Reply 100 of 125, by M-HT
I tried running X-VESA Beta 5 on ZimaBoard (CPU: Intel Celeron N3350 [Apollo Lake], GPU: Intel HD Graphics 500) and the result was:
No VGA adapter detected
Reply 101 of 125, by Marco Pistella
@M-HT
X‑VESA requires a real IBM‑compatible VGA core (sequencer, graphics controller, CRTC, planar modes, latch logic, etc.).
Intel Apollo Lake (HD Graphics 500) no longer includes a legacy VGA hardware block — only a VESA framebuffer interface provided by the firmware.
Because INT 10h function 1A00h does not return a valid VGA Display Combination Code (07h/08h), X‑VESA correctly reports “No VGA adapter detected”.
This is expected behavior on modern Intel SoCs where the VGA subsystem has been removed from the silicon.
Reply 102 of 125, by zyzzle
M-HT wrote on 2026-05-14, 11:16:
That happened on my netbook with Intel N4020 CPU. There are various "fakevga" programs out there. The one I used to supplant this message, and get X-VESA and quickview pro, and others to run is called FAKEVGA.COM a small .com file which fools the system into thinking VGA is in the system by modifying INT 10 function.
Reply 103 of 125, by Marco Pistella
@zyzzle
Thank you for the information about FAKEVGA.COM.
Using FAKEVGA will indeed allow X-VESA to pass the initial VGA detection check, but this is strongly discouraged. X-VESA relies heavily on direct VGA hardware access throughout its execution — sequencer registers, CRTC, graphics controller, planar modes, latch logic — not just at startup. These are not optional code paths but core to almost every function X-VESA performs.
On systems without real VGA hardware, any of these accesses may produce unpredictable results or cause X-VESA to crash at any point during execution. This would not be a bug in X-VESA — it would be the expected consequence of running software that requires real VGA hardware on a system that does not have it.
In short: FAKEVGA + X-VESA on nonVGA/partialVGA or similar platforms = use at your own risk, crashes are expected and will not be investigated as bugs.
Reply 104 of 125, by zyzzle
Marco Pistella wrote on 2026-05-15, 04:12:
@zyzzle Thank you for the information about FAKEVGA.COM. […]
@zyzzle
Of course. This is evident and understood.
I've only had to invoke fakevga.com on one system:
Lenovo 100e 11.5"(64GB eMMC, Intel Celeron N3350) with a SOC.
netbook which reports "VGA card required" on many programs, but supports VESA3.0, has many VESA modes, supports MTRRs writecombining caching for VGA and LFB with the Broxton onboard Intel Graphics. Never noted any other glitches on this one system after executing fakevga. Everything just works as it should from then on, from Quickview Pro 2.61 to X-VESA to older Apogee games. So, something about its vBIOS is crippled in VGA mode INT 10h function 0x1A00h which doesn't affect VESA and seems to be an artificial software, vbios limitation.
Intel seems to have intentionally cripped its post Broadwell onboard graphics BIOSes, the later Apollo / Broxton chipsets are the most denuded of all. For no good reason. Some of these intentional disablements can be fixed in software, like you've so expertly done with Nvidia GeForce cards and NEWAX.
AMD Ryzen did the same thing. Ryzen 1700 and above onboard graphics don't seem to support any VGA at all (even 320x200x8) or 8-bit modes in DOS. 16 and 32-bit VESA modes @ 640x480 and up are enabled. All programs using low VGA resolutions fail on such a vBIOS. Come to think of it, I should try running fakevga on that system. Such systems are basically unuseable in baremetal DOS because of that castration of the onboard vBIOS.
I'd never try running fakevga on a system with only an EGA / CGA card installed, or other such nonsense.
Reply 105 of 125, by Marco Pistella
X-VESA RC1 (Update)
RC1
- minor fix update and optimization
Reply 106 of 125, by ockiller
Hey!
I want first to thank you Marco for such a remarkable tool, the level of engineering and polish put into this is quite mind blowing. I wish I had your skill!
I tested a Quadro FX540 in my main system (Ryzen 5700X3D), which is very close to a Geforce 6600 LE PCIe, I have enabled write combining with Reyer's MTRRLFBE (VGA & LFB). Here are some results. I would say that everything looks normal, I don't know what else would be interesting to you, let me know if you want more tests.
Except that for the dual page video move test I have "VESA retrace status" reported as FAIL, and I indeed see the line flicker. VGA version works as intended. I guess it's related to what you mentioned about the nVidia logic of triggering the refresh signal at the end of the blank period? I have to notice that this card suffers from flickering on some Duke Nukem 3D or Quake graphics modes, which is solved by Falco's MSKVBEF7 for example (must be a positive side effect of this tool as it was not intended to fix anything on a generation this old).
Reply 107 of 125, by Marco Pistella
ockiller wrote on 2026-05-20, 17:06:
Hey!
I want first to thank you Marco f...[CUT]
Thanks a lot for the detailed test and for the kind words — much appreciated!
