Reply 740 of 762, by Babasha
envagyok wrote on 2026-01-07, 08:03:
Hello
Which is the 1-2 game with can i cover almost all prop. 3d standard?
Best is what can i use with dos or windows98 se
Tomb Raider 1
Quake 1
anyway they need additional executables or patches/libraries
Need help? Begin with photo and model of your hardware 😉
Reply 741 of 762, by envagyok
Is anywhere a source for this files where i can download it?
Reply 742 of 762, by Putas
Quake only has the Vérité proprietary renderer. Mechwarrior 2 and POD would be better candidates.
Reply 743 of 762, by vvbee
POD's S3d "renderer" is just the software renderer + a handful of shadow polygons rendered with S3d. From a low res video on YouTube the CIF version looks suspiciously like the software renderer as well.
Reply 744 of 762, by Babasha
Putas wrote on 2026-01-07, 11:41:
Quake has more miniGL backends to proprietary renderer
Reply 745 of 762, by robertmo3
the correct answer is:
-Tomb Raider 1
-Nascar Racing 1
Reply 746 of 762, by leileilol
Two proprietary coverage games: I76 Gold and Croc.
Interstate '76 Gold / Nitro is the big one I think of out-of-the-box, which is technically similar to Mechwarrior 2 but not split off to multiple OEM editions. That one SKU covers:
- 3dfx Glide
- Direct3D 5
- PowerVR SGL
- Rendition
Croc's another impressively covering one, but not one I think about a lot for leaving out SGL and not bothering with Direct3D:
- 3dfx Glide
- ATI 3DCIF
- MSI
- S3D
Babasha wrote on 2026-01-07, 13:26:
Crime Cities beats that in the MiniGL pissing contest - as techland written their own minigl drivers where vendors faltered! this is already very documented!!! Some of these drivers even can be more compatibility resilient than the official MiniGLs!
- 3dfx Glide (MiniGL)
- Direct3D(MiniGL)
- OpenGL
- MSI (MiniGL)
- PowerVR SGL (MiniGL)
- S3D (MiniGL)
Reply 747 of 762, by Putas
But translating from OpenGL cannot be optimal.
Reply 748 of 762, by robertmo3
Tomb Raider 1:
- 3Dfx Glide
- ATI 3D Rage (ATI CIF)
- S3 Virge (S3D)
- Rendition Verite
- PowerVR (PowerSGL)
- Matrox Mystique (MSI)
Nascar Racing 1:
- Matrox Millennium
- Creative 3D Blaster (CGL)
- Nvidia NV1 NVLib
Reply 749 of 762, by Putas
leileilol wrote on 2026-01-07, 19:25:
Interstate '76 Gold / Nitro is the big one I think of out-of-the-box, which is technically similar to Mechwarrior 2 but not spli […]
- 3dfx Glide
- Direct3D 5
- PowerVR SGL
- Rendition
Just like Die By The Sword
Reply 750 of 762, by robertmo3
- 3dfx Glide
- Direct3D 5
- PowerVR SGL
- Rendition
Just like Sub Culture and Monster Truck Madness 2.
Reply 751 of 762, by robertmo3
Actua Soccer (VR Soccer 96):
- QuickDraw3D RAVE
- 3Dfx Glide
- S3 Virge (S3D) (semi-finals)
Reply 752 of 762, by robertmo3
some more bigger ones:
Battle Arena Toshinden:
- 3Dfx Glide
- Nvidia NV1 NVLib
Whiplash:
- 3Dfx Glide
- S3 Virge (S3D)
- Rendition Verite
Time Warriors:
- 3Dfx Glide
- S3 Virge (S3D)
Turok: Dinosaur Hunter:
- 3dfx Glide
- Direct3D
- PowerVR SGL
- Ati CIF
Reply 753 of 762, by RaVeN-05
Terracide powervr oem supports ati3dcif
Ral from release International Rally Championship EXCLUSIVE GAME!!!!
