RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3300 of 3309, by sharangad
Interstate '76 Rendering defects appear identical to original hardware:
https://youtube.com/shorts/lTvaQM2fbZo?feature=share
Not sure whether to be relieved or depressed.
(Also at 1080x1920p:
https://www.patreon.com/posts/interstate-76-1 … ntent=join_link )
ICR2 Brands Hatch is now Rendition Ready
https://youtu.be/lpezKgZwHdM
[EDIT]
Rendition Ready tracks.
Atlanta (all 3 N99, NL):
https://youtu.be/7-mM59YdC4g
Brands Hatch:
Birmingham , Alabama:
https://youtu.be/0RhCKwFyec0
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3301 of 3309, by RaVeN-05
Tested Interstate 76 w and w/o saves you gave me.
Seems something odd happened to my PC.
the SODA works good by i76 and Nitro(previously worked good)
are very buggy in terms of game logics .
cars are have randomly turning wheels all 4x4
the cars in intros are randomly drives around until they reach end point where cutscene ends.
the animations are choppy like they use below 18 fps.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3302 of 3309, by sharangad
RaVeN-05 wrote on Yesterday, 11:26:
Tested Interstate 76 w and w/o saves you gave me. Seems something odd happened to my PC. the SODA works good by i76 and Nitro(p […]
This relates to cpu timing for Ai cars, possibly involving dxwnd . I think windows update broke it. It worked perfectly in January, when I tested it last. I mean it worked perfectly after a fresh reboot.
Now it seems permanently borked. Turning off virtual machine platform and windows hypervisor platform also used to help. Perhaps @been_nath-058 could suggest something.
Reply 3303 of 3309, by Pens5919
I've been having a graphical issue with the current rLauncher build for ICR2. Are there any fixes? It seemingly scatters the colors around at random. I wish I could put the video in here.
Reply 3304 of 3309, by sharangad
Pens5919 wrote on Yesterday, 18:18:
1) Is this with icr2?
2)Also what's your GPU and how much vram have you got?
3) win10 or 11?
4) could you attach your log files here and maybe email them to support@nirvtek.com?I'm having network issues with my email, so both here and the email would be nice.
To get a zipped up copy of the logs, run the game, reproduce the problem and then quit the game. Then click the "zip log files" button in rlauncher, it's on the bottom row. This should open up a file explorer window with the zip file highlighted.
[edit]
5)also a screenshot of the rendition settings dialog in rlauncher for dosbox (click rendition settings while in the dos apps tab) would be useful.
6) Did this use to work or is this from a blank slate?
[/edit]
I'll take a look at the logs first thing tomorrow. It's a bit late in my timezone right now.
Reply 3305 of 3309, by Pens5919
This is with ICR2, I have 495mb of VRAM with AMD Radeon Graphics on a Windows 11 laptop running with a Ryzen 5 7530U CPU.
Reply 3306 of 3309, by sharangad
Pens5919 wrote on Yesterday, 23:57:
Could you also attach the log files?( The Rendition settings look OK. )There may be errors in there.
I've never tested rready against ryzen integrated gpus. The only Radeon I've tested against is an old r7 240.
Reply 3307 of 3309, by sharangad
Anyone having the same problem on Ryzen integrated graphics should be able to use this untested alpha release :
https://nirvtek.com/downloads/RReady.Alpha.20260321.001.7z
MD5: f79d0073191be6e29def15f975809917
I'm still waiting for the logs from the fixed build from Pens5915, before I head for another round of testing and a full release.
[edit] thanks, Pens5915 for the logs.
Reply 3308 of 3309, by sharangad
This does need to be fixed though.
Reply 3309 of 3309, by sharangad
https://nirvtek.com/downloads/RReady.Alpha.20260321.003.7z
MD5: 1ecadf8230440711e1bc66e1ebef537e
This should resolve all problems with Ryzen Integrated Radeons with ICR2, hopefully.