About the VESA retrace status = FAIL in the dual‑page video move test:
yes, what you’re seeing is completely normal for Nvidia cards of that generation. Their VBE implementation triggers the “retrace” signal at the end of the blanking period, not at the beginning like standard VGA hardware. Because of this timing difference, the VESA 4F07h “set display start during retrace” call cannot reliably synchronize page flips, and the result is exactly what you observed: occasional flicker and a FAIL status.
The VGA version works correctly because it uses the classic 3DAh/3BAh vertical‑retrace bit, which is still generated in the expected way.
If your FX540 shows flicker in VESA page‑flipping tests (and in games like Duke3D or Quake), that’s completely normal for this generation of Nvidia cards. Their VBE BIOS handles the retrace signal in a non‑standard way, so 4F07h “set display start during retrace” cannot reliably synchronize page flips.
If you want to fix this behaviour, you may want to try NEWAX, which was specifically designed to correct Nvidia’s VBE timing issues on GeForce/Quadro cards:
NVIDIA Kepler/Maxwell/Pascal VESA Bios Bug (workaround found) (last pages)
It replaces the broken 4F07h logic with a proper handler and restores stable page‑flipping on many Nvidia cards.
If you test it on your FX540, I’d be very interested in your results.
NEWAX on GitHub: https://github.com/Marco-Pistella/NEWAX
Reply 108 of 125, by eM-!3
Great tool! I don't know how to use it as I'm too stupid to understand it but it's really great. Thanks for sharing.
Reply 109 of 125, by Marco Pistella
eM-!3 wrote on 2026-05-20, 17:57:
Thanks! Glad you like it.
No worries — you don’t need to understand everything to use it. Just have fun experimenting with it at your own pace.
Reply 110 of 125, by eM-!3
Marco Pistella wrote on 2026-05-21, 07:00:
Few years ago in my very first post to the forums I described my problems with Scorched Earth in high resolution. I think that your tool might be helpful to find the real reason behind it. I just need to learn more about huge amounts of information that you give to the user.
Scorched Earth - only low resolution
Reply 111 of 125, by Marco Pistella
X-VESA RC2 (Update)
RC2
- Added Video BIOS dump to disk (S key in F10 screen)
The attachment XVESA200.ZIP is no longer available
Reply 112 of 125, by Marco Pistella
X-VESA RC3 (Update)
RC3
- Added PCI Vendor/Device/Revision code (F10 screen)
Reply 113 of 125, by EduBat
Marco Pistella wrote on 2026-05-23, 10:05:
RC2
Quoting from the PCI specs:
6.3.3.1.3. Image Structure
A PC-compatible image has three lengths associated with it: a runtime length, an
initialization length, and an image length. The image length is the total length of the
image, and it must be greater than or equal to the initialization length.
The initialization length specifies the amount of the image that contains both the
initialization and runtime code. This is the amount of data that POST code will copy into
RAM before executing the initialization routine. Initialization length must be greater
than or equal to runtime length. The initialization data that is copied into RAM must
checksum to 0 (using the standard algorithm).
The runtime length specifies the amount of the image that contains the runtime code.
This is the amount of data the POST code will leave in RAM while the system is
operating. Again, this amount of the image must checksum to 0.
The PCI Data structure must be contained within the runtime portion of the image (if
there is any), otherwise, it must be contained within the initialization portion. Figure 6-9
shows the typical layout of an image in the expansion ROM.
The attachment Screenshot_2026-05-26_19-48-04.png is no longer available
It is may be interesting to note that the Video BIOS extracted by X-Vesa is the runtime one, after initialisation. In this case, some of the initialisation code is not present, but it may be interesting to get it to better understand the card. The specs go into a lot more detail about how it all works.
In my GTX650, the file extracted by X-Vesa has 58368 bytes, while the one I extracted "before initialisation" has 64512.
Before:
The attachment VBIOS.ZIP is no longer available
After:
The attachment FILE0000.ZIP is no longer available
Reply 114 of 125, by Marco Pistella
X-VESA 2.0.0 final release:
GitHub source code: https://github.com/Marco-Pistella/X-VESA
Reply 115 of 125, by Falcosoft
Marco Pistella wrote on 2026-05-28, 18:51:
Thanks for sharing the code! It's really useful.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 116 of 125, by Marco Pistella
Falcosoft wrote on 2026-05-28, 19:06:
Thanks
Reply 117 of 125, by Falcosoft
Marco Pistella wrote on 2026-05-28, 19:12:
Thanks
Github is still indexing the code base so searching does not function properly.
Can you tell what files contain the SSE and AVX benchmark routines?
Website, Youtube
Reply 118 of 125, by Marco Pistella
Falcosoft wrote on 2026-05-28, 19:16:
Thanks
VESA_Speed_Routines.ASM + VESA_COMMAND_02.ASM
Reply 119 of 125, by Falcosoft
Marco Pistella wrote on 2026-05-28, 19:24:
Thanks
Thanks, I found them.
There is 1 thing that I could not find in X-VESA (even in the detailed video mode information page): It's the bits in the ModeAttributes field inside the ModeInfoBlock struct.
Some of these bits, such as 'VGA compatible mode' could be useful for troubleshooting since it seems e.g. Build engine games use it to determine code paths.
Thanks in advance!
Website, Youtube
