VST Midi Driver Midi Mapper
Reply 260 of 278, by Falcosoft
Zaphod Beeblebrox wrote on 2024-05-09, 20:48:
Sure! I've installed it anyways of course, seems to me that Defender with Cloud enabled detects way more false positives.
Yes, it seems it's the Cloud version that detects it falsely and of course it is not the verison that MS uses on Virustotal...
The attachment MS_AV.png is no longer available
So it is starting again. If I was not fast enough with my reporting to MS then other AV vendors that respect MS detection result take over the verdict and will flag the file as malicious.
I'm thinking that eventually I stop releasing binary versions. I'm really fed up with this antivirus nonsense that takes almost as much free time from me as development.
@Edit:
To prevent further escalation I have changed the file to the self signed version. As I said this way one more AV engine detects it as malicious (Trapmine) but it seems MS defender cloud version does not detect it falsely as a trojan anymore.
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.0
https://www.virustotal.com/gui/file/36e62c255 … 56788?nocache=1
@Edit2:
MS accepted the false positive report so I changed the attachment on the release page to the original exe.
Website, Youtube
Reply 261 of 278, by Zaphod Beeblebrox
Falcosoft wrote on 2024-05-09, 21:29:
Yes, it seems it's the Cloud version that detects it falsely and of course it is not the verison that MS uses on Virustotal... […]
Don't worry about it, MS can suck it.
"Hail the Omnissiah!"
Reply 262 of 278, by Falcosoft
VEG wrote on 2024-04-01, 14:21:
Another great update, thanks!
Does the self-signed code signing certificate actually help with anything? I doubt that it makes antivirus software happier.
I have made some experiments and the conclusive result is that Windows Defender (MS cloud protection) always respects my self-signed certificate. Some files are detected as various malwares/trojans until I sign them. The moment I sign them the same files are not detected anymore and not removed immediately.
In case of other AV engines the results are not so clear. Trapmine detects the installer exe to be malicious only when it is signed and CrowdStrike Falcon has the same tendency.
So there is no best overall solution but since Windows Defender is used much more often than e.g. Trapmine the self-signed version seems to be the better version to distribute.
Website, Youtube
Reply 263 of 278, by Falcosoft
New version 2.5.1 has been released:
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.1
Virustotal:
https://www.virustotal.com/gui/file/751e717d1 … 0b598/detection
This is mainly a hotfix release to fix a config dialog problem.
1. When you open a VSTi editor in Configuration dialog ->Configure VSTi you have to be rather fast since after 15 seconds the underlying vsthost process closes which prevents saving settings. This problem is fixed now.
2. Added displaying actual sample rate in vsthost's Info dialog.
3. Some minor fixes and enhancements.
Website, Youtube
Reply 264 of 278, by Falcosoft
A new update with some small fixes:
v2.5.2:
1. Fixed SysEx Continuation messages.
2. Fixed misleading error description in vstmidiproxy.
https://github.com/Falcosoft/vstdriver/releases/tag/v2.5.2
Virustotal:
https://www.virustotal.com/gui/file/2af08e557 … 1a4e0680e291d6b
Website, Youtube
Reply 265 of 278, by mashakos
Don't know if this is the right place to ask, but I'm trying to set up FSMP MIDI Player with vstdriver's VST Midi proxy + loopMIDI + Coolsoft MIDI Mapper and haven't quite gotten vstdriver proxy to play nice with FSMP.
After following instructions, I started with:
Creating a port named FalcomodPort in loopMIDI
ensure that loopMIDI is running
VST Midi proxy running
Set vstdriver MIDI port to "FalcomodPort" in vstdriver config MIDI tab
Result:- no audio in FSMP MIDI Player
after that I tried all of the above except:
Set vstdriver MIDI port to "VST MIDl synth Global (port A)" in vstdriver config MIDI tab
Audio now works and is being run through the proxy, but any 32ch midi is mangled with incorrect timing of instruments
Summary: in vstdriver, if I set the port to loopMIDI "FalcomodPort", no audio in FSMP. If I set port to "VST MIDl synth Global (port A)" midi file audio plays through FSMP but it's mangled. Setting port to "MIDl synth (port A)" works fine but then I lose the convenience of FSMP not needing to pause while vstdriver loads vsti plugin dll.
