TEDIT v0.65 [FIXES]
Reply 100 of 113, by Yoghoo
cookertron wrote on Yesterday, 17:02:
FIXED and released! […]
Yoghoo wrote on Yesterday, 15:23:
cookertron wrote on Yesterday, 14:48:
Version 0.64.0 Fixes: […]
  • Shell-to-DOS Jemmex crash fix
  • BSS-to-segment migration: Moved shadow_buf (4 KB) and doc_table (3 KB) to separately-allocated DOS segments via INT 21h/48h, reclaiming 7 KB from the 64 KB COM segment
This version does not work at all for me (with or without adding a file name on the command line). I see only the mouse and nothing else.
FIXED and released!
Version 0.64 now works with 4DOS. All tests pass!
The issue was that 4DOS doesn't clear memory when allocating it out so the buffers contained garage data which corrupted specific tests. A better explanation is in the changelog if you're interested .😎
NOW, here's a question for everyone... how would you feel about a DOSBox-X host shared clipboard? This means you can copy text from the host system (Win/Linux) directly into TEDIT and vice versa. I'd love to hear your opinions.
Sorry but it's not fixed here. Still the same problem.
Regarding host shared clipboard it's not really for me. I only use Dosbox-X to quickly test or compile something. The rest I do on real retro pc's. 😀
Reply 101 of 113, by cookertron
Yoghoo wrote on Yesterday, 17:15:
FIXED and released!
I'm really sorry, I didn't commit the new fix to GitHub. I've done it now 😔
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 102 of 113, by Yoghoo
cookertron wrote on Yesterday, 17:32:
FIXED and released!
No worries. Issues are indeed fixed. Only it uses almost 280KB of memory when I do a dos shell. Seems a bit excessive but further than that it works fine.
Reply 103 of 113, by aVd
A 4DOS compatibility... Wow! The latest TEDIT version 0.64 is really good 😀 Also the new Agent86 0.20.1 works fine even with the older code.
Just a few minor bugs: for me <Ctrl>+<Alt>+<S> ("Close all...") and <Ctrl>+<Alt>+<S> ("Save all...") keyboard shortcuts do not work at all. And <Ctrl>+<Shift>+<W> combo works as <Ctrl>+<W> ("Close") - probably not really a bug. But <Shift>+<Tab> now works fine.
And why not some <Fn> or key combo assigned for "Shell to DOS and some shortcuts for "Load project..." and "Save project..."?
For the DOSBox-X clipboard sharing - I'm not sure, if you have to use the freed bits for such a functionality. I use DOSBox and DOSBox-X for quick tests and DOS compile/build only.
@cookertron, do you mind, if I keep tinkering with the old 0.57 version source code?
DOS fan :: artificial "intelligence" (chat) bots - not a fan... not a fan at all :: is freeware a lie, when human freedom is a fundamental lie?
Reply 104 of 113, by cookertron
aVd wrote on Yesterday, 18:59:
I'll look in to that, thanks.
Good point but not sure which key combo to assign - any thoughts?
Thanks for feedback.
Absolutely not! You do whatever you like with it 😀
Reply 105 of 113, by igully
@cookertron
Thank you for this new build v0.64 which fixed the JEMMEX issue when shelling.
If I may, can I ask you to please add a small feature? A Unix/Amiga (LF) to Windows/DOS (CR+LF) line ending conversion (back and forth). It would of course, require that when opening a text file to detect and indicate somewhere the current line ending present.
For what it is worth, I am not a DOSBOX user. I use either a real machine, VirtualBox and 86Box and may try any other "complete" x86 PC emulator eventually.
Thanks again for your continued development.
Reply 106 of 113, by aVd
cookertron wrote on Yesterday, 19:21:
I have no idea about the "shelling". We may look in some of the countless Norton Commander's clones - most of them (if not all of them) have "start command interpreter" option. Or maybe Ignacio can suggest some suitable keyboard shortcut. As for the project's shortcuts - some popular DOS IDE may be of help too. Old Borland C++ DOS IDE, RHIDE...?
Seems like Ignacio's suggestion for CR to LF, CR (and backwards) line break convertor will be more useful for me.
Thank you! It will be only cosmetic work - like rearranging the menu items. And don't worry, I have only basic knowledge in assembly, so I'll not do anything deeper to break your original code entirely 😉
P.S. I think, I found another bug.
After unsuccessful tryout to open some big file and the error message "Out of memory" I got something like empty file in the opened file list:
The attachment after_out_of_memory_error.jpg is no longer available
Wouldn't it be more proper behavior to not open "empty file" at all after this "Out of memory" error?
Also, I'm not sure what to chose as a response for this message:
The attachment unclear_question.jpg is no longer available
Reply 107 of 113, by Yoghoo
Just a FYI for someone who wants to change ALT-Q to ALT-X. These lines need to be changed:
Change line 135: DB 'Quit', 0	To:  DB 'Exit', 0
Change line 143: DB 'Alt+Q', 0 To: DB 'Alt+X', 0
Change line 332: DB 0, 'Q' To: DB 1, 'X'
Change line 334: DB 10h, 0 To: DB 2Dh, 0
This is for version 0.64 so line numbers can change in upcoming versions. 😀
Reply 108 of 113, by aVd
Made a newer old single-file edit TEDIT version 0.57.2 with new "Search" menu. Now "Edit" and "Search" menus look like this:
The attachment edit_menu.jpg is no longer available
The attachment search_menu.jpg is no longer available
Attachment with the modified source code and the compiled com-executable:
The attachment TEDIT_0572_mod.zip is no longer available
Unfortunately I stll can't figure out how to make <Shift>+<Tab> combo to work in dialog boxes in reversed direction.
