i think sadly trident 8900D (and other 8900 i think) have not good support for 256 colors in 286 computers. The only driver i found it work is for windows 3.0, and is terrible slow, and hava a lot of problems
In fafct, just for tetst, i build a 486 DX4 PC, plug the trident and same isa audio and CF card of 286, load windows, and windows 3.1 is same slow than in 286. Build a horrible 386 SX25mhz i have, pretty slow board, load 386 triedent drivers, and is pretty fast
For me after test everything i found, is simple, trident drivers for windows 3.1 and 286.. SUCKS
thanks for all help
Grzyb wrote on Today, 08:43:
Hi, i download the trident driver from this compilation, but sadly same as others, the "good" 640x480x256 driver need 386, and the 286 one is anciend win3.0 one, slow and full of problems
Matth79 wrote on Today, 18:31:
https://archive.org/download/trident-tvga-890 … er-disk-trident - this one is later, the TRW one readme says that some require 386, this one doesn't mention
Sadly this driver if you expand amd check TRIT640.DR_ 640x480-256C , have this text This driver ONLY can work on 386/486 machines or above..
thanks
