Reply 100 of 171, by Yoghoo
- Oldbie
cookertron wrote on 2026-04-01, 17:02:FIXED and released! […]
Yoghoo wrote on 2026-04-01, 15:23:cookertron wrote on 2026-04-01, 14:48:Version 0.64.0 Fixes: […]
- Shell-to-DOS Jemmex crash fix
- BSS-to-segment migration: Moved shadow_buf (4 KB) and doc_table (3 KB) to separately-allocated DOS segments via INT 21h/48h, reclaiming 7 KB from the 64 KB COM segment
This version does not work at all for me (with or without adding a file name on the command line). I see only the mouse and nothing else.
FIXED and released!
Version 0.64 now works with 4DOS. All tests pass!
The issue was that 4DOS doesn't clear memory when allocating it out so the buffers contained garage data which corrupted specific tests. A better explanation is in the changelog if you're interested .😎NOW, here's a question for everyone... how would you feel about a DOSBox-X host shared clipboard? This means you can copy text from the host system (Win/Linux) directly into TEDIT and vice versa. I'd love to hear your opinions.
Sorry but it's not fixed here. Still the same problem.
Regarding host shared clipboard it's not really for me. I only use Dosbox-X to quickly test or compile something. The rest I do on real retro pc's. 😀