Reply 266 of 278, by Falcosoft
mashakos wrote on 2026-01-26, 04:07:
Don't know if this is the right place to ask, but I'm trying to set up FSMP MIDI Player with vstdriver's VST Midi proxy + loopMI […]
VST MIdi Proxy is based on LopMidi's kernel driver which does not support the needed 0xF5 port select Midi message. So multi port /32 channel Midi files do not work with either LoopMidi or VST Midi Proxy. Since LoopMidi's development seems to have been stopped and the author does not respond to messages there is not much hope of fixing left.
So for multi port Midi files you have to use the non-global ports of the VST Midi driver.
It seems you misunderstood the role of the MIDI tab. It does not set something special for VST driver.
Actually it only does what Coolsoft's Midi mapper does. That is it sets the default Midi out port for all other Midi programs that use the default port by design.
This is not relevant for FSMP at all since in FSMP you can set the desired Midi out port explicitly.
Overall in the context of FSMP I think you should always use the normal/non-global VST Midi driver ports since FSMP does not close the connection to the ports when a track playing is finished (unlike e.g. Windows Media Player) . Thus the driver stays loaded and you do not have to pause the player when you want to change plugin. In this regard everything should behave the same way as with the global proxy ports.
The global Midi proxy was mainly written for Midi players like Van Basco and WMP that close the connection after each track and thus you have to wait for loading heavy plugins before another track can be played. FSMP does not work this way.
Website, Youtube
Reply 267 of 278, by mashakos
Falcosoft wrote on 2026-01-26, 05:10:
Oh that's why I've been hitting a wall! Thank you very much for replying to my query, lovely work on the driver fork and player!
Reply 268 of 278, by Falcosoft
New version 2.6.0 has been released:
https://github.com/Falcosoft/vstdriver/releases/tag/v2.6.0
Virustotal:
https://www.virustotal.com/gui/file/33313ea54 … f749772594a1543
Added option to open/use multiple Global Proxy Ports.
Overall 8 instances so 16 ports can be started at once (A/B -> O/P).
The global proxy port names are displaying properly on system tray menu and VST dialogs as well as on the system tray tooltips.
Each global proxy instance can be set to autostart with Windows.
The attachment GlobalProxies.png is no longer available
Website, Youtube
Reply 269 of 278, by DragonSlayer
@Falcosoft: Thank you for your continued work on this project. I look forward to trying out the new version.
"There are only 10 types of people in the world; those who understand binary, and those who don't."
Reply 270 of 278, by Falcosoft
Important info about VST Midi Driver's compatibility with the new Win 11+ Midi 2.0 service stack.
The good news is that the new Midi 2.0 service does not completely kill VST Midi Driver 😀
But:
1. After the new Midi 2.0 service stack is activated all drivers that are not kernel streaming drivers disappear. This includes VST Midi Driver, Coolsoft's VMS, The Munt driver etc. You have to reinstall all of them.
This is because the new Midi 2.0 service deletes all midi(1-9) keys from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32 and adds the new wdmaud2.drv driver as midi1 key. The default midi key stays wdmaud.drv.
From the software Midi ports that retro users usually use only LoopMidi stays intact since it's a kernel streaming driver and thus it does not require a separate midi(1-9) entry in the registry.
2. But even LoopMidi does not work properly anymore after the new Midi 2.0 service stack is activated. Only those LoopMidi ports are discovered that are instantiated before the Midi 2.0 service (midisrv) starts. Since the service starts early this means that none of the dynamically added ports are discovered by default 🙁
This bug also affects the VstMidiProxy component of VST Midi Driver since it uses the teVirtualMidi component that LoopMidi is also based on.
The current workaround is to stop and restart the Midi 2.0 service after a port is added or removed by VstMidiProxy (or LoopMidi).
