Duke Nukem 3D - General Midi Problem.
Reply 20 of 35, by NeoG_
SScorpio wrote on 2026-02-25, 23:14:
Just any other sound card will work, you don't need a hard that's hardwired for MIDI. A second cheap SB, or a YMF, etc also work. Something that supports PnP to make configuration with Unisound can simplify things.
I like the PicoGUS because it can be set to be a simple port listener without IRQ or DMA, I'm not sure if other sound cards can enable the MIDI port without also taking a bunch of unnecessary resources
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 21 of 35, by SScorpio
NeoG_ wrote on 2026-02-25, 23:25:
I also have a PicoGUS. Prior to getting one I ran a SB16 and YMF719 card. Using Unisound you can initialize individual pieces of the cards. So you can enable just port 330 for the MPU401 0n one of the cards and nothing else and only that part of the card is operating at that time.
Reply 22 of 35, by jh80
SScorpio wrote on 2026-02-26, 01:11:
Yes, this is exactly what I use now and it works great. Unisound is a godsend.
Reply 23 of 35, by NeoG_
jh80 wrote on 2026-02-26, 04:53:
Out of curiosity does your YMF card have an issue with Sam & Max MIDI music as described here?
Sam & Max Hit the Road, SC-55 hanging note bug, and Intelligent MPU-401
Reply 24 of 35, by jh80
NeoG_ wrote on 2026-02-26, 07:14:
I just checked it. I'll reply in that thread.
Reply 25 of 35, by mtest001
Thanks to both of you for the confirmation.
Is this true for any card or some do better than others?
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 26 of 35, by TheMLGladiator
mtest001 wrote on 2026-02-26, 13:58:
I ultimately opted to pair my AWE64 (for digital sound) with a Vortex 2 (for MIDI with external synth). The pros of this setup are that it works well on ACPI enabled systems where IRQ 2/9 is not readily available. The downside is when rebooting into MS-DOS mode the Vortex 2 needs a TSR to be loaded. Under Windows everything works great. Also, don't use PCI cards for digital sound in Duke3D, it will crash in many areas of the game.
Reply 27 of 35, by NeoG_
ESS does flawless digital FX and MPU-401 but will be limited to 22khz stereo in DOS games on account of supporting the SB Pro profile and not the SB16 profile. But your AWE card can already do that so that doesn't help. CMI seems to have a SB16/44Khz Stereo compatible card that does simultaneous MPU-401 and SB16 emulation but I haven't tried it myself.
YMF cards are in the same camp as ESS supporting SB Pro profile for DOS games.
The bottom line is that if you want 44Khz Stereo mixing in DOS games and simultaneous MPU-401, having an SB16 with a second card is the most stable solution. But it does require you have two ISA slots.
Reply 28 of 35, by mtest001
Thanks for the answers. I have one Ess-1868 card laying around (Formosa MPB-000050), I'll try to pair it with my SB32 PnP and see if this works well... Any advice regarding which card to assign to playing only the MIDI and which card for the rest?
Reply 29 of 35, by TheMLGladiator
mtest001 wrote on 2026-03-03, 14:28:
I guess it really depends on the game more than anything. The ESS card has better sounding FM than the CQM found on the SB32 PnP. Games that suffer from the single-cycle DMA clicking bug on the SB32 won't have this issue on the ESS. For games like Duke 3D that properly support the Sound Blaster 16 (and greater) for digital sound the SB32 PnP is the better choice. Honestly I would set the ESS up with IRQ7 DMA1 HDMA5 and the SB32 with something else.
Reply 30 of 35, by megatron-uk
Honestly, just use the ESS. For 99.9% of DOS games it's going to be the better option, or at least no worse quality than SB16 - there are not many games which actually use 16bit samples.
https://www.target-earth.net
Reply 31 of 35, by mtest001
Thanks again, I'll try that.
Reply 32 of 35, by RetroGamer4Ever
Slap this on your ESS card and you won't have to bother with the SC-55 module, as you'll get onboard GS-compliant MIDI for those old DOS games.
https://www.serdashop.com/X2GS-TE
Reply 33 of 35, by mtest001
Thanks and yes I know, but I love my SC55 !
Reply 34 of 35, by mtest001
Just one quick question: is the problem the same when using a wavetable attached to the card ?
Reply 35 of 35, by NeoG_
mtest001 wrote on Yesterday, 21:09:
Yes, the wavetable header and the MIDI output on the rear are essentially the same signal
