Reply 20 of 41, by RetroPCCupboard
asdf53 wrote on 2026-05-26, 18:57:It's still not normal that your 3DMark99 score is lower than your 3DMark00 score. Could it be that you ran it with Vsync enabled?
It seems you were correct! Many thanks! 3DMark 99 score went up from 7329/20272 up to 9885/20403.
3DMark 2000 unchanged though, so that obviously does disable vsync itself.
