Advice on bigger HDDs beyond 128GB
Reply 60 of 169, by DustyShinigami
wierd_w wrote on 2026-03-13, 12:32:
If the old version of ontrack is still on there, the ddo installer will detect it. […]
DustyShinigami wrote on 2026-03-13, 00:50:
Nope. This isn't happening. The latest version sure is nice and user friendly as it goes through all the different steps, but the Dynamic Drive Overlay options are greyed out. I'm guessing that's what's needed to fool the BIOS...?
Try running DM in Manual mode, by running it from the command line with the /m argument.
More knobs will be available, including options to reconfigure, remove, or upgrade the existing ddo data.
Oh. Cool. Had no idea. Thing is, aren't the Ontrack files only added to a RAM disk temporarily? Apart from that it's been loaded either from an image on my Gotek pen drive or a floppy disk. Also, as I mentioned above, I seem to have problems running it from a command line via the image. Particularly 10.46.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 61 of 169, by douglar
DustyShinigami wrote on 2026-03-11, 23:24:
I think the BIOSes are upgraded to their latest version. The one for the HighPoint Technologies IDE controller is 1.25 or 1.26. And the BIOS is BEH-70 from 2001, I believe.
Could you post a picture of the HighPoint Technologies IDE controller ?
Reply 62 of 169, by DustyShinigami
douglar wrote on 2026-03-13, 13:13:
On the motherboard? Ooh, now you're asking... I'll have to see if I can figure out where it is. ^^;
EDIT: Ah, actually, not difficult at all thanks to the diagram on The Retro Web.
The attachment IMG_5414[1].JPG is no longer available
OS: Windows 98 SE
Reply 63 of 169, by DustyShinigami
Yeah, I'm having no luck doing this with 10.46. On boot, it extracts the DMZIP1.EXE to a RAM disk. Trying to run or extract it manually, nothing. Can't get it to work. Even with the /m switch. I can try 9.57 and see if it does it, but it's 10.46 I need apparently.
OS: Windows 98 SE
Reply 64 of 169, by DustyShinigami
Yep. Nothing doing. 9.57 will let me initialise with the /m switch, but it still won’t let me add or remove any Dynamic Overlay or says none exist. The Hitachi version is the same and 10.46 won’t let me either, but nor will it let me initialise it manually with any switches. I’ve tried /m, /c, and /n. It gets to ‘inflating DM.exe’ but then says ‘disk full’. 🤷🏻‍♂️
OS: Windows 98 SE
Reply 65 of 169, by wierd_w
'Get creative'.
Modify the autoexec of the floppy.
Let it extract as per normal. Where it calls dm.exe from the ramdisk, throw the flag on the end.
More than one way to skin that cat.
I may create a video on advanced functions of ontrack using a virtual machine this weekend.
In the meantime, I'd just suggest dd-ing 4mb of zeros to the front of the disk then trying again, or something similarly brutal.
Reply 66 of 169, by DustyShinigami
wierd_w wrote on 2026-03-13, 20:30:
'Get creative'. […]
'Get creative'.
A nice idea, but I'm not even sure how I'd go about it or what I would need to add. Opening up the autoexec, all it has is this:
@echo off
cls
cd a:\
findrdsk VDISK
echo Please remove the CD and/or Floppy Diskette
echo Press Ctrl-Alt-Del to reboot your system
I've tried the same command when trying to initialise it manually - findrdsk vdisk or trying to load findrdsk.exe and nothing happens.
OS: Windows 98 SE
Reply 67 of 169, by wierd_w
I will look into it more closely when I go home today.
Reply 68 of 169, by DustyShinigami
Okay. Thanks. 😀
OS: Windows 98 SE
Reply 69 of 169, by DustyShinigami
I think in the meantime, I'll order myself one of those ATA133 PCI controllers, so at least I've got something to fall back onto if all else fails.
OS: Windows 98 SE
Reply 70 of 169, by douglar
DustyShinigami wrote on 2026-03-14, 17:04:
The Promise S150 and Ultra133 are best. Promise cards that support ATA100 or 133 have the BIOS & Controller in a single chip package & are most compatible. Maxtor branded cards are promise cards. The Ultra 100 cards can be upgraded to support LBA48 by flashing the 2003 firmware to the card.
