First post, by iogamesplayer
Hi all,
My Brother BC7486 PC has a NCR 77C22E VGA chipset intergrated into the motherboard.
Games like Tomb Raider and Pirates: Gold work great at 640x480 @ 256 colors under DOS with one of those VESA extension TSR programs, but Windows is stuck at 16 colors.
I tried SciTech Display Doctor, I tried the standard Super VGA driver, and from what I can find this card doesn't officially support Windows 95.
Does anybody know how I could get Windows 95 to run at 256 colors?
Thanks
Reply 1 of 5, by iogamesplayer
I tried SciTech display doctor 5.3a as well -- it tells me the NCR SVGA 77C22E chip has been detected but isn't supported by SciTech
Reply 2 of 5, by EduBat
Maybe it will work with the windows 3.1 drivers which you can find here?
https://www.ardent-tool.com/NCR/3350.html
Failing that, install Windows 3.1, then the drivers, then upgrade windows from 3.1 to 95.
Reply 3 of 5, by iogamesplayer
You're amazing, that worked first try 😀
Only remaining issue is that I cannot run software like DooM 95 utilising DirectDraw, because the driver "is not windows 95 compatible". Do you also happen to know a magic workaround for that?
Thanks!
Reply 4 of 5, by EduBat
Really glad it worked 😀
No, I don't know of any workaround for doom95.
Reply 5 of 5, by wierd_w
The win3x driver is probably better optimized, but if you have a vesa tsr for the card, then the vbemp driver should also work.
It will be leveraging that tsr for everything though.
It does do ddraw, however. (Or so I recall seeing. I'm old. Take with suitable salt)
https://bearwindows.zcm.com.au/vbe9x.htm
Dont expect miracles, all the same.
