reply 260 of 269, by Falcosoft
Zaphod Beeblebrox wrote on 2024-05-09, 20:48:
Sure! I've installed it anyways of course, seems to me that Defender with Cloud enabled detects way more false positives.
Yes, it seems it's the Cloud version that detects it falsely and of course it is not the verison that MS uses on Virustotal...
The attachment MS_AV.png is no longer available
So it is starting again. If I was not fast enough with my reporting to MS then other AV vendors that respect MS detection result take over the verdict and will flag the file as malicious.
I'm thinking that eventually I stop releasing binary versions. I'm really fed up with this antivirus nonsense that takes almost as much free time from me as development.
@Edit:
To prevent further escalation I have changed the file to the self signed version. As I said this way one more AV engine detects it as malicious (Trapmine) but it seems MS defender cloud version does not detect it falsely as a trojan anymore.
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.0
https://www.virustotal.com/gui/file/36e62c255 … 56788?nocache=1
@Edit2:
MS accepted the false positive report so I changed the attachment on the release page to the original exe.
Website, Youtube
Reply 261 of 269, by Zaphod Beeblebrox
Falcosoft wrote on 2024-05-09, 21:29:
Yes, it seems it's the Cloud version that detects it falsely and of course it is not the verison that MS uses on Virustotal... […]
Don't worry about it, MS can suck it.
"Hail the Omnissiah!"
Reply 262 of 269, by Falcosoft
VEG wrote on 2024-04-01, 14:21:
Another great update, thanks!
Does the self-signed code signing certificate actually help with anything? I doubt that it makes antivirus software happier.
I have made some experiments and the conclusive result is that Windows Defender (MS cloud protection) always respects my self-signed certificate. Some files are detected as various malwares/trojans until I sign them. The moment I sign them the same files are not detected anymore and not removed immediately.
In case of other AV engines the results are not so clear. Trapmine detects the installer exe to be malicious only when it is signed and CrowdStrike Falcon has the same tendency.
So there is no best overall solution but since Windows Defender is used much more often than e.g. Trapmine the self-signed version seems to be the better version to distribute.
Website, Youtube
Reply 263 of 269, by Falcosoft
New version 2.5.1 has been released:
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.1
Virustotal:
https://www.virustotal.com/gui/file/751e717d1 … 0b598/detection
This is mainly a hotfix release to fix a config dialog problem.
1. When you open a VSTi editor in Configuration dialog ->Configure VSTi you have to be rather fast since after 15 seconds the underlying vsthost process closes which prevents saving settings. This problem is fixed now.
2. Added displaying actual sample rate in vsthost's Info dialog.
3. Some minor fixes and enhancements.
Website, Youtube
Reply 264 of 269, by Falcosoft
A new update with some small fixes:
v2.5.2:
1. Fixed SysEx Continuation messages.
2. Fixed misleading error description in vstmidiproxy.
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.2
Virustotal:
https://www.virustotal.com/gui/file/2af08e557 … 1a4e0680e291d6b
Website, Youtube
Reply 265 of 269, by mashakos
Don't know if this is the right place to ask, but I'm trying to set up FSMP MIDI Player with vstdriver's VST Midi proxy + loopMIDI + Coolsoft MIDI Mapper and haven't quite gotten vstdriver proxy to play nice with FSMP.
After following instructions, I started with:
Creating a port named FalcomodPort in loopMIDI
ensure that loopMIDI is running
VST Midi proxy running
Set vstdriver MIDI port to "FalcomodPort" in vstdriver config MIDI tab
Result:- no audio in FSMP MIDI Player
after that I tried all of the above except:
Set vstdriver MIDI port to "VST MIDl synth Global (port A)" in vstdriver config MIDI tab
Audio now works and is being run through the proxy, but any 32ch midi is mangled with incorrect timing of instruments
Summary: in vstdriver, if I set the port to loopMIDI "FalcomodPort", no audio in FSMP. If I set port to "VST MIDl synth Global (port A)" midi file audio plays through FSMP but it's mangled. Setting port to "MIDl synth (port A)" works fine but then I lose the convenience of FSMP not needing to pause while vstdriver loads vsti plugin dll.
Reply 266 of 269, by Falcosoft
mashakos wrote on 2026-01-26, 04:07:
Don't know if this is the right place to ask, but I'm trying to set up FSMP MIDI Player with vstdriver's VST Midi proxy + loopMI […]
VST MIdi Proxy is based on LopMidi's kernel driver which does not support the needed 0xF5 port select Midi message. So multi port /32 channel Midi files do not work with either LoopMidi or VST Midi Proxy. Since LoopMidi's development seems to have been stopped and the author does not respond to messages there is not much hope of fixing left.
So for multi port Midi files you have to use the non-global ports of the VST Midi driver.
It seems you misunderstood the role of the MIDI tab. It does not set something special for VST driver.
Actually it only does what Coolsoft's Midi mapper does. That is it sets the default Midi out port for all other Midi programs that use the default port by design.
This is not relevant for FSMP at all since in FSMP you can set the desired Midi out port explicitly.
Overall in the context of FSMP I think you should always use the normal/non-global VST Midi driver ports since FSMP does not close the connection to the ports when a track playing is finished (unlike e.g. Windows Media Player) . Thus the driver stays loaded and you do not have to pause the player when you want to change plugin. In this regard everything should behave the same way as with the global proxy ports.
The global Midi proxy was mainly written for Midi players like Van Basco and WMP that close the connection after each track and thus you have to wait for loading heavy plugins before another track can be played. FSMP does not work this way.
Website, Youtube
Reply 267 of 269, by mashakos
Falcosoft wrote on 2026-01-26, 05:10:
Oh that's why I've been hitting a wall! Thank you very much for replying to my query, lovely work on the driver fork and player!
Reply 268 of 269, by Falcosoft
New version 2.6.0 has been released:
https://github.com/Falcosoft/vstdriver/releases/tag/v2.6.0
Virustotal:
https://www.virustotal.com/gui/file/33313ea54 … f749772594a1543
Added option to open/use multiple Global Proxy Ports.
Overall 8 instances so 16 ports can be started at once (A/B -> O/P).
The global proxy port names are displaying properly on system tray menu and VST dialogs as well as on the system tray tooltips.
Each global proxy instance can be set to autostart with Windows.
The attachment GlobalProxies.png is no longer available
Website, Youtube
Reply 269 of 269, by DragonSlayer
@Falcosoft: Thank you for your continued work on this project. I look forward to trying out the new version.
"There are only 10 types of people in the world; those who understand binary, and those who don't."