Cards with Silicon Image chips like the Adaptec ASH-1233 have always worked OK for me, and Phil likes them too, but other people have reported issues.
If you get a card that's not a Promise card, make sure you see a BIOS chip on it.
Here's an example of a card without a BIOS:
https://theretroweb.com/expansioncards/s/high … int-rocket-133s
Here's the same card with a BIOS:
https://theretroweb.com/expansioncards/s/high … nt-rocket-133sb
I'd avoid Via based cards unless they are free or close to free. And even then they might not be worth the effort.
I don't have a lot of experience with Highpoint or ITE based cards.
Reply 71 of 169, by DustyShinigami
douglar wrote on 2026-03-14, 18:40:
The Promise S150 and Ultra133 are best. Promise cards that support ATA100 or 133 have the BIOS & Controller in a single chip pa […]
Thanks for the heads up. 😄 I ended up ordering a Silicon Image one. At least, it looks to be based on the model on the box. It’s old stock that’s technically new. It was only £8-11. But here’s hoping I don’t run into issues. It’s this:
https://ebay.us/m/ZChY44
OS: Windows 98 SE
Reply 72 of 169, by douglar
DustyShinigami wrote on 2026-03-14, 18:49:
You sure about that?
The attachment Untitled.png is no longer available
Please post a picture of it when it arrives. Very curious to see what you get.
Reply 73 of 169, by DustyShinigami
douglar wrote on 2026-03-14, 19:04:
You sure about that? […]
Oh no. Have I gone and bought an unknown brand? 😕
OS: Windows 98 SE
Reply 74 of 169, by douglar
DustyShinigami wrote on 2026-03-14, 19:35:
It's probable one of these two:
https://theretroweb.com/expansioncards/s/star … ch-pciide2-8211
https://theretroweb.com/expansioncards/s/startech-pciide2
Reply 75 of 169, by DustyShinigami
Nearly a week later, it finally arrived. And yeah, it's an ITE. I just hope it does the job.
The attachment IMG_5422[1].JPG is no longer available
OS: Windows 98 SE
Reply 76 of 169, by DustyShinigami
Hmm. Unsurprisingly, it doesn't appear to be working. Unless I'm missing a crucial step...? I plugged the card in, the PC didn't detect any hardware changes. Connected the HDD to it and then it did. I've installed the drivers for it, I get a prompt on boot, which I would love to disable somehow as it doesn't carry on booting Windows unless I press a key to either go into the configuration utility or Esc to continue loading Windows, and I have a RAID utility in my taskbar. Both utilities seem to recognise the correct capacity of the HDD. It says around 298-300 anyway, but Windows still doesn't recognise the full amount. And I still get a BSOD if I try to run the ScanDisk. 🙁
So I'm not sure what I'm missing here.
OS: Windows 98 SE
Reply 77 of 169, by DustyShinigami
Yeah, this is all new territory for me. Never used a RAID card before, don't fully understand what they are or what use they have, I'm not sure if I need to build an array or how. I've tried doing it in the utility on boot, but I can't seem to do it. It says I need two drives and I don't even know how to do that.
OS: Windows 98 SE
Reply 78 of 169, by wierd_w
More or less, what you are missing is an lba48 capable bootrom, or equivalent.
Windows 95 will still need patching. The 32bit disk drivers it ships with are not lba48 aware.
Information can be found here:
https://rloewelectronics.com/Programs/Patch137.htm
Reply 79 of 169, by DustyShinigami
wierd_w wrote on 2026-03-19, 16:15:
More or less, what you are missing is an lba48 capable bootrom, or equivalent. […]
Surely that defeats the point of having a RAID controller card...? I thought ATA 100/133 supported LBA48 out of the box? But it's Win 98 I have and I had already installed that patch. Re-running it, it did say the HDD is 48-BIT Support Verified. And the patch is verified on boot, but it still only recognises it as 127GB in Windows. 🙁
OS: Windows 98 SE
