Reply 80 of 90, by douglar
LSS10999 wrote on 2026-03-18, 12:10:
A question. I wonder if this will work properly with an IDE-SATA adapter on new motherboards that only have SATA ports.
Interesting question.
I think it should work if you force things to run in PIO mode, since all the PATA-SATA bridges I've seen are willing and able to fall back to support PIO in some way or another.
All the PATA-SATA bridges I've seen also support UDMA modes pretty reliably too. But PICOIDE doesn't do UDMA, it tops out at MWDMA.
My experience is that getting MWDMA to work with IDE-SATA adapters can be very difficult. Depends on your IDE controller, IDE driver, & motherboard firmware. It will likely be easier if you start with a Marvell based PATA SATA bridge. People have had better luck with those.
Might just be cheaper & less time consuming to buy a PCI Pata controller if you feel like you have to use a DMA mode.
Reply 81 of 90, by Jo22
crusher wrote on 2025-11-21, 08:04:
+1 vote for a 5.25" front panel because what it replaces is a CD-ROM drive and I'm lack of 3.5" slots.
I think same. I really appreciate the idea of PicoIDE, but I want to see a full-size chassis in the future! 😁
Also because of extra space for bigger buttons and a larger screen, I'd be nice to users of big hands. 😃👋
In principle, that's also the case for floppy emulators.
But since they started out to replace/substitute 3,5" 1,44 MB floppy drives, their 3,5" form factor made sense.
PS: Sorry, I'm a bit late to the party! Please everyone go on! 😅
Reply 82 of 90, by Yoghoo
Jo22 wrote on 2026-03-18, 20:19:
I asked about that on Discord. But it's not in the planning unfortunately. Seems that injection molding a 5.25" frame is quitte expensive.
For me the reason not to buy one atm as I don't like those 5.25" to 3.5" frames and I would also like to have bigger buttons and a larger screen. 😀
Reply 83 of 90, by douglar
Yoghoo wrote on 2026-03-18, 21:50:
I like the idea too. Might be easier if you didn't have buttons.
Does anyone sell a 140mm x 35mm touch screen ?
Maybe this would work?
http://www.lamptron.com/Products/HardwareMonitor/137.html
The attachment image004 (1).jpg is no longer available
Edit: That screen takes HDMI. PICOIDE as it is takes I2C.
If we stick with I2C, there's this for a 1/2 height: https://www.amazon.com/2-42inch-OLED-Display- … B0DLG6MGMH?th=1
Or this could fit in a full height with some tweaking-- https://www.tindie.com/products/displaymodule … module-ssd1322/
Reply 84 of 90, by crusher
I think same. I really appreciate the idea of PicoIDE, but I want to see a full-size chassis in the future! 😁 Also because of ex […]
Thanks for the info from Discord. What a pity a 5.25" is not on the plan 🙁
Me personally can live with a 3.5" -> 5.25" adapter frame.
Can anyone recommend one in beige color?
They seem hard to find.
Reply 85 of 90, by Yoghoo
crusher wrote on 2026-03-19, 07:10:
Thanks for the info from Discord. What a pity a 5.25" is not on the plan :( Me personally can live with a 3.5" -> 5.25" adapter […]
Polpo did search for them as well and also discovered that they are not easy to get. 3D printing or spray painting a black one (which are available) could be an option. I still got a couple of beige ones but I'm not using them (because of exact color match etc).
Reply 86 of 90, by crusher
Yoghoo wrote on 2026-03-19, 07:35:
Spray painting a black frame is a very good idea!
Reply 87 of 90, by tabm0de
sangokushi wrote on 2026-03-09, 23:08:
tabm0de wrote on 2026-02-24, 11:25:
Only reason why i bought a small desktop chassi with two 3.5" bays for PicoIDE and Gotek ;) https://i.imgur.com/PtKCz6N.png […]
Only reason why i bought a small desktop chassi with two 3.5" bays for PicoIDE and Gotek 😉
Does it have an ISA slot?
Its a case only, adding motherboard with isa riser, so yes.
naa, nothing yet...
Reply 88 of 90, by JuddSandage
I 3d Printed up my own, they look pretty good too.
Reply 89 of 90, by Lostdotfish
In case you missed it on Bluesky or Discord...
The attachment Screenshot 2026-06-03 191655.png is no longer available
Dual device support. 1 PicoIDE 2 IDE devices presented to the system.
This device is going to be super awesome!
Reply 90 of 90, by weedeewee
Lostdotfish wrote on Yesterday, 18:18:
In case you missed it on Bluesky or Discord... […]
Thanks ! I did miss it.
Any benchmark results yet ?
Do not ask Why !
