Reply 20 of 29, by NeoG_
SScorpio wrote on 2026-02-25, 23:14:Just any other sound card will work, you don't need a hard that's hardwired for MIDI. A second cheap SB, or a YMF, etc also work. Something that supports PnP to make configuration with Unisound can simplify things.
I like the PicoGUS because it can be set to be a simple port listener without IRQ or DMA, I'm not sure if other sound cards can enable the MIDI port without also taking a bunch of unnecessary resources
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
