@sqpat
Good story with the ROM card approach to avoid BIOS patches.
The issue is clearly chipset/bios/mobo specific.
Looks like HW mod will be needed to resolve the current MEMR MEMW 8bit ROM culprit.
About
Speedstar 64 Adds: MEMR MEMW (16 bit on front side)
Speedstar 64 Removes: SMEMR SMEMW (8 bit on back side)
I never looked at the pins of 5434. Pass a pic for a reference about what you are looking at on the cards.
About LFB - i cannot think of a game/application that uses this mode and can run on 286 class hardware. So, no concern at all in my opinion.
@JonnyAmps
So, you silenced the Amptron VLSI VL82CPCAT-16QC board?
That sucks.
Great info and results for the HT18 chipset. Is it long term stable? I am eager to test this now.
It is very difficult to go past 27.5fps with 0 wait states on 286 class hardware.
Looked up things as well, without actually testing. Here is my prep for it so far:
CR1 bit 7: page mode, 1 = enabled, 0 = disabled
CR2 bit 5: non-page mode, 1 = 0 wait-state, 0 = 1 wait-state
CR2 bits 6 and 7: must be set to 1
CR4 bit 3: fast ISA I/O - you reported CF card issues - at minimum this is the well-known write access issues, or the local storage subsystem not functioning at all
Attached 2 executables.
Both disable page mode, set 0 wait state memory access.
The second one enables fastest ISA I/O.
Didn't test yet as the bench desk is covered with ISA cards - doing a bit of a deep-dive on the ISA graphics subject that i hope to post about at some point soon.
Because of that i have fresh evidence that Cirrus Logic GD-5424, 5426, 5428, 5429, 5430, 5434 are slightly faster than ET4000AX, ET4000/W32, ET4000/W32i for VGA graphics in DOS.
Titles like Wodlenstein3D, Doom, etc. clearly show that.