EDIT: <Shift>+<Tab> problem solved by @cookertron. The latest update for the 0.57.x variant of TEDIT is here.
Reply 109 of 113, by cookertron
Release v0.65 - https://github.com/cookertron/TEDIT:
  • Menu item 'Quit' renamed to 'Exit' with shortcut changed to ALT-X
  • Large document invokes 'Out of Memory' and a ghost document in side panel - fixed. Drops back to previous document.
  • Exiting TEDIT with modified documents invokes confusing save dialog. Now says 'Discard unsaved changes?' with options 'Yes|No'
  • Shell to DOS shortcut is F8
  • All menu shortcuts should now work but this isn't guaranteed 😁
I couldn't work out which shortcut to use for projects so just left it empty. Maybe someone will get inspired 🤷
Before doing anything else I'm going to explore removing the original document from memory altogether. When edits are made to a document the original file isn't touched, it's only when the document is saved. TEDIT walks through the piece table and makes the changes that have accumulated. That's why if you make a lot of changes you'll eventually be prompted to save your work to free up the piece table. It also means the original file doesn't need loading into the memory at all, the text can be read directly from the disk. That's the theory anyway. Let's see how it goes!
Reply 110 of 113, by aVd
aVd wrote on Today, 10:40:
By replacing some TUI source code, @cookertron fixed <Shift>+<Tab> navigation problem. So, this 0.57.3 version seems like the final one of the single-file edit TEDIT 0.57.x updates:
The attachment TEDIT_0573_mod.zip is no longer available
Tnanks @cookertron!
Now it's time to test the newest and the coolest multi-file edit TEDIT version 0.65 😀
Reply 111 of 113, by Yoghoo
cookertron wrote on Today, 11:51:
Good to see ALT-X by default. 😜
Nothing else to add as everything seems to work fine. But maybe look at the memory consumption when shelling to dos (230+KB without any documents open). Not really an issue for me but it could hinder pc's with limited (free) memory.
Reply 112 of 113, by aVd
I don't know how we missed this. It will be an easy fix, but the "File" menu needs some shortcut-letters rework:
The attachment file_menu_shortcut_letters_repeated.jpg is no longer available
"Edit" menu seems Ok.
Reply 113 of 113, by aVd
Just made a quick test fix for "File" menu partially inspired from BC++ DOS IDE. It looks like this:
The attachment file_menu_suggestion.jpg is no longer available
These are my code changes in "TEDIT.ASM"
m_file_entries:
; New
DW m_str_new, menu_new_handler
DB 0, 'N'
DW m_str_acc_cn
DB 0, 0
; Open...
DW m_str_open, menu_open_handler
DB 0, 'O'
DW m_str_acc_co
DB 0, 0
; Close
DW m_str_close, menu_close_handler
DB 0, 'C'
DW m_str_acc_cw
DB 0, 0
; Close All
DW m_str_closeall, menu_closeall_handler
DB 4, 'E' ; - CHANGED -
DW m_str_acc_caw
DB 0, 0
; ---- divider ----
DW 0, 0
DB 0, 0
DW 0
DB 0, 0
; Save
DW m_str_save, menu_save_handler
DB 0, 'S'
DW m_str_acc_cs
DB 0, 0
; Save As...
DW m_str_saveas, menu_saveas_handler
DB 1, 'A' ; - CHANGED -
DW m_str_acc_css
DB 0, 0
; Save All
DW m_str_saveall, menu_saveall_handler
DB 6, 'L' ; - CHANGED -
DW m_str_acc_cas
DB 0, 0
; ---- divider ----
DW 0, 0
DB 0, 0
DW 0
DB 0, 0
; Load Project...
DW m_str_loadprj, menu_loadprj_handler
DB 8, 'J' ; - CHANGED -
DW 0
DB 0, 0
Show last 31 lines
; Save Project...
DW m_str_saveprj, menu_saveprj_handler
DB 5, 'P'
DW 0
DB 0, 0
; ---- divider ----
DW 0, 0
DB 0, 0
DW 0
DB 0, 0
; Shell to DOS
DW m_str_shell, menu_shell_handler
DB 9, 'D' ; - CHANGED -
DW m_str_acc_f8
DB 42h, 0 ; accelkey=42h (F8 global dispatch)
; ---- divider ----
DW 0, 0
DB 0, 0
DW 0
DB 0, 0
; Exit
DW m_str_quit, menu_quit_handler
DB 1, 'X'
DW m_str_acc_ax
DB 2Dh, 0 ; accelkey=2Dh (Alt+X global dispatch)
This is just a suggestion. Someone may give a better idea for letter assignments in "File" menu.
