First post, by STN996
I recently started building a retro PC using Gigabyte GA-8SIMLH motherboard and a Pentium 4 processor, Voodoo5 AGP, Voodoo2, and Diamond Monster Sound MX300 sound card (which uses the same chipset as the Aureal Vortex 2). Right now, I have one spare PCI slot left that I would like to use it. Although I haven't started gaming on this machine yet, my goal is to achieve better compatibility with DOS-era titles. Budget isn't really an issue, but I don't want to overspend on overly expensive cards (I know the Voodoo5 isn't worth its current market price, but it is a personal enthusiasm). Later DirectX 9 games will be handled by a separate Windows XP machine (yes, I have another Windows XP retro rig). I would love to get some recommendations since I'm a beginner and finding a lot of joy in building these old systems.
Additionally, I built this system inside an IBM NetVista sleeper-build desktop case. I keep the frame and outer shell and swap the component because I love this classic IBM aesthetic. However, I think the airflow in this horizontal desktop case is not very good. I have installed two 60mm Noctua fans with the airflow direction shown in the image, but I am still worried about the thermals around the graphics and sound cards. Any advice on improving cooling in this setup would be greatly appreciated!
I used translator softwares to help me write this post since English is not my native language. I hope any spelling or grammatical errors won't cause any misunderstanding.
Reply 1 of 12, by RetroPCCupboard
I can't see the images in the image host that you used. Says not viewable in my region (UK). Are you unable to use the forum image upload?
Reply 2 of 12, by STN996
RetroPCCupboard wrote on 2026-05-23, 04:51:
I can see the image just fine. Sorry, I dont know how this should work properly. I actually reupload this post because the images were not shown.
https://imgur.com/Thls25Y
https://imgur.com/gT6pf2P
Reply 3 of 12, by NeoG_
With regards to cooling, you want both local air movement around hotspots and a consistent directional airflow through the case itself. Currently you have 2 60mm fans intaking air and the 92mm power supply exhausting air on the same panel which is sub-optimal.
First, reverse the noctua fans so they are exhaust fans alongside the power supply, that way fresh air will come in through the front panel opening and lead to a consistent removal of heat buildup in the case itself. If the expansion cards are still struggling - for example if you can feel a significant hot spot just above the expansion cards on the case when closed, I would stick a fan at the end of the expansion cards between the floppy cage and the side of the case that blows air down the length of the cards. That will move stagnant air away from the cards into an area that will be exhausted at the rear of the case.
If after that you are still struggling heat wise, you need more air inflow from the front of the case. One trick I do is to dremel out a section of the front panel from the bottom surface, a bit past the roundover so it opens a large gap for air to come in but looking from the front you can't tell it's been modified.
You will find once the airflow works well, you can run the fans significantly quieiter as most of the airflow benefits can be derived from a fairly low RPM with Noctua fans.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 4 of 12, by STN996
NeoG_ wrote on 2026-05-23, 05:25:
With regards to cooling, you want both local air movement around hotspots and a consistent directional airflow through the case […]
Thanks for the advice. As for the modifications, I currently lack the proper tools, and the locations of the two fans are the only mounting spots available on the case. I am indeed a bit worried about the lack of direct airflow over the PCI and AGP slots, but for now, I can't think of a good way to fix it. I will reverse the fans at least and see how it goes.
Reply 6 of 12, by NeoG_
Shponglefan wrote on 2026-05-23, 05:50:
You might be able to jury rig an 80mm fan blowing into the expansion slots. Maybe there is a way to attach it with zip ties to the case.
If I had nothing else I would just find a suitable sized fan (92mm is probably about the right size) and hot glue it to the metal case at the end of the expansion cards
Reply 7 of 12, by STN996
I'm mainly trying to figure out how to utilize that last empty PCI slot for now. As for the fans, I can decide on this once the entire hardware configuration is finalized.
Reply 8 of 12, by jh80
STN996 wrote on 2026-05-23, 06:16:
I'm not sure I would add anything to the last PCI slot. Is there anything you think you're missing? It will always be limited in DOS without ISA slots for sound, although you can probably get far (not sure about DOS drivers for your card).
People are commenting on the airflow situation because it's pretty worrisome. Pentium 4 chips run hot (compared with previous generations). Which exact chip do you have? You really want to find some way to get air near those PCI cards. I would monitor temperatures inside the case closely.
Reply 9 of 12, by STN996
jh80 wrote on 2026-05-23, 06:41:
I am using Northwood 2.4 GHz 533 MT/s. I heard thermal performance of Northwood is actually not that bad but I certainly will tweak overclocking under different scenarios. I don't think I am missing anything actually. I did some research before and found some information that vortex 2 and voodoo 2 have some advantages on compatibility but I know DOS games could be very troublesome.
Reply 10 of 12, by ott
If you already have MX300 card for A3D, I would install Audigy2 to support EAX.
Note:
The main limitation for using all PCI ports is the IRQ assignment in Win9x/DOS. PCI ports may share common IRQ (especially on mATX motherboard), which can lead to conflicts with PCI cards with PCI Bus mastering.
Reply 11 of 12, by STN996
Interestingly, I just found the grille right under the power button that seems to fit an 80mm fan. This location points directly at all the PCI slots, so hoping adding a new fan there should solve my cooling concerns.
Reply 12 of 12, by STN996
ott wrote on 2026-05-23, 07:01:
If you already have MX300 card for A3D, I would install Audigy2 to support EAX. […]
Note:
Sounds like a good idea. I know the IRQ is very messy. When I was installing drivers on a SD card windows98 it keeped crashing because I didn't reserve IRQ for MX300. But it is all good now. It seems the IRQ in the BIOS can be assigned individually for my motherboad so I think it is fine when I install another card in the future.
