RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 3361 of 3383, by sharangad
These are the file offsets (from the beginning) for the CGL functions used by 3DBINFO from VRITB170.CGL.
cglQueryScreen 0x10551
cglInitScreen correct offset at 0x10755
cglSelectRenderBuffer 0x12B39
cglClearScreen 0x127A5
cglSwapBuffer 0x12AB1
cglGetConfig 0x10E59
cglQueryFeature 0x15A19
cglClose 0x10E11
The rest will be decoded, rest assured.
(Cross-posted to CGL thread:Re: Fun with CGL (Creative Graphics Library) on 3D Blaster).
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3362 of 3383, by sharangad
Toshinden now fails with a texture load error:
https://youtu.be/2AtO-JLwReQ
End of program message:
Cannot load texture into CGL
Size 64 x 64
Board memory left 0
Free byte address 0
Error code = 1803
Exiting
Build Date: Jul 22 1996 18:26:14
V:\TOSH>tsd
RReady's logs have this:
!!! CGL cglInitScreen
Mode 14, format 1, num buffers 2, options 2, size 0, reference (origin?) 0
CGL Resolution 640x400@70 Hz, format 1, num buffers 2
Buffer size 2048000
CGL redirected Port IO function #0x01
*** CGL input port C803 = value 0000 (bytes: 1)
Registers EAX: 00000000, EBX: 00000000, ECX:0000000E, EDX:0000C803, ESI: 00000001, EDI: 00000002, EBP: 002ED064
!!! CGL cglClearScreen
*** CGL input port C804 = value 0000 (bytes: 1)
Registers EAX: 00000000, EBX: 00000000, ECX:0000000E, EDX:0000C804, ESI: 00000001, EDI: 00000002, EBP: 002ED064
!!! CGL cglSwapBuffers
*** CGL input port C810 = value 00AC (bytes: 1)
Registers EAX: 002ECFAC, EBX: 0000005A, ECX:00000280, EDX:0000C810, ESI: 00000010, EDI: 00000001, EBP: 002ED064
!!! CGL Download
!!! Ptr is 002ECFAC, int param is 00000000
*** CGL input port C804 = value 0001 (bytes: 1)
Registers EAX: 00000001, EBX: 002ED0AC, ECX:00000001, EDX:003EC804, ESI: 002ED040, EDI: 00000001, EBP: 002ED064
*** CGL input port C807 = value 0001 (bytes: 1)
Registers EAX: 00210001, EBX: 00000002, ECX:0000070B, EDX:0000C807, ESI: 00000000, EDI: 00000000, EBP: 00000000
!!! CGL Close
Reply 3363 of 3383, by sharangad
One more Gona:
https://nirvtek.com/downloads/3DBVLB.20260504.001.7z
MD5: 87bd92f770a99a23827abef852ab0bfc
This is broken.
Try this instead:
https://nirvtek.com/downloads/3DBVLB.20260504.002.7z
MD5: 337f0450a27dd69b60df59445e5c1e7b
https://nirvtek.com/downloads/3DBVLB.20260504.003.7z
MD5: e4470c26cb74cca823ba663571d2ee13
(The previous version locked down the resource identifier to the expected value for 3DBVLB. This version will query it even if it's wrong.)
Run it with 1 as a parameter,
3dbvlb 1
Reply 3364 of 3383, by Gona
Here it is.
sharangad wrote on 2026-05-03, 23:21:
One more Gona: https://nirvtek.com/downloads/3DBVLB.20260504.001.7z MD5: 87bd92f770a99a23827abef852ab0bfc […]
One more Gona:
This is broken.
Try this instead:
3dbvlb 1
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 3365 of 3383, by sharangad
Gona wrote on 2026-05-04, 12:57:
Here it is.
One more Gona:
This is broken.
Try this instead:
3dbvlb 1
Woohoo! That looks good. I'll add the results to dosbox in a bit.
Reply 3366 of 3383, by sharangad
and again (the VLB's IO port base appears to be 0x0204):
https://nirvtek.com/downloads/3DBVLB.20260504.004.7z
MD5: af84131b4e1c19ad5e15001a5aed0d65
My logging text is wrong, but it's working correctly. The logical device is 0x00. The 0x76 is a register.
Reply 3371 of 3383, by sharangad
Today's an ICR2 day, but here's one more for you Gona:
https://nirvtek.com/downloads/3DBVLB.20260505.001.7z
MD5: 98813f54511292f06e04a78530cf7da5
Thanks for all the testing BTW!
There is light at the end of the tunnel. Some games like Rebel Moon (1995) still don't detect the card, but Nascar Racing does. It fails to set the mode, instead of complaining about a missing 3D Blaster.
