First post, by Shadic95
Hi, it's me again.
I'm sure some set of users is sick and tired of me constantly posting, but lord, the world of old machines is a headache.
To reiterate, my specs are here, before anything else:
Motherboard: Intel D815EEA
CPU: Intel Pentium 3 866MHz
RAM: 133mhz 512mb (I currently have only 2 matching 128mb sticks, but I've bought a very similar 256mb stick with IBM and hynix (like my existing sticks), so all three ram slots will be filled for 512mb of ram, the max the machine can use)
GPU: NVIDIA GeForce FX 5200 VCGFX522APB (new sealed in box)
Sound Card: Aureal AU8830 Vortex 2 BA88ST30A-01 (and I have an original Audigy coming in the mail, which I seek to add in as well)
Ethernet: For now, the onboard Ethernet, but I have an st1000bt32 coming in the mail
Storage: CF2IDE and some SD2IDE thing. Also a DVD writer thing, and a gotek USB floppy emulator
Additional: some USB card with an NEC chip that can work in windows 98
PSU: Corsair RM750e
Now, the problem on hand... NVIDIA drivers of all generation are hot garbage (at least for 9x), and I kinda want away from NVIDIA cards at all costs, at this point. Whether it's needing to be installed twice to not have weird page fault errors when opening stuff like HxD, or LEGO Rock Raiders causing DDHelp errors when you exit the game, and then re-opening the game causes a crash, and the whole system to freeze up... This has happened with a RIVA TNT on another system, and this FX 5200, I might add! And also stupid stuff like it getting rid of the new item context entry from the right click menu... These cards are just extremely awful with their driver support, and I am done with them.
Now, I know the Voodoo's would be cool and such, but we all know that those are Raritanium, and getting what would suit this build the best, a Voodoo 5, is just... not going to happen, because even if I *did* save 1000$+, who is to say any listings would be left by the time I even have that money. So that really only leaves... Matrox and ATI, I guess??? Not considering the Savage as an option here, because it gives garbled 3D in a lot of games, from my experience using a Diamond Stealth S540 PCI. Oh, and palletized textures and fog table support is a must, but that I suppose is a given the OS that this machine is primarily using. and my limit is 400$ for a GPU, because I've already spent so much time and money on this dang thing.
I *was* eyeballing a Radeon 9800 Pro for a maybe one day Pentium 4 build, but at this point, maybe I might consider it for this Pentium 3 machine. However, I do not know if it supports palletized textures and fog tables, plus, I don't know how the driver support is like, as I would be using Windows 98SE, and Windows 2000SP4. Would this card do just fine, or should I look elsewhere? I am SO sorry for my tone, but like... I am just bewildered by how bad these NVIDIA cards are with their driver support, and just badly want something that won't have 5000 issues, and will have the features I want. Any and all help is deeply appreciated. Thank you.
EDIT:
Since someone will ask, for the FX card, I was using driver 56.64, and for the RIVA TNT card, 44.03. Considering how the same DDHelp issue happened on both cards, and with different drivers, I am convinced all NVIDIA drivers are bad, and I am not interested in being convinced otherwise, unless there is some weird fan project I don't know of, which magically fixes everything. Even then, I'd still prefer to just, never use these cards for retro builds, ever again.
Reply 1 of 22, by Trashbytes
Hmm with a P3 866 your choice of non nvidia GPUs are limited but a Radeon 9600XT AGP wouldn't hurt if you don't have an issue with leaving GPU performance on the floor due to the slower 866 P3, they tend to be on the cheaper side as they don't die that easily so plenty are around. (Avoid the 9700 Pro, 9800 Pro or 9600 Pro, they are the older ones with the inadequate cooler and have a track record of being DOA, the XT cards are the newer refresh models with better coolers and temp sensors)
You could also grab the ATI Cockroach the Radeon 9250 AGP, there are plenty around so make sure you get a 128bit bus version or grab a Radeon 9500 if you want a little more than the 9250.
If you want some flair you could grab a Matrox Parahelia 256 AGP but they are neither cheap or easy to get but I have one and its a cool card.
As for fog tables and palletised texture there are people here that are far more knowledgeable than me on which ATI cards can handle this and which drivers are needed.
Reply 2 of 22, by Shadic95
Trashbytes wrote on Yesterday, 15:42:
I feel like I was probably limiting performance with the FX Card anyways, due to the CPU, so like, I'm fine if that happens to be the case again. Any idea if they support palletized textures and fog tables? Also, thanks for the warning on the cards to avoid. I wouldn't have known, otherwise.
Reply 3 of 22, by Fish3r
A lower end card from the Radeon 9000 series could be an option if you want something cheap but I'm pretty sure those don't support table fog.
Have you looked at voodoo 3s? They're not as bad as the 5s price-wise and fast enough for 98se games. I'd only avoid them if you're looking at playing games from 2001 onwards. Up to then they're generally ok.
