RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3322 of 3354, by sharangad
Still haven't fixed the MDK scaling issue. V_LockBuffer/V_UnlockBuffer has the world background which needs to be blitted, but it doesn't scale correctly with some resolutions (and not just 1680x1050). The Pixel boundaries seem to go off.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3323 of 3354, by sharangad
@Goneau:
I found a bug in my 3dbVLB test app.
Could you rerun this test:
https://nirvtek.com/downloads/3DBVLB%2C.20260413.001.7z
MD5: 5de142ae96ae7d604f433bd75d64773a
I don't know if the IO port range will affect it.
[edit]
Port 0x279 appears to be the Isa pnp initialisation.
[edit 2]
Does anyone know how the isa pnp init works? Wikipedia has some details and Microsoft has a doc on the bios side of things.
Reply 3324 of 3354, by sharangad
sharangad wrote on 2026-04-01, 11:59:
The mdk stray pixel edge problem appears to occur in D3D mode as seen here:
https://www.youtube.com/watch?v=voz7N_2HmAM&t=321s
Reply 3326 of 3354, by Gona
3dbVLB.txt attached.
I have only one board with VLB slot (and it has only one VLB slot), that is PnP:
SOYO 4SAW2 (a Socket 3 - SiS 496/497 board)
and the VLB PnP init work the same as like the ISA PnP init (at least in appearance).
But with PnP, the 3D Blaster VLB get different resources than default, and some Rebel Moon don't like it so I have used DOS initiator program (INIT3D.EXE) in this board too.
sharangad wrote on 2026-04-13, 10:47:
@Goneau: […]
@Goneau:
[edit]
[edit 2]
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 3327 of 3354, by sharangad
Thanks Gona!
The isa pnp should return a device Id from somewhere after this sequence, after setting all non-pnp cards to query mode with a key.
It looks like the test app is still broken.
Reply 3328 of 3354, by sharangad
One more Gona,
https://nirvtek.com/downloads/3DBVLB.20260416.001.7z
MD5: 0367e20cacb61a499fe0c7d64be30b39
I was missing IO for port 0xA79 earlier. Hopefully the device ID will show up now.
Reply 3331 of 3354, by sharangad
Gona wrote on 2026-04-18, 20:34:
Here it is.
Thanks Gona!
That's produced a response on port 0x22b and the adjacent port. Need to plug this into dosbox and see what happens. I'll have a fresh build tomorrow. Today's an icr2/widescreen day.
Reply 3332 of 3354, by sharangad
@Gona, if you run Microsoft's ISAPNP.EXE (from the Windows 95/98 resource kit), does it list the device identifier (for the 3db vlb)? It should be a 72 bit identifier.
That might be easier than testing this bit by bit at a time with each build.
Reply 3334 of 3354, by sharangad
I don't know whether exporting this reg key will work:
HKEY_LOCAL_MACHINE\Enum\ISAPNP
In theory at least, the device id should be there.
On my 486 with an Opti ISA sound card I get ffffffff as the device id, but it might be different for the VLB, maybe.
[EDIT] If it doesn't, I can try knocking up a test app, though I don't really know how well it would work.
Reply 3335 of 3354, by sharangad
This is something DeepSeek knocked up, so it could be entirely wrong (well, maybe slightly. It does fix a couple of bugs I had with my previous test app):
https://nirvtek.com/downloads/ISAPNP.7z
MD5: 70a3bfe9a26dc054366d035c9d51e868
My 486 has a PnP Opti 931, but maybe the motherboard predates PnP, I dunno. This detects 10 cards with the same ID (FF FF FF ... FF) on that. It may work better on yours.
[EDIT] Or this (ChatGPT)
https://nirvtek.com/downloads/ISAPNP2.7z
MD5: e4707609bc4bc43cad0185f819d7715e
This doesn't work on my 486 either (o card(s) detected.
Reply 3336 of 3354, by sharangad
After waiting 6 hours for an ICR track to load in debug mode, I turned on logging and realised a bug in there had turned it off immediately. Fixed the problem and kicked it off again and it's almost 6 hours again now. But while the track was loading I had a CGL epiphany.
