Reply 20 of 32, by DustyShinigami
- Oldbie
douglar wrote on 2026-04-08, 17:24:Here's what happens for the standard protected mode IDE driver ESDI_506.PDR : 1. The "NoIDE" Registry Flag - the driver checks […]
wierd_w wrote on 2026-04-08, 15:30:It tends to happen when dos disk drivers are loaded.
Certain dos atapi or scsi drivers trigger it, iirc.
1. The "NoIDE" Registry Flag - the driver checks HKLM\System\CurrentControlSet\Services\VxD\IOS for a value named NoIDE. If this exists (often placed by Windows after a crash), the driver aborts.
2. "Safe to Hook" Check - The I/O Supervisor (IOS) checks if the drive is already being managed by a driver other than the motherboard BIOS. If it is handled by a DOS driver and the driver is not listed in the c:\windows\IOS.INI "safe" list, the protected-mode driver aborts.
3. Controller Validation - The driver attempts to communicate directly with the IDE controller's I/O ports . if the the "Busy" bit stays on too long, the protected mode driver fails to initialize.
4. ATA Identity Command - The protected mode driver wants to see a 512-byte block of data containing the model number, firmware version, the drive geometry and capabilities like LBA support. If the drive returns garbage or fails to respond, the protected-mode driver exits.
5. Interrupt validation - The protected-mode driver triggers a simple command and waits for the hardware interrupt for the returned results. If the interrupt smells funny, the protected-mode driver exits. This catches many newer IDE controllers.
6. Geometry Sync - compares the geometry returned by the identify device command against the BIOS drive table. If there is a discrepancy that it cannot understand, the protected-mode driver exits.So it sounds like windows is passing all those tests unless there is some odd third party IDE driver loaded.
Only thing that springs to mind would be the RAID adapter driver...? But I'm sure I had this issue with GK3's installation before I bought that. Other than that, there's the HPT controller, which has the latest driver installed (I think?) - 1.26. Prior to re-installing my 80GB HDD, I did disable that controller in the BIOS. I can always try disabling it again and resetting everything in the BIOS...?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
