GeForce 7800 GS and Bumpgate
Reply 20 of 38, by altarofmelektaus
havli wrote on 2026-03-03, 18:35:
Perhaps something like Zalman VF900 could be suitable? I don't know if it fits the GPU area, but it might. Plus some passives for RAM and HSI.
This seems plausible and likely better than the stock cooling. I just finished a socket 462 liquid cooled build last year and I don't feel like doing another, but I might have to if I don't strike luck with aftermarket coolers.
Reply 22 of 38, by altarofmelektaus
Do you think this would work well enough for HSI? It's long enough that I can cleanly drill holes into it and use some spring mounted pegs from an old parts card. I got a VF900 and it fits the GPU area, no clearance issues with this heatsink either. Just wondering if the heatsink I found in my parts bin is big enough to handle that chip.
Reply 25 of 38, by havli
Yes, this heatsink with some airflow around will be good.
Reply 26 of 38, by altarofmelektaus
Maybe I should've checked to make sure the VF900 even fits the card first. This card has an asymmetrical screw mount that is incompatible with the VF900's bracket and is the only thing stopping me from using it. Annoying.
Reply 27 of 38, by altarofmelektaus
Ydee wrote on 2026-03-08, 09:46:
Maybe this one https://shop.bostar.cz/default.asp?cls=stoitem&stiid=18 , still for sale on some eshops?
Also for future reference to anyone with this issue, the AeroCool Double Power does not work on the 7800 GS AGP. I just imported one NOS from Czech Republic and thought it'd work with its strange looking mounting bracket, but nope, none of the holes line up. Neither does the VF900. It is a very weird arrangement of holes that is rectangular.
At least I have these for other GPUs I suppose.. Maybe this one just really wants its original stock cooler. It's not that bad.
Reply 28 of 38, by altarofmelektaus
Cursed
Reply 30 of 38, by The Serpent Rider
altarofmelektaus wrote on 2026-04-02, 20:44:
Cursed
At the end of the day you can just ditch the fan part of the original cooler and attach a 90-120mm fan via bracket in the neighboring slot: https://www.titan-cd.com/en/product/TTC-SC07TZ_RB.html
Reply 31 of 38, by altarofmelektaus
Ydee wrote on 2026-04-03, 08:02:
Cursed
Can you put a sketch in here with the spacing holes? I'll try to find something.
Sure thing. I appreciate it!
The outer 3 holes are less important and probably even more impossible to find an exact match for. It's nice I had a caliper and scanner on hand. Measured by centers of holes.
Reply 32 of 38, by aVd
Cursed
Hi, @altarofmelektaus,
Did you tried, if it will fit turned by 180°?
I like the quieter planets, this one became pretty noisy 😀
Reply 33 of 38, by Ydee
altarofmelektaus wrote on 2026-04-05, 01:20:
Cursed
We may not find a perfectly compatible one on the AGP version, but with a little DIY, this one might do the trick: https://www.tntrade.cz/produkty-primecooler-p … ion-detail-6933
The 62mm pitch doesn't quite fit, but it could sit if one hole is enlarged by a file or a Dremel, or drill one new hole.
I have a similar one made of aluminium, on the R9600XT, I attach the pitch.
Reply 34 of 38, by altarofmelektaus
aVd wrote on 2026-04-05, 08:41:
Cursed
Yes, in every orientation it does not fit. I believe this card has its own proprietary mount that nobody else has made heatsinks for. It will fit with two adjacent screws, but this only keeps the heatsink secured on one side. It will not work for opposite side screws.
Reply 35 of 38, by altarofmelektaus
Ydee wrote on 2026-04-05, 11:09:
We may not find a perfectly compatible one on the AGP version, but with a little DIY, this one might do the trick: https://www.t […]
See, that's the kind of bracket I was looking for. That's probably the closest one I've seen so far. It also looks to support the HSI chip heatsink I threw together. I'll consider looking for one!
Reply 36 of 38, by Ydee
Still on stock, even another Cu/Al version cheaper, but for 7800 I vote for full copper version.
Reply 37 of 38, by altarofmelektaus
I have returned with a solution! Was rummaging through some of my old water cooling parts one day and found two little brackets used to mount a chipset waterblock. In that moment, I remembered that the heatsink mount for my 7800 fit a VF900, but only on one side. Then the magic lightbulb lit up...
Yet to test it out and get temp readings, but the fact I was able to figure something out has me more than happy at the moment!
Reply 38 of 38, by Ydee
Seems well done, congrats!