I think I've found part of the signature of the function which assigns function pointers for CGL functions. Not everything has this (21st), but even VLB games have a slightly different form of the function in there:
                           FUN_00010c18                                    XREF[1]:     FUN_000110a4:0001158d (c)
00010c18 53 PUSH EBX
00010c19 52 PUSH EDX
00010c1a 89 c2 MOV EDX ,EAX
00010c1c 8b 40 27 MOV EAX ,dword ptr [EAX + 0x27 ]
53 52 c2 8b 40
The last byte changes. The precise offsets are different and the function pointers which are relocatable are usually totally different. This is from 3DBInfo, but most CGL games including a few VLB games have something similar:
       00010c1f 8b  58  04       MOV        EBX ,dword ptr [EAX  + 0x4 ]
00010c22 89 1d 38 MOV dword ptr [PTR_FUN_00020438 ],EBX = 00010c10
04 02 00
00010c28 8b 58 08 MOV EBX ,dword ptr [EAX + 0x8 ]
00010c2b 89 1d 3c MOV dword ptr [PTR_FUN_0002043c ],EBX = 00010c10
04 02 00
00010c31 8b 58 0c MOV EBX ,dword ptr [EAX + 0xc ]
00010c34 89 1d 40 MOV dword ptr [PTR_FUN_00020440 ],EBX = 00010c10
04 02 00
00010c3a 8b 58 10 MOV EBX ,dword ptr [EAX + 0x10 ]
00010c3d 89 1d 44 MOV dword ptr [PTR_FUN_00020444 ],EBX = 00010c10
04 02 00
00010c43 8b 58 14 MOV EBX ,dword ptr [EAX + 0x14 ]
00010c46 89 1d 48 MOV dword ptr [PTR_FUN_00020448 ],EBX = 00010c10
04 02 00
00010c4c 8b 58 18 MOV EBX ,dword ptr [EAX + 0x18 ]
00010c4f 89 1d 4c MOV dword ptr [PTR_FUN_0002044c ],EBX = 00010c10
04 02 00
If these are in fact the CGL function pointers, swapping out the values at these addresses with custom code calls to Dosbox should make things work.
Reply 3337 of 3354, by Gona
I have put the 3D Blaster VLB to my only VLB PnP board but these ISAPNP.EXE files works the same here:
Firts one detects 10 cards with the same ID (FF FF FF ... FF) and the second one o card(s) detected.
I have checked the unusual resources got the 3D Blaster VLB by PnP bios:
Control region: 86000000-86000FFF (versus C10000000-C10000FFF)
Memogy region: 87000000-87FFFFFF (versus D10000000-D10FFFFFF)
I/O port: 200-203 or 204-207 (versus 3E0-3E3)
IRQ: 9 (versus 5)
sharangad wrote on 2026-04-20, 03:13:
This is something DeepSeek knocked up, so it could be entirely wrong (well, maybe slightly. It does fix a couple of bugs I had w […]
Reply 3338 of 3354, by sharangad
Gona wrote on 2026-04-20, 15:50:
I have put the 3D Blaster VLB to my only VLB PnP board but these ISAPNP.EXE files works the same here: Firts one detects 10 card […]
IRQ: 9 (versus 5)
Thanks Gona.
I'm going to try to get function pointer intercept working with the 3dbpci code tomorrow. Aso need to repeat the 6 and a half hour test again for a third time because I had to shutdown because of lightning.
I think I need to analyze the vlb apps with an Ai to see how it detects it and whether function pointer intercept will work here.
Reply 3339 of 3354, by sharangad
IRQ: 9 (versus 5)
Once more unto the breach Gona,
[EDIT] Use this link
https://nirvtek.com/downloads/3DBVLB.20260422.002.7z
MD5: 96ad0f7e216253127de502e4279d68b4
[/EDIT]
https://nirvtek.com/downloads/3DBVLB.20260422.001.7z
MD5: 541789a296a8d224aa5af6a268f3e05f
This one works on with my ISA soundcard. I don't know whether the device id is right here. If this works on your machine, it should list both the soundcard and the 3DB.
It might to be a good idea to run it several time to see if the device IDs are the same each time, though this might be an issue with Dosbox-Rendition.
