Reply 31000 of 31544, by MattRocks
giantenemycat wrote on 2026-03-22, 21:18:
Have set up two contenders for my alternate-timeline-2006-second-hand-cheapo-PC. […]
The attachment dubious.jpg is no longer available
The MESH has an ASUS A7V-E - Socket A (VIA KT133). Athlon 1100, 256MB SDRAM.
On the right in that lovely tacky case, we have a Gigabyte GA-8SIMLH - Socket 478 (SiS 651). Pentium 4 2.0 (Northwood), 512MB DDR (in single-channel for the jank).
Which would you pick?
I'd put the AMD in the blue case 😉
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
Reply 31001 of 31544, by DaveDDS
Looked through my boxes of IC tubes, for a 6264 (8k SRAM), lots of 62256s (32k) but no 6264s! Then I "remembered" the "long forgotten" boxes of ICs in a back corned of my workshop and went through then... found 5 6264s (yay!) but also a some other pretty interesting old ICs:
Several 2016 (2k SRAM) and 5516 (2k CMOS SRAM)
2x 486 CPUs - I didn't think I had any x86 prior to Pentium anymore!
3x 8080, 2x 8085, and 2x Z80 CPUs
4x 68000 CPUs (original 64pin DIPs)
1x 1702 EPROM (256byte) I knew I still had a few 2708s (1k) but I've not seen a 1702 in years (this is the first EPROM type I ever worked with!)
1x 1771 floppy disk controller (very early - might be the 1st WD)
Lots more "old stuff" but these were the ones which stood out to me.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 31002 of 31544, by giantenemycat
MattRocks wrote on 2026-03-24, 00:36:
I thought of that, but I would feel weird gutting the MESH. I got it from a very nice man with a very nice Philips 107E CRT for a very nice price.
This manual he still had is the main reason I don't wanna mess with it, gotta preserve that slice of history. Windows ME and hard drive issues...sounds about right. Come to think of it, that probably explains why there's a 120GB HDD in there. That would have been crazy for 2001.
1999 Family PC: AST Bravo LC(?) 5166(?)/430TX(✔)/Pentium 166(?)/32MB(?) SDRAM/Virge DX\GX(✔)/ALS120(✔) - [OSR2 -> ME]
2006 Family PC: Generic Shuttle HOT-675/450MHz PIII/256MB SDRAM/Radeon 9200\9250/ST310240A 10.24GB - [XP SP2]
Reply 31003 of 31544, by Ozzuneoj
EDIT: Just wanted to update this post to say that you should NOT try to use 4Mbit chips in a GRiDCase 1530 the way I did below. It will pass memtest and it will kind of work, but the chipset is apparently only designed to properly refresh 256Kbit and 1Mbit DRAM chips. This can cause some pretty weird and difficult to diagnose problems which took me months to sort out (haven't had a ton of time to work on it). The most common seems to be that the system will hang if you leave it idle for 30 seconds and then attempt to interact with it. It seems that something important gets corrupted due to bit rot (from the memory not being fully refreshed at idle) and when you press a key the system hangs when trying to work with garbage data.
So, that means that the only way to get 4MB or 8MB of RAM in one of these machines without problems is with very compact SIPPs that can fit 8 (or 9 with parity) 1Mbit chips on them. These seem extremely uncommon, and likely do not exist outside of already decked-out GRiD systems. This would be a good project for someone who knows how to design a DIY PCB so that the community can order some blank PCBs (JLCPCB, PCBway, etc.) and then solder the required memory chips and capacitors.
Without that, there seems to be no way, currently, to obtain or modify existing SIMMs or SIPPs to build 1MB modules that fit and work properly in a GRiDcase 1530.
Ozzuneoj wrote on 2026-03-23, 23:43:
I wonder if I could just swap out the memory chips themselves? I have a big bag of 72pin SIMMs that don't have matches, so one or two of those would likely be good donors.
Yes!!
This ended up being the easiest solution. After practicing pulling SOJ chips off of a 72pin SIMM and reattaching some it seemed like something I could do without destroying anything. So I pulled all 8 chips off of the SIMM, pulled the chips off of each SIPP and swapped them out. All I used was a bit of thinned out flux, long angled tweezers, a heat gun and a tiny bit of solder paste for the legs that didn't want to flow with the existing solder (applied as needed with a super tiny flat blade screw driver).
I figured this method would be the safest and least likely to cause any damage to the PCB or solder pads since I am not that great with desoldering braid and don't have much experience using solder paste on multi-leg chips (yet). I think I made the right choice since I had basically no problems at all.
The attachment 1530_1MB (2).jpg is no longer available
After completing each stick I tested every pin with my DMM and everything was connected.
The attachment 1530_1MB (3).jpg is no longer available
I inserted the four SIPPs and the system booted right up and immediately found 4MB of RAM!