Reply 3374 of 3383, by Gona
I have downloaded this one:
and I have checked it — this is the version I ran.
The attachment png.PNG is no longer available
sharangad wrote on 2026-05-05, 12:11:
Gona wrote on 2026-05-05, 11:38:
Here it is.
Thanks Gona, but that's the wrong file I think.
Reply 3375 of 3383, by sharangad
Gona wrote on 2026-05-05, 19:37:
I have downloaded this one: https://nirvtek.com/downloads/3DBVLB.20260505.001.7z and I have checked it — this is the version I r […]
Here it is.
Ok , I've messed up somewhere. I'll get you another build later today.
Reply 3376 of 3383, by sharangad
Some signs of life with the VLB in Dosbox-R, thanks to Gona's tireless efforts.
The port IO returned a memory address. I'll need a dos4gw test harness to test this on real hardware and I won't be able to do that for a few days.
2026/5/6|23:17:22.64 VLB PNP Port 0279 poked with value 61
2026/5/6|23:17:22.64 **************** VLB <known> IO Read Port 020B, size 1
2026/5/6|23:17:22.64 0x61, returning 0x04
2026/5/6|23:17:22.64 VLB Comms Port write 0204, 07, 1
2026/5/6|23:17:22.64 VLB <unknown> IO Write Port 0204, Val 00000007 (size 1)
2026/5/6|23:17:22.64 VLB Comms Port write 0204, 05, 1
2026/5/6|23:17:22.64 VLB <unknown> IO Write Port 0204, Val 00000005 (size 1)
2026/5/6|23:17:22.64 VLB Comms Port write 0204, 03, 1
2026/5/6|23:17:22.64 VLB <unknown> IO Write Port 0204, Val 00000003 (size 1)
2026/5/6|23:17:22.64 VLB Comms Port write 0204, 01, 1
2026/5/6|23:17:22.64 VLB <unknown> IO Write Port 0204, Val 00000001 (size 1)
2026/5/6|23:17:22.64 VLB PNP Port 0279 poked with value 02
2026/5/6|23:17:22.64 ISA PNP function 02 (Set control config), param 0002
2026/5/6|23:17:22.64 VLB write dword from 86000200 = 00000002
2026/5/6|23:17:22.64 VLB write dword from 86000008 = 87800001
2026/5/6|23:17:22.64 VLB write dword from 8600000C = 00000000
2026/5/6|23:17:22.64 VLB write byte from 87800000 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800001 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800002 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800003 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800004 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800005 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800006 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800007 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800008 = AA
2026/5/6|23:17:22.64 VLB write byte from 87800009 = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000A = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000B = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000C = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000D = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000E = AA
2026/5/6|23:17:22.64 VLB write byte from 8780000F = AA
2026/5/6|23:17:22.64 VLB Read byte from 87800004
2026/5/6|23:17:22.64 VLB write dword from 86000200 = 00000010
2026/5/6|23:17:22.64 VLB write dword from 8600000C = 00100000
2026/5/6|23:17:22.64 VLB write dword from 8600000C = 00900000
2026/5/6|23:17:22.64 VLB write byte from 87800000 = 08
2026/5/6|23:17:22.64 VLB write dword from 8600000C = 00800000
2026/5/6|23:17:22.64 VLB write byte from 87800000 = 07
2026/5/6|23:17:22.64 VLB write dword from 8600000C = 00700000
2026/5/6|23:17:22.65 VLB write byte from 87800000 = 06
2026/5/6|23:17:22.65 VLB write dword from 8600000C = 00600000
2026/5/6|23:17:22.65 VLB write byte from 87800000 = 05
Show last 4 lines
2026/5/6|23:17:22.65 VLB write dword from 8600000C = 00500000
2026/5/6|23:17:22.65 VLB write byte from 87800000 = 04
2026/5/6|23:17:22.65 VLB write dword from 8600000C = 00400000
Reply 3377 of 3383, by sharangad
Got Toshinden/3dbpci running on dosbox-rendition with a black screen and in game sounds working. The console does have a few error messages., but the actual in-game (fighting) seems to be working (blindly) .
There's a bit of a thunderstorm here right now, but I'll post a video on the CGL thread when I get a chance.
The log file shows that the game seems to be calling cglStream to push the polygons out. Most of the functions are being trapped now.
Reply 3378 of 3383, by sharangad
Toshinden running with black screen.
https://youtu.be/LTbC5n-LOZQ
Also available on my Patreon at 1080p:
https://www.patreon.com/posts/battle-arena-cg … ntent=join_link
