First post, by RetroVein
Hello everyone. This is my first post on Vogons. First of all, I'd like to thank all users, who make this great forum possible, and who are building such a valuable resource of information.
I am a seasoned technical user, and I would like to share a problem that is beyond me at this point: a defective 486 motherboard that I cannot make work.
Motherboard: LS-486E rev C2 (supports EDO). Chipset 85C496 + 85C497
L2 cache: 256 kbytes + tag RAM
The board come with no activity at all. The reset signal was not released by the chipset. After using dielectric contact cleaner on the socket 3, the reset issue disappeared. But the POST fails (no PCI video output), with code 41 0d and continuous short beeps.
When there's a floppy drive attached, the BIOS tries to read from a floppy (I suppose that BIOS checksum fails, and it is trying to find a binary on the floppy to flash itself).
Steps done:
- Cleaning with soft brush, then alcohol, and finally dielectric contact cleaner.
- Removing the socket 3 top cover, and cleaning the CPU contacts directly.
- Reprogram BIOS (AT 27C010A) using external programmer, on new chip.
- Replace CMOS battery with fresh one and reset settings using jumper.
Diagnosis steps:
- Map all SIMM pins to the chipset (SiS496). No trace seems to be open. Address lines go to a pair of 74F244. Data, CAS and RAS go directly to the SiS496.
- Oscilloscope probing on SIMM pins (mainly address lines, all CAS and RAS and some data lines).
- Check diodes and SIP resistors.
- Inspection under microscope.
- IR camera inspection (no suspicious device).
- Tried a single good EDO and FPM, on all SIMM slots.
Now, the weird thing:
After I accidentally shorted an output pin of a 74F244 with an input from the SiS496, and when powering off and on again, ¡the motherboard boots! I could enter BIOS, change settings, try to boot OS, etc.
But then, after power down, all goes to the previous error state, and post code 41 0d, continuous short beeps.
I found a strange signal on address line #2 (A2). When the signal is high, at the output of 74F244, there are what seem castle battlements (see image attached).
The input to the 74F244 (from SiS496 is fine, see image attached).
So I decide to replace that 74F244 with a new one (I only have one DIP20, so I had to use kynar fly-wires). Same behavior.
Now, this is the point I decided to search for help.
I can only think of two more possible partial solutions (one being modify BIOS to use the more relaxing DRAM wait-states possible, and see if that helps).
Any ideas, recommendations, info, etc., is very much welcome.
Could this mobo get to live again? 😀
Thank you very much.
