Reply 40 of 46, by Acidmonkey
Can someone help me with this SMD resistor? On mine mainboard is broken or missing i need to know what resistor i need to put here...
ty
Reply 41 of 46, by nickles rust
Acidmonkey wrote on 2026-02-28, 15:29:
How you put voltage to lower then 2.5v? For this AMD cpu i need 2.0 or max 2.1v no??
Right. The little linear regulators on this board will not be adequate to power the later AMD CPUs. I would suggest one of the aftermarket voltage converters or DIY VRM projects. There are many threads here about doing this. For example:
www.vogons.org/viewtopic.php?t=86611
I think that component is a bypass capacitor (for that nearby IC). Note the "BC1" label. It is probably not required, but you can replace it with nearly any similar cap from a scrap board.
Reply 42 of 46, by Acidmonkey
nickles rust wrote on 2026-02-28, 16:14:
Right. The little linear regulators on this board will not be adequate to power the later AMD CPUs. I would suggest one of the […]
Ty for answer. MB is working i was just wondering is this component is affecting MB for working properly.
I just found this cpu so its two voltage on it...
Reply 43 of 46, by Acidmonkey
i just check and i have 4.3v only on pin 40 close to this missing smd. And on datasheet say that shoud be 5v. So probably i need to put this smd....
Reply 44 of 46, by Nexxen
Acidmonkey wrote on 2026-02-28, 16:33:
At this point you should probably start a new dedicated thread.
More visibility and more help.
You will be able to ask more questions and post more pics 😀 + I'm interested in the developments.
New is "more" 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 45 of 46, by Acidmonkey
I install this bios and now i dont see anymore my HDD. Get stuck on detecting IDE Primary Master.. F4 also dont work ctrl-alt-del yes and also del y can go instide in bios but hdd dont want to detect....before flash hdd was working normaly
Reply 46 of 46, by Chkcpu
Acidmonkey wrote on 2026-02-28, 18:27:
Hi Acidmonkey,
Welcome to Vogons.
This 12/07/1998S BIOS you flashed is limited to 32GB HDDs. Are you using a larger drive? This would explain the hang at detecting the drive.
I don’t know which BIOS you used before, but the only M520/M530 BIOS with 128GiB/137GB support I know is the M520_J2 BIOS, patched by me. 😉
At https://theretroweb.com/motherboards/s/pcchips-m520 it is the 10th BIOS in the list with the Note “Modded by Jan Steunebrink”.
I hope you can still boot from floppy and are able to re-flash the BIOS. Or use a bootdisk of 32GB or smaller.
Greetings, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
