Anyone knows a 8900D windows 3.1 286 driver?
First post, by theelf
What title say, anyone knows a 8900D windows 3.1 286 driver?
Yes, i found 8900C windows 3.0 drivers that work on the 8900D and win3.1 but are slow, and not very compatible
I just need 640x480x8 in my 286
Thanks a lot
Reply 2 of 27, by theelf
keenmaster486 wrote on 2026-03-20, 03:21:
First three Google search results: https://theretroweb.com/drivers/150 https://vogonsdrivers.com/index.php?catid=37 https://arxv […]
https://arxvaldex.com/trident-microsystems-dr … -drivers-p-1292
none of this work on 286
Reply 3 of 27, by mkarcher
The Trident series is unaccelerated, so there is no need for Trident specific logic in the driver. The TVGA8900D is faster than the C, because they improved the pipelining of CPU writes to video memory, not because of extra capabilities offered to a Windows driver. Trident ships a BIOS extension tool called "LOCKFIFO" which can be used to configure the pipelining ("FIFO") on the TVGA8900D, which is a BIOS extension, and thus will be effective with nearly any Windows 3.1 driver, because drivers of that age use the BIOS to configure the video mode.
So, did you already try Microsofts generic "SVGA 640 x 480 256 colors" driver? If that driver works, I don't see what a TVGA8900D driver can improve over the generic one.
Reply 4 of 27, by theelf
Hi, no, generic svga driver dont work with 8900D
Like i said the only way i can get 256 colors is with a old win3.0 driver, but is not working fine, slow with color problems
Im with the hope someone have a old woking driver version, because i already download and tested every?one i found in internet
Patched svga and vesa ones need 386, i tested too
I will check LOCKFIFO tonight thanks
Reply 5 of 27, by Grzyb
There's a bunch of 286-compatible drivers attached in this post - Re: Should a Diamond Speedstar Pro (CL-GD5426) work in Win3.1 in 286 real-mode?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 7 of 27, by theelf
I think, unfortunately, the Trident 8900D (and probably other 8900 models) does not have good support for 256 colors on 286 systems. The only driver I found that works is for Windows 3.0, and it is extremely slow and has many issues.
In fact, just for testing, I built a 486 DX4 system and installed the same Trident card, the same ISA sound card, and the same CF card I use in my 286 (same Windows installation). When I loaded Windows 3.1, performance was just as slow as on the 286.
Then I assembled a 386SX-25 (a very slow board I have), installed the Trident 386 drivers, and performance was actually quite fast.
From all the testing I’ve done, my conclusion is simple: Trident Windows 3.1 drivers for 286 systems are very poor... SUCKS
Thanks for help
Grzyb wrote on 2026-03-20, 08:43:
Hi, i download the trident driver from this compilation, but sadly same as others, the "good" 640x480x256 driver need 386, and the 286 one is anciend win3.0 one, slow and full of problems
Matth79 wrote on 2026-03-20, 18:31:
https://archive.org/download/trident-tvga-890 … er-disk-trident - this one is later, the TRW one readme says that some require 386, this one doesn't mention
Sadly this driver if you expand amd check TRIT640.DR_ 640x480-256C , have this text This driver ONLY can work on 386/486 machines or above..
thanks
Reply 10 of 27, by rmay635703
Hmm, I remember someone patching a Win 3.11 driver from 32bit 3.1 to have 16 bit support, gotta wonder
https://winworldpc.com/product/generic-svga-d … iver-windows-31
https://wuffs.org/blog/windows-3x-graphics
wierd_w wrote on 2026-03-22, 22:25:
Why not use the generic VBE driver?
Trident should have offered a VBE TSR for that card. If not, there's always SDD.
I don’t think anyone has patched VBE to work on 286+ Win3.1 (all 386+)
https://github.com/PluMGMK/vbesvga.drv
Only example targeting 286…
https://forum.vcfed.org/index.php?threads/ibm … -1.29377/page-6
Didn’t appear to help outside DOS
And the 286 specific drivers seemed to stop with 3.0 for some reason
download/file.php?id=115670
Now if the op wanted to run 2.11
https://www.seasip.info/DOS/Win1/win2vesa.html
Reply 12 of 27, by theelf
Why not use the generic VBE driver? https://github.com/PluMGMK/vbesvga.drv […]
I see a VBE 1.0 TSR here?
http://www.win3x.org/win3board/viewtopic.php? … =27758&view=min
Hi, generic VBE driver need 386+ thanks
Reply 13 of 27, by wierd_w
Seems a bit odd that it needs 386+... huh.
