Well my Thinkpad T43 failed on me today 🙁
After reading a couple of the later posts here I though I would pull it off the shelf, charge the battery and see about replacing the soundfont I was using with VSBHDA with something larger (I mean, I've got 1GB of RAM for DOS... let's use it for something!)... sadly, whilst the battery charged (amber -> green indicator after an hour or two) it won't power on. The PSU and battery indicators light up, the cpu fan spins, but the screen is dead and there's no POST/beep messages. Tried on battery, on psu, on both, removed battery, held power button, reseated ram, etc.. all the normal tricks... it just won't POST.
I guess I'm in the market for a replacement:
- Later Pentium-M or Core Solo/Duo
- Minimum 1024x768 screen - absolutely must be 4:3 aspect
- Must have chipset supported by SBEMU/VSBHDA
- Trackpad preferred - nub controllers are a pain for gameplay
- Not too physically big/heavy - I've a lovely Armada 1750, but don't use it because it's so brick-like
Currently thinking: Thinkpad T60, T61, R51, R60, R61 (but most of the these were specced with 16:9 options), Compaq Nx6310, Dell D520
https://www.target-earth.net
