BitWrangler wrote on 2026-06-02, 04:16:
mkarcher wrote on 2026-06-02, 02:07:
Compared to the Intel 430 series, the SiS 5571 is worse anyway, even with 64 bit memory installed.
The 430FX is pretty dire if you don't have a pipeline burst COAST in it. .. I don't imagine the LX or NX are much cop, not that they are easy to find to check.
430FX certainly performs much better with PLB (regardless of whether it's onboard or on COAST) than with async cache, but it was a huge leap forwards compared to NX, which only supported async cache and also only could handle FP DRAM, no EDO.
It's easy to be negative about i430FX, but it's hard to understate how amazing its performance was back in the day, it pretty much single-handedly moved Pentium from being an overpriced, hot, underperforming white elephant to an affordable, efficient and downright fast option that was finally clearly faster than 486 systems in applications people actually ran (i.e. not just floating-point benchmarks). But it did need paired SIMMs. Its moment in the sun was brief though, as a year later the i430HX and VX eclipsed it and another year later the i430TX was in a completely different league.
SiS chipsets all could run on single SIMMs, including the 5511, which introduced UMA (memory shared between CPU and onboard or later integrated VGA). If you want the single worst performing So5/7 solution clock for clock, get a board with 5511 and 6202 VGA, and add a single SIMM to it. Its already excessively narrow bandwith will then get shared between CPU and VGA.
