First post, by RetroPCCupboard
I have acquired a small PC in a MicroATX low profile case. The motherboard is a Gigabyte GA-6VEML.
It supports Tualatin (currently has a 1.3Ghz Celeron). Has an ISA slot. There is no AGP slot. It has onboard Trident Blade3D graphics.
According to this, the onboard audio works in DOS:
VIA 686B AC'97 audio works really well in DOS (SB Pro stereo + OPL3 emulation!)
So, what would you do with it?
The ISA slot seems a little wasted here to me, as I am not aware of any low profile ISA soundcards. For PCI video there aren't too many options that I think make sense here.
Thoughts?
Reply 2 of 12, by wierd_w
There's an old thread about low profile isa soundcards, but with a functional onboard one I question why.
Any low profile ISA/EISA sound card out there.
I'd want to put dualboot svardos + winxp setup on there, and use it for a compact game appliance.
Reply 3 of 12, by RetroPCCupboard
cyclone3d wrote on Yesterday, 19:08:
Put it in a different case? Make an external enclosure and extension cables so you can use the slots?
Yeah, it does seem to me that better use could be made out of the Tualatin with a full-size PCI slot.
wierd_w wrote on Yesterday, 19:11:
I would think that it wont be as compatible as genuine soundblaster. But, yeah, I should try onboard audio
Reply 4 of 12, by NeoG_
A PicoGUS and a WP32 or WavetablePi
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 12, by RetroPCCupboard
I have never heard of svardos. I see now that it was based on FreeDOS (which I have heard of).
Is there any reason in particular you'd use that OS over MS-DOS?
Reply 6 of 12, by RetroPCCupboard
NeoG_ wrote on Yesterday, 21:24:
I have been considering getting a PicoGUS for another PC. But that isn't low profile, so won't fit in this case.
I kinda bought this PC without looking properly. Just saw ISA and Tualatin then hit the "Buy" button, as was cheap. I noticed afterwards the lack of AGP.
Reply 7 of 12, by Major Jackyl
I have a similar board. I use it only for testing Tualatin CPUs without taking apart my primary Tually PC (which has TUSL2).
I also ran windows 7 on it, for a good laugh. The 20GB drive was basically completely consumed and it took maybe 4+ hours? Absolutely useless after that, 🤣 No drivers for the VGA or audio in windows 7, not that it matters much; absolute slug-fest
The attachment QDI_C1K_SUM.png is no longer available
Oldest, slowest PC I ever installed 7 on, don't think it's possible to sink any lower than that.
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 8 of 12, by Shponglefan
Lack of AGP seems like a big hindrance to a Tualatin level system. Unless maybe running a Voodoo4 or 5 PCI card maybe?
But if the intent is to keep it in the existing case, then not a lot of options.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 9 of 12, by kixs
Major Jackyl wrote on Yesterday, 22:22:
I have a similar board. I use it only for testing Tualatin CPUs without taking apart my primary Tually PC (which has TUSL2). […]
You should have used a SSD and some later PCI card like Geforce 8400GS. It would be completely other experience.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 10 of 12, by Major Jackyl
kixs wrote on Yesterday, 23:23:
Not sure if any of my PCI SATA cards would've booted it, so getting an SSD on this board could be tricky. Best I could've done in the GPU department is a 5200, which is the "last" nvidia PCI card? 8400GS is a PCI-e card. I've NEVER seen anything higher than 5 series in PCI form. I don't have drivers for 5 series or lower for windows 7, either, so I would need to find some of those. Thinking about it sounds like a hassle, 🤣 Only to waste the ISA in the end because windows 7 doesn't know anything about it.
Reply 11 of 12, by NeoG_
RetroPCCupboard wrote on Yesterday, 22:09:
Oh dang that ISA slot is a writeoff
Reply 12 of 12, by rasz_pl
Who needs AGP when you have AMR?!?! 😀
ISA slot is more of a DOS thing, so I dont see lack of AGP as a problem. Savage4 has excellent DOS compatibility.
PLE133T is VIA 694T + Savage4. Not great, not quite terrible. ~Banshee performance? Will play UT fine.