Nfs3 use fifa99 ragea set thrash driver to rage regeditor.exe
Nfs4 copy NBA ragea as d3da.dll
Fifa 99 uses ati3dcif but unplayable
NHL 99
Nba
GPolice uses ati3dcif immediately ctd
Futurecolalppd uses ati3dcif immediately ctd
@vetz @Gona also please look at Re: 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D) and look above
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 754 of 762, by RaVeN-05
potentially could be as inside game code calls to apis detected:
powervr?
Semper FI "The Tradition Continues" (c) Interactive Magic
Seven Kingdoms Ancient Adversaries Demo
ati 3d rage?
BugRiders: the Race of Kings
Rendition verite ?
nfs3 demo
future cop demo
Men in Black Demo S3 Virge?
Reply 755 of 762, by marxveix
RaVeN-05 wrote on 2026-02-21, 19:49:
ati 3d rage?
Thanks and yes. The ATi Rage Pro mode uses ATi native renderer
Re: ATi RagePro supported games
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 757 of 762, by RaVeN-05
rendition ?
StarSiege
s3 virge?
Armor Command
i-war
queen the eye
powervr?
Ljaguska
Wild Metal Country DEMO
ATI 3D RAGE?
AtiQuake
cubitus
i-war
Queen the eye
S3 Metal
CRIME_CITIES
Apin Metal
Matrox Impression
DOOM95? SCXIEXT.DLL
Multi API
Speedway Championships
Mystique
I-War
Queen the eye
Reply 758 of 762, by marxveix
RaVeN-05 wrote on 2026-04-29, 14:44:
potentially could be as inside game code calls to apis detected: […]
ATI 3D RAGE?
AtiQuake
cubitus
i-war
Queen the eye
Bit strange games, but some ATi/Brender stuff is there.
Play with the Teletubbies (new)
Queen: The eYe
I-War: Defiance
https://blazingrender.net/#games
These are Brender games, like first Croc game. I have some Brender demos that i have tested/played with Rage2 and Rage3.
ATiQuake? you mean ATIQuake OpenGL or its Quake game?
Cubitus? More info about the game if you have something?
Reply 759 of 762, by RaVeN-05
ATIQuake OpenGL (miniGL that works trough ati3dcif api calls)
This is the limited version of cubitus.  To buy the full version, send 10$ to :
Hugues St-Pierre
1628 Ave. Lorient
Charlesbourg, Quebec (Canada)
G1G-3C5
GOAL OF THE GAME : Clear all of the smaller cubes, two by two, that make up the large cube before the time limit expires.
To clear a cube, select two cubes with the same picture.
To get more time, select two cubes with identical time pictures (in seconds) on them.
Also, check the panel at the bottom of the screen to see if you can select
a time cube(At the Easy level, you can always select the time cubes).
In the limited version you have a limited number of cubes to delete before the game stops.
SYSTEM REQUIREMENTS :
Pentium 133 or 100% IBM PC compatible
Windows 95
DirectX (DirectDraw, DirectSound, DirectInput)
16meg Ram
2x CD-ROM
Suggested : 3d Accelerated graphics card with opengl drivers
WARNING :
- If you are in 256 color mode, the game may freeze when started. 16bits or
24bits or 32bits is recommended (16bits gives the best performance as of now)
- With an underpowered PC, the game will work, but the mouse input will be too slow to enjoy the game.
- You don't have to install the game on your hard disk, but if you want to,
you can drag all the CD files onto it (this will speed up the loading time).
- If you select the default opengl driver, the game will use the opengl32.dll in your
\windows\system\"opengl32.dll" directory. If you don't have hardware Opengl acceleration (i.e.: Software only),
the game will be VERY VERY VERY slow.
- The game may seem to occasionally freeze-up, this is due to Window's handling of the swap file. The game
is not broken, but you will loose 1 to 3 seconds of game play.
- If you change the resolution, the game can freeze or loose colors,
or other unwanted side-effects. The 3d card's driver can be the source of this problem.
All of the game's sound, music, pictures, code, and files are Copyright 1998 - Hugues St-Pierre
I am not responsible for any problems, technical or otherwise, that may be caused by this product.
Je ne suis pas responsable des bris ou des problemes pouvant etre causer par ce produit.
SpeedwayChampionship is like crime cities have same techland minigls : 3dfx, d3d, mystique, powervr, s3 virge