Reply 4 of 22, by Trashbytes
Shadic95 wrote on Yesterday, 15:46:
For support I'm sure one of the experts here on such things will chime in, I know ATI does support them but only with some drivers and not with others so you will need to wait for them to post.
There have been plenty of discussion on the topic, so searching Vogons may get you to the right thread.
Reply 5 of 22, by Shagittarius
If you think Nvidia 9x drivers are hot garbage wait till you go ATI.
Ati really improved their drivers during the xp and 9x00 period, but for the prior period ati was notorious for bad drivers. It was one of the many reasons to go Nvidia.
However stick to the 9x00 hardware and appropriate drivers and you shouldn't have any problems.
Reply 6 of 22, by Shadic95
Fish3r wrote on Yesterday, 15:47:
Hm... Not sure. I used to have a Voodoo 3 PCI at some point, and I did like that card. I feel like it fit the Pentium 2 300MHz build it was in, but for a much more powerful machine, I am not sure. Games like LEGO Rock Raiders are super GPU heavy, and I do not believe the Voodoo 3 would handle it well. Plus, support for some newer games like Sonic Adventure DX, and some other games up to around... 2004? Would be nice. That's what made the GeForce FX 5200 so appealing, as it seemed like a dream card that could handle the old games fine, while having barely enough juice for those somewhat newer games. If it wasn't for it's awful driver support, I would keep sticking with this card.
Also, bummer. I don't know how many games rely on fog tables, but I feel like for the sake of compatibility, a GPU I get should be able to support it.
Shagittarius wrote on Yesterday, 15:50:
Ati really improved their drivers during the xp and 9x00 period, but for the prior period ati was notorious for bad drivers. It was one of the many reasons to go nvidia.
...So it's bad there, too? Does that really mean Matrox and Voodoo are the only good options without bad drivers? Jeez, what a mess... I *really* don't want to pay the insane prices of the Voodoo, but maybe I have to, if the news with Matrox cards is also not good...
This was added after I made my post... well, I guess it's not entirely off the table, even if the lack of fog table support is unfortunate.
Reply 7 of 22, by Shagittarius
No sorry I had to clarify for you I think you will do well with the ati 9x00 series. I just hope the problem isn't more related to your system or config because it would suck to have issues with the ati card too.
I use a 9800pro in my 98 machine. I had issues back in the day with incompatibility with the 9700pro but that was fixed with the 9800.
Reply 8 of 22, by Shadic95
Shagittarius wrote on Yesterday, 15:56:
No sorry I had to clarify for you I think you Wil do well with the qti 9x00 series. I just hope the problem isn't more related to your system or config because it would suck to have issues with the ati card too.
Yeah, I saw the added clarification after I refreshed the page. Sorry about that. I don't *think* it's an issue with my system, considering the RIVA TNT was having some of the same problems on a different system, with that one being PCI instead of AGP, I think it really is just down to driver issues.
Reply 9 of 22, by Trashbytes
One of the lucky ones with a working one !
I have two dead ones myself and a working one I resurrected, no idea how long itll live but I don't use it much, the old girl has already served her time no need to beat a dead horse 😀
Reply 10 of 22, by Shagittarius
Trashbytes wrote on Yesterday, 15:59:
Yeah that is a problem 9800pros can be risky. I've only ever owned that one but I imagine the 9600 or an x800 or x850 should still be fine and in the driver sweet-spot.
Actually I think an x850 might be cheap and reliable. Anyone have experience with them?
Edit , just looked when did x850s start going for over 200 usd?
Reply 11 of 22, by Shadic95
So... if I have the correct drivers, the Radeon 9600XT AGP *might* be okay? I really don't fully understand how needed or important fog table support is, so, if that's all I'm losing, then maybe this is the way to go? If I can get some clarification on what the best and most stable drivers are, and how bad it is to not have those features, I might just go this route, unless there is another I'm not aware of that would be good as well, without being super insanely expensive.
EDIT: Someone on Reddit ( https://www.reddit.com/r/RetroWindowsGaming/c … nt=share_button )
is suggesting that the GeForce 3 would be suitable for a Pentium 3, which is not what I would expect to read. But I am so conflicted about this, considering the driver issues I have been having. Maybe it's less bad with an older card like this? Also, Rock Raiders may just suck, since it uses Direct 3D Retained Mode, a weird thing few retail games even use. None of my other games have that weird DDHelp issue, so maybe I just suck it up, deal with the system crashing with that one game, and in theory have a good time otherwise?
EDIT 2: Aaaaaand, all of the GeForce 3's are sold outside of America. Great...
Reply 12 of 22, by Trashbytes
Shagittarius wrote on Yesterday, 16:02:
the X850 AGP was the last AGP card from ATI and as such its drivers are not that compatible with older titles and because ATI had moved to PCIe with that card it didn't get a ton of updates on 98.