The attachment 1530_1MB (1).jpg is no longer available
I'm so happy this worked! This thing is one step closer to being as good as it really ever needs to be.
I have had a bit of trouble getting a patched ROM working properly (to fix BIOS issues related to fast hard drives or CF cards), but I will take another stab at that tomorrow. Once I have that working I'll swap the hard drive for a 512MB CF card. Then I should be able to load this thing up with just about any game or program that uses CGA or monochrome graphics. Should be a fantastic machine for that. 😀
For historical preservation the original memory chips, BIOS ROMs and hard drive will be safely stored in a labeled box... because I can't really imagine doing this any other way. @_@
Reply 31004 of 31544, by rasz_pl
What do you guys think? Could I just cut the ends of that SIMM (4th one down) to be the size of the SIPP without it causing an issue?
deffo
EDIT: Doh... I just tested them for fitment and these pins don't even slot into the ones in the GRID motherboard. They are close, but the pins on the old SIPPs are even smaller diameter than these precise round header pins apparently.
I have some vague memory of Feipoa talking about different thickness of machined pins in Custom interposer module for TI486SXL2-66 PGA168 to PGA132 - HELP! standard is 0.5mm
Ozzuneoj wrote on 2026-03-24, 03:38:
personally I would just solder appropriate thickness resistor legs to simm edge, but swapping chips is even faster
now you just need that UA 571-C Remote Sentry Gun to complete collection
Reply 31005 of 31544, by Ozzuneoj
rasz_pl wrote on 2026-03-24, 05:01:
deffo […]
deffo
Good to know that someone else has noticed a difference in pin diameter. The standard "square" type pins, like what most jumpers or motherboard headers use are way way too big, so when I looked around online I found people talking about these round "precision" pin headers, and they really looked like exactly what I needed. It seems strange to me that they don't fit despite being so similar, but I guess after 40 years it wouldn't be unusual for different variations of these to exist. Even the originals SIPPs use flat rectangular pins rather than round ones.
Now that I think about it, the BIOS chips also socket straight into similar holes on the board rather than into a DIP socket... I probably could have sacrificed some old chips and used the legs from those to make SIPP pins that would fit, while also using the chips themselves as a sort of jig to keep the roughly parallel. I'm picturing flattening out the pins on a DIP chip so that they aren't curved and stick straight out, then laying the chip on the ram stick (or under it) so that the pins are aligned with the contacts. Solder them all in place and then snip the legs free from the DIP chip. At least this way they would mostly be aligned with one another in groups of 8-12 or so. It would also keep them very low profile compared to using the pin headers that I tried to use.
As for doing each one by hand... I don't know. Getting individual pins straight enough to be usable and not look like a mess would have been a nightmare, at least with my skill level. The only reason I even tried making my own SIPPs was because I could get those premade rows of pins, tack down the ends and middle and then solder everything in between. The original SIPPs appear to have a hole in the PCB for each pin to wrap through so that they are attached and probably at least somewhat stable during soldering. Some kind of jig would help of course, but again... the rabbit hole... 🤣
Also, it's funny you mention needing a remote sentry gun to complete the system. I found this last night and I intend to install it on this thing because... well, because it exists.
https://forum.vcfed.org/index.php?threads/gri … t-case.1239812/
https://github.com/tschak909/UA571C
Reply 31006 of 31544, by BitWrangler
Yes!! […]
Whelp... I had already reassembled the GRID system when I got the idea to make my own SIPPs, so I ended up being a bit off with […]
Ozzuneoj wrote on 2026-03-21, 20:14:
Yeah the SIPP sockets are very cramped in this system. […]
The attachment rams (1).jpg is no longer available
The attachment rams (2).jpg is no longer available
The attachment rams (3).jpg is no longer available
I have a decent assortment of very small 1MB SIMMs, so I'm hoping I can use some of these.
The attachment rams (4).jpg is no longer available
The ones on the right are around 12.7mm tall, but given the CPU and video limitations I really don't think 8MB would provide much more functionality than 4MB, and I would prefer not to break up a matching set of 8. So I am leaning toward using this set of 4, which are around 14.5mm tall.
The attachment rams (5).jpg is no longer available
These IBM branded memory chips seem uncommon and I cant find a datasheet for them but according to this page these should be 1MB sticks. Of course I will have to install them to find out if they are compatible, but don't think it will be too hard to solder some pins to them. I will try to figure out beforehand if I actually have an extra 2mm of space in there... but I might be able to install four sticks at a slight angle even if they are a bit too tall.
I am looking forward to this though. I don't know why, but having a system upgraded to the point that it is as balanced and as useful as it realistically could be makes it seem "complete" and gives me a good feeling. Even if it works okay with 1MB and no 387, having 4MB and a 387 installed just feels right.