Reply 14 of 27, by theelf
wierd_w wrote on 2026-03-22, 23:00:
Yes I think same, because in readme say
vbesvga.drv (needed in both Standard and 386 Enhanced Mode, and on Windows 9x) […]
- Install both the Win16 DDK and a contemporary version of Visual C++
- Obtain a copy of EXE2BIN.EXE (e.g. from FreeDOS, or from the Open
Watcom compiler) and place it somewhere in your PATH
- Place the VBESVGA folder from this repository in the DDK hierarchy, at
286/DISPLAY/8PLANE/VBESVGA
- Ensure MSVCVARS.BAT from Visual C++ has been run to setup the
environment
- In addition, ensure 286\TOOLS from the DDK is in your PATH and 286\INC
is in your INCLUDE variable
- Go to the VBESVGA\mak folder and run make vbesvga.mak; this should
create the file VBESVGA.DRV which can be loaded by Windows
vddvbe.386 (needed only in 386 Enhanced Mode, and on Windows 9x)
- Place the VDDVBE folder from this repository in the DDK hierarchy, at
386/VDDVBE
environment
- In addition, ensure 386\TOOLS from the DDK is in your PATH
- Go to the VDDVBE folder and run nmake; this should create the file
VDDVBE.386 which can be loaded by Windows
vbevmdib.3gr (needed only in 386 Enhanced Mode for running graphical DOS programs in windowed mode, not needed on Windows 9x)
- Place the VBEGRAB folder from this repository in the DDK hierarchy, at
386/VBEGRAB
environment
- Go to the VBEGRAB folder and run nmake; this should create the file
VBEVMDIB.3GR which can be loaded by Windows
look like will work fine in standard mode, but when i tried to load windows always hang with th driver. Or maybe need vesa 2.0 or LFB I dont know
Reply 15 of 27, by wierd_w
Maybe it uses 386 exclusive instructions?
I just am not sure why that would be explicitly necessary.
Reply 16 of 27, by theelf
wierd_w wrote on 2026-03-22, 23:14:
ok, sorry, my fault, i tested again, and NO, you right work in 286, i believe was not working because after windows 3.1 boot logo disapear and screen goes to black, windows desktop never appears... and then i reset computer. This time, i just left there, and after 3 minutes, windows desktop appear!!! redraw a windows when i move take like 10 seconds... jeje
Work! sadly is not very usable, but thanks! i believe need 386 because black screen, it was just loading?¿ or drawing desktop... 😀
Reply 17 of 27, by wierd_w
I... have no idea if it will work with that old of a card... but there is a 'maybe it will work' driver here?
https://files.mpoli.fi/hardware/DISPLAY/TRIDENT/
'TRIWIN31.ZIP'
The readme inside gives this:
MS Windows 3.1 TRIDENT TVGA Drivers =================================== (UC5.1 11/93) […]
(UC5.1 11/93)
This diskette contains these high-resolution drivers for Windows 3.1:
TRIW1024.DRV -- 1024x768-16C Large Font
TRIT640.DRV -- 640X480-256C
TRIT800.DRV -- 800X600-256C
TRIT1024.DRV -- 1024X768-256C
TRIT8005.DRV -- 800X600-256C (512K DRAM required)
TRIH640.DRV -- 640x480-32768C (386 CPU & 1M DRAM required)
TRIX640.DRV -- 640x480-65536C (386 CPU & 1M DRAM required)
TRIH800.DRV -- 800X600-32768C (386 CPU & 1M DRAM required)
TRIX800.DRV -- 800X600-65536C (386 CPU & 1M DRAM required)
With a specific mention that only the highcolor modes need 386+ cpus.
Reply 18 of 27, by theelf
wierd_w wrote on 2026-03-22, 23:36:
I... have no idea if it will work with that old of a card... but there is a 'maybe it will work' driver here? […]
'TRIWIN31.ZIP'
(UC5.1 11/93)
Hi thanks i already tried that one too. I think almost all packages have same 8bit windows 3.0 driver for real mode, trident just update the enhaced mode
The problem of 3.0 driver is that is slow as hell,too much, and have some problem with palette
Reply 19 of 27, by wierd_w
Stupid question, but are you sure you arent hitting the 'ISA BUS is too slow' problem?
What is the ISA CLK of this system?