Here you can follow the MS announcement about this and other bugs:
https://devblogs.microsoft.com/windows-music- … nd-workarounds/
On Github you can find the bug report of this problem here:
https://github.com/microsoft/MIDI/issues/835
3. There is an unsupported way to disable the new Midi 2.0 stack completely so everything can work as before. For this you have to download ViVeTool from Github and use the following command:
ViVeTool.exe /disable /id:58988972
(https://github.com/thebookisclosed/ViVe/releases)
BTW, I have made a package for advanced users that contains cmd files to restart the Midi 2.0 service as well as scripts to disable/re-enable the Midi 2.0 stack. All cmd files require administrator privileges!
The attachment Midi2_Fixes.zip is no longer available
Website, Youtube
Reply 271 of 278, by Falcosoft
Support my feature request on the Github repo of the new Midi 2.0 services to bring back the classic Midi Mapper 😀
https://github.com/microsoft/MIDI/issues/916
Ps: Please, do not make me disappointed. This whole topic started as a complain about how sad that MS killed Midi mapper and then through pages someone argued that how sad that Midi is absolutely dead on Windows.
Now it seems someone is dedicated from MS to develop Midi software at the OS level. Let's signal to him that this problem interests many, not just a single man from the previous century...
More comments/likes in that topic can strengthen this.
Website, Youtube
Reply 272 of 278, by MusicallyInspired
I've been chatting with one of the MS engineers working to fix all the MIDI issues in Win11. There's an official Discord server where you could download a fix when everything was broken last month. I also submitted a bug report where it disallows MIDI-OX from sending any Sysex messages that he wasn't aware of that nobody had run into yet. I also requested a "MIDI scratchpad" feature similar to MIDI-OX's to put into the new Win11 MIDI tool you can download and he implemented that as well. He's very helpful and also receptive to feedback and suggestions.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
Reply 273 of 278, by Trelokk
Great news!
In the meantime: I was wondering if something could be done to make the existing Nuked-SC55-CLAP plugin work with the existing VST MIDI Driver. It's probably an entirely different format and therefore a complete nonsense idea. Just asking since I have doubts anybody will create a functional SC-55 VSTi plugin for this any time soon. Therefore it'd be nice if we were able to just work with what we have right now. What's great is that DOSBox-Staging already supports the CLAP solution in its latest 0.83 alpha branch. A Windows version however still remains a dream.
If native support isn't possible, maybe utilizing a wrapper like this one could be a solution?
Reply 274 of 278, by Falcosoft
Trelokk wrote on 2026-05-14, 11:39:
Great news!
1.Yep, CLAP is a completely different format so hosting it would require a completely new host component.
2. That wrapper is VST 3 only. So using it would require a completely new CLAP to VST 2 part.
IMHO, neither is worth the effort for just one plugin (at least not my effort).
Website, Youtube
Reply 275 of 278, by Falcosoft
Great news!
It seems that Element plugin from Kushview supports hosting CLAP plugins and it also has a VST 2 instrument form:
https://kushview.net/element/download/
@Edit:
It seems CLAP is only supported from Element 1.0.0b1 and from the above download link you can only download an older version (v0.46.6):
But here you can find also the newer ones:
https://github.com/kushview/element/releases
Website, Youtube
Reply 276 of 278, by Falcosoft
MusicallyInspired wrote on 2026-05-11, 03:38:
In our 'Restore legacy Midi Mapper' case he is not that much helpful (Pete Brown AKA Psychlist1972 ). Not even a single comment from him so far:
Website, Youtube
Reply 277 of 278, by RetroGamer4Ever
I'm holding off on migrating my main machines to Windows 11 as long as I can, so I can enjoy the MIDI goodness that I already have configured and available in Windows 10, so I can and must be patient enough to let the devs hammer out this new MIDI stack, with the features I need and want.
Reply 278 of 278, by MusicallyInspired
Falcosoft wrote on 2026-05-14, 14:32:
Yeah that's him. He's very active on the Discord server. I suggest trying to communicate with him there.
MuntVSTi Editor
FB-01 tools
Github
SC-55 Packs