As for the video chip, it is visible in the first picture above. It is a Yamaha V6366C-J, similar to the one here. It is apparently MDA, Hercules and CGA compatible. I didn't look into it too much, but Checkit said that the system has 16KB of video memory available, so it seems limited to CGA.
The biggest limiting factor in the system I think will be the tiny hard drive. I think I have around 18MB free right now with hardly anything on it. That doesn't leave a lot of room for activities. For me, part of this computer's charm is that it is still running what is likely its original hard drive from 37 years ago, and it sounds cool... Of course, it would be nice to have a CF card or something in there to give more space, performance and reliability. For all I know this drive could be riddled with bad sectors or have other problems... I just haven't used it enough to know.
Interestingly, in the years since I got this machine back in 2020 a TON of work has been done by others to overcome several limitations. At the time there was no reliable way to use a CF card with them due to some BIOS bugs, but this guy seems to have figured out a way to patch the bugs relatively easily. I will consider doing this at some point and switching to a CF card. The rabbit hole is getting deep quickly though. All this started with me just digging this thing out of storage to show to my daughter a few days ago... 🤣
Whelp... I had already reassembled the GRID system when I got the idea to make my own SIPPs, so I ended up being a bit off with the size of the SIMM. These ones are definitely too big. They are too tall once assembled. And it looks like all SIMMs are too wide since they are meant to snap into SIMM slots and this system has only a few millimeters of space on either side of the SIPPs.
The attachment 20260323_193547 (Custom).jpg is no longer available
The two top ones are my attempts to convert SIMMs to SIPPs. I think these would work totally fine for a larger board, so I'll keep them.
The middle one is the original 256K SIPP from the GRIDcase 1530.
The next one down looks like it has no traces in the empty space at the sides, so should be able to be cut down to the size of the tiny SIPP. By comparison, the one under it also doesn't have much there but it looks like there is at least a copper layer in there, where the other one seems to have nothing.
EDIT: Doh... I just tested them for fitment and these pins don't even slot into the ones in the GRID motherboard. They are close, but the pins on the old SIPPs are even smaller diameter than these precise round header pins apparently. That really stinks. I don't know of anything else that would work, aside from sanding these ones down, which would be tedious to say the least.
... the rabbit hole is getting very deep now.
Yes!!
Awesome, glad that worked out. Not every SIPP PCB is going to have the address lines on for 1MB though, I guess this machine lucked out with being a bit later in the day than first 286 SIPP boards/modules. Maybe only a few months in it for 1mbs, but might have to find pretty late SIPP to swap 4MB onto each. Just a gut feel.
Okay, so 386 enhanced CGA dehanced Windows 3.1 is a go now 🤣
Reply 31007 of 31544, by Ozzuneoj
BitWrangler wrote on 2026-03-24, 18:11:
Yes!! […]
Yes!!
Yeah, I checked them first to be sure they were all connected. I noticed on the datasheets that pin 5 was NC on the 256Kbit x4 chips but was labeled A9 on the all of the 1Mbit x4 chip datasheets I checked. Thankfully, pin 5 did go to one of the SIPP pins on these modules (along with the rest of course) so I figured that at the very least all of the required traces were there. I am very glad it worked, because it was an all or nothing deal. I had to make all four of them to be able to tell if the computer could use any of them in this configuration.
And yeah, I will test the limits of CGA and monochrome modes on this system now, for sure!
Maybe I should remove the keyboard so that there is room for the 486SXL-50 I picked up a while back... then swap out the clock crystal. It's time to go for the CGA\MDA laptop benchmark record!
... no. I am planning to stop at 4MB + CF card with this one. Well... and maybe some kind of sound device, though that will most likely have to be external.
Oh man... if I could get this working as an MPU-401 device for an MT-32 that would be incredible. The look of the two together would be fantastic, and the sound of MT-32 music would fit nicely with whatever weird games are usable on this display.
Maybe there is a way to use the external drive connector on the back to access enough ISA pins to adapt a sound or midi device? hmmmm....
@_@
*peers way, waaay down into rabbit hole*
No... I think it is just a floppy connector. Whew...
Or I could use SBEMU with a serial port though a Yamaha TG100 (which I have) to reach the MT-32!
SBEMU with protected mode MPU401 UART support
And if something required intelligent mode (and not protected mode DOS) I could use SoftMPU, though I only have one serial port on this thing.
Reply 31008 of 31544, by Thermalwrong
I just found out that DriverGuide is now serving files again! Instead of the pointless outbyte driver installer thing.
Time to back up every driverguide link I can think of before it goes down again. Certainly there are a few posts where I linked driverguide and those files are going to have to go up on archive.org instead.
