First post, by Mageek
Good day,
I have built an AMD k6-iii+ computer which includes an IDE to CF card. I Built it using a 8GB CF card which was properly detected by the BIOS with automatic LBA parameters. Windows 98SE installed great, all good.
Now I want to reinstall from scratch on a 32GB CF card. Once again, the BIOS autodetects it fine, with its LBA parameters. The Win 98SE installer runs fine until it does the surface scan. It asks me if I am sure the LBA parameters are correct... twice. I say yes, it runs the scan but nearing the end it starsts marking bad blocks. Eventually fails and I can't install.
Back to the 8GB card, all works fine, can run disk scan, no issues.
I have tested it from my modern linux machine and the CF card works perfectly there: tested with badblocks and also F3 to check that the advertised size is real (F3 tests for flash fraud https://fight-flash-fraud.readthedocs.io/en/s … able/index.html)
Any ideas?
Thanks!