Reply 14 of 22, by Shadic95
Well, I'm sort of at a crossroads here, and I don't really know what to do. In regards to the DDHelp issue, so far, that issue has only ever happened with LEGO Rock Raiders, a game that used D3DRM. Other games have worked fine, without weird crashing. And, as weird as the whole having to install the driver twice thing was, as well as the New option being removed from the right click menu is, it otherwise has been working *fine*, so... Maybe I just need to suck it up, accept the issues it does have, and be grateful it otherwise works well elsewhere?
Sorry if I've been incredibly rude or ungrateful sounding in any of this thread, just... Even knowing that 9X is just perpetually a mess of stability and such, it has been frustrating how like, the non Voodoo options all seem to have weird issues. And makes me wish all the more that those cards were at all affordable these days.
At any rate, since it was suggested in this thread, and on Reddit, that an FX5200 isn't really exactly fitting for what my machine is, is there a card that is still plentiful that would fit the machine better? If I have to sacrifice DX9 support, so be it. After reading the FX5200 drivers eat away at the CPU, I am having second thoughts about having this card in my system, and do wonder if something else would be better. I am open to NVIDIA cards again, since it seems like, otherwise, the options are just way too narrow, and the issues that do happen, aren't bad enough to exclude them entirely.
Reply 15 of 22, by Fish3r
Have you looked up fixes for rock raiders? I have a 9x machine with an FX5600 in it and there's some games where I've needed to use patches (eg. NFS:HS) to get them to work but otherwise it's fine. IIRC rock raiders also got a re-release to make it more compatible with XP and newer hardware that might solve your issues?
As for table fog & paletted textures, Geforce FX supports both (Fog is emulated, but it works fine).
I made the voodoo recommendation on the assumption you wanted to only run 90s games, but since you're talking about eg. Sonic Adventure DX then it'd probably be better to try and make what you have work before going out and buying something.
Reply 16 of 22, by Shadic95
Fish3r wrote on Yesterday, 16:44:
So those later re-releases change one thing about the game, which is, no drm. I am already using the no drm exe. The game is infamous for being hard to run on modern systems without specific patches fixing bugs with specific weapons and a dgvoodoo2 setup. It works fine on the system as is, aside from the DDHelp issue upon exiting the game and relaunching it, which I mentioned in the initial post. As much as that issue sucks, I might just have to deal with it. The reset button on my case and the fast boot times make it not the worst, even if undesirable.
I am well aware. I had read the vogons wiki and found that info, which is what informed my purchase of the card, to begin with.
Truthfully, games that new are more of a novelty on the machine, rather than a serious thing, for me. Games like Rock Raiders, UT99, and a few others that are slipping my mind, running well are what matter the most to me. Considering Rock Raiders recommends a 32MB GPU, something with at least that, and a 128 bit memory bus, seems best.
But, I suppose that may not be too important for now. As I've mentioned, aside from the DDHelp issue, and some other minor issues (which were fixed, to some extent), the card is otherwise working fine, and I might have just been making a fuss for no good reason. Unless there is a good reason to swap off it (despite possible concerns about the drivers being CPU intense?), I think I'll just stick with it, for now.
Reply 17 of 22, by Shagittarius
You are bound to find games that won't run on every config for some reason. The best you can do is maintain multiple platforms and hope that it will run on one of them. Or just say bollocks to it all and let it go.
Reply 18 of 22, by cyclone3d
What updates have you installed on the 98 machine? If you are using the unofficial service pack, then that is most likely leading to all sorts of weird issues.
The only updates you should be installing are the ones from the 2004 Microsoft update CD ISO that are available on vogonsdrivers.
Do you have the chipset drivers installed?
Have you messed with AGP aperture size or PCI latency in BIOS?
Have you run a. RAM tests ng program to make sure you aren't getting random errors from a faulty or incompatible stick of RAM?
Do you have the latest available BIOS installed on the motherboard?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 19 of 22, by swaaye
I think the OP might just be a bit unaware of how delicate Win9x is. It is very easy to crash this OS. It doesn't have the various process and memory protection techniques of NT. Any misbehaving software or drivers or incompatibilities somewhere can lead to memory corruption and that's it. That's what is crashing DDHelp. Once this happens you need to reboot or more likely, hit reset. Of course this can also corrupt files on the delicate FAT partition. The OS is also susceptible to "DLL hell" in which you can have software install older or newer versions of a particular library file that isn't compatible with some other piece of software already using it.
If you go beyond DirectX 7.0a with Win9x, that seems to be a cause of DDHelp crashes. Possibly related to VXD sound card drivers. I see you have a Aureal card and that is using VXD based drivers.
Other sources of problems can be no-cd cracks, other VXD drivers for hardware you've installed, virtual CD software.
I try to use Win2K or XP unless I have hardware that absolutely needs Win9x.