This last couple of days I have been trying to get my Toshiba T3400CT pair up and running. One originally had a bad keyboard controller and good caps, the other had bad caps and bad corrosion. Swapping the KBC between the two boards got board #1 working but board #2 still won't complete POST after recapping (which really needed it btw) because of the bad KBC. I wonder if I could swap in a KBC from the T21xx series laptop or if that would cause bad things to happen?
Well, the bad board has a smashed screen so it's not too important right now.
For anyone wondering, these should be the caps to replace on the T3400 and probably T3600 laptops, seems to be dependant on usage rather than outright faulty caps:
c42 on dc board - 6.3v 1500uf, 14mm tall, 10.2mm diameter
c41 on dc board - 25v 220uf, ~11mm tall, 8mm diameter
c39 on dc board - 6v 47uf, ~6mm tall and 6mm diameter
smaller cap by X3 on mainboard - 16v 47uf, 5.5mm tall, 7mm diameter
larger cap by X3 on mainboard - 10v 150uf, 6.25mm tall, 8.25mm diameter (height critical)
small cap by IC37 on mainboard - 16v 10uf, 5.5mm tall, 4mm diameter
Reply 31009 of 31544, by BitWrangler
I don't know if you could maybe clone the KBC code to another 8051 type chip in order to use that as a scratch monkey.
Reply 31010 of 31544, by NyLan
I have a made a case for the famous Dell Mini usb floppy drive
The attachment 20260326_235604.jpg is no longer available
The attachment 20260326_235655.jpg is no longer available
The attachment 20260326_235702.jpg is no longer available
The attachment 20260326_235717.jpg is no longer available
and I have recreated the hook that retains the drive for my IBM 600. I was broken and missing.
The attachment 20260326_092804.jpg is no longer available
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 31011 of 31544, by Ozzuneoj
NyLan wrote on 2026-03-26, 23:11:
I have a made a case for the famous Dell Mini usb floppy drive […]
Nice! I have a bunch of those. They are indeed handy.
I'm guessing this is the model you printed?
https://cults3d.com/en/3d-model/gadget/dell-f … oppy-drive-case
Reply 31012 of 31544, by Nexxen
I finally decide to clean and repair a bunch of AT keyboards. Some are AT/XT selected via a switch.
I'll probably start a thread to post stuff and mistakes.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 31013 of 31544, by NyLan
Ozzuneoj wrote on 2026-03-27, 00:59:
Nice! I have a bunch of those. They are indeed handy. […]
Yes and I just modified it a bit to add 8mm Silicone Bumper Pads spots and the printed label.
Personal GitHub
Reply 31014 of 31544, by RetroLizard
Got a Sega Genesis Model 1. Still has to be shipped out, but the seller said it was having problems with the first controller port.
Now, I could very well be wrong, but would transplanting a db9 port from an old computer work? Seeing as the Genesis uses the same physical pin layout as a db9, I'm assuming the db9 port would just use the signals provided by the Genesis mainboard, rather then the standard serial signals of a PC.
Reply 31015 of 31544, by giantenemycat
I was about to transplant a different board into this case, but actually looking at it, it seems like the I/O shield is built into the chassis. Even if that pops out, that's not going fit into a different case, is it?
Reply 31016 of 31544, by Shponglefan
RetroLizard wrote on 2026-03-27, 12:24:
It would probably depend on the pin spacing and shroud. The Genesis uses connectors with a black plastic shroud, whereas typical d-sub connectors on computers are metal with metal clip-in pins. If you could source a proper replacement with the plastic shroud, I'd go with that over transplanting a port from a computer.
Of course this all assumes that the connector does need replacing. You'd want to diagnose that first. It could be something like corroded pins which might be able to be cleaned, or an issue not related to the connector itself.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 31017 of 31544, by RetroLizard
Shponglefan wrote on 2026-03-27, 13:48:
Yeah, that's true. I was just wondering if the idea would work, physical limitations not withstanding.
Reply 31018 of 31544, by wierd_w
Genesis is a normal DB9.
Many vintage serial mice used the same kind of molded plastic plug.
interface-for-serial-mouse-v0-75y944km38hf1.jpeg?auto=webp&s=43e3fd6f6f639f38b08d3673367e81eb07747b77
It's (genesis controller) physically (and mostly electrically) the same as an Atari Joystick.
There's a community breakout board for TI 99/4A microcomputers for dual joysticks that's basically just some passives and some db9 connectors.
https://texelec.com/product/ti-994a-to-atari- … ystick-adapter/
I can confirm that genesis controllers fit fine.
Reply 31019 of 31544, by BitWrangler
giantenemycat wrote on 2026-03-27, 13:40:
That one doesn't look too unusual. I am seeing some listed under the designation "Motherboard ATX IO Shield Backplate Centre Parallel Port Horizontal Audio"
