First post, by rico001
I think DOSbox glshaders/scalers do not look good /work right. They upscale for some reason... Example from log on World Rally Championship fever... Auto-switched to shader 'crt/vga-1080p'
2026-02-06 20:34:15.338 | SDL: Using standard SDI (auto) display refresh rate of 60 Hz Windows 11 oled tv.
2026-02-06 20:34:15.351 | DISPLAY: VGA 720x400 16-colour text mode 03h at 70.087 Hz throttled VFR, scaled to 1067x800 pixels with 1:1.35 (20:27) pixel aspect ratio
need to go to 640x400(double-scan) and maybe use standard of 640x480 emulated... will try to explain better and post more info...
The glscaler scaler standard may be the issue... On Windows 95/98 with crt monitor it had an option to use double-scan in a compatibilty mode (I think I remember from command and conquer red alert) So am trying to say upscale differently for 320x200 games. EDIT:
Learned about Pixel Aspect Ratio and DisplayPixel Aspect Ratio... PAR of 1:1.22 instead of 1:1 changes demensions of each pixel and is differant process than simply upscaling the on-screen image by an integer.
Reply 1 of 6, by rico001
Found a ton of cool info, ideas failed couldn't get a game working in .82.2 might try regular dosbox, am able to use both monitor and tv -2000+(date) years... Found out 320x200 (might be mode 12h) might be considered 16:10, and might not work on tv's 1280x800... Still learning... hopefully ok to post here, learning alot remembering fun things ...
Reply 2 of 6, by theelf
Cant understand anything
Reply 4 of 6, by rico001
Don't legally know about posting pic/videos for commercial games, but FOSS games software to compare without licensing issues: fractint (fractal generator by stone soup), sopwith2, scumm vm games... One or 2 comercial examples that are dramatically differant with proper scaling and aspect ratio was Lemmings, another was Earthworm Jim 2. Perhaps someone can make a program to match color in game screenshots to your computer monitor or tv. An app that helps to control aspect ratio and control scan line or shader settings is shaderglass(available on github), for Windows or linux and can be used externally to Dosbox. An app that people used to use to change settings such as gamma and brightness was Powerstrip by Entech (2001)... Some of these scaling changes can be viewed in DOSBOX_Staging image gallery..
Reply 5 of 6, by rico001
For trying to get a 320x200 vga - I think 12h mode, to look ok on 4k (3840x2160p) I used 3840 (640x6)X 1200. On lemmings in fullscreen and it added padding and looked less chunky lemming characters...
Reply 6 of 6, by theelf
rico001 wrote on Yesterday, 21:15:
320x200 in a 4k screen will scale fine at 2560×2000, is 1.28 close to 1.33 and integer scaling, for sure any shader will look good
But anyways, for VGA games the shader mus be something emulate doublescan, like if one pixel is 10 in 4k, the shader need to do somehing like this
(i=image b=black)
i
i
i
b
b
i
i
i
b
b
mabe is better a png overlay
