Socket A: Aiming for the Stars!!!
Reply 220 of 642, by PcBytes
Tzk wrote on 2026-06-02, 04:59:
CPU-Z freezing at 15% is a known issue. possible workarounds: 1. Use CPU-Z v1.59 or earlier - 1.59 is the last version without […]
1. Use CPU-Z v1.59 or earlier - 1.59 is the last version without that issue
2. reinstall windows - fresh install will load latest cpu-z until at some point it somehow starts freezing again
3. use cpu-z vintage edition - that one validates and doesn't freeze
I usually go with option 2 - i got a slim windows xp install (i call it "bench xp") and made an image of that. as soon as it startes freezing cpu-z i'll just write the image back and start over. usually that happens after a crash/freeze or when i'm booting the system at slightly unstable settings.
The percentage seems to differ across versions but the freeze always happens at CPU, and one thing I noticed - only on Athlon XP. For instance, my other boards go past that - KG7-RAID, ST6, P4B533-E. Version 1.57 (I think the same version supercordo uses) is where I could get past the freeze.
As for the Windows install - it's as stock as MCE2005 gets - outside visual stuff (Zune theme, Kaela Kovalskia wallpaper) it's pretty much stock, save for a Ford Racing 3 game install I usually used to test R3xx/RV350/360 cards for stability.
Reply 221 of 642, by geordiepingu
Using this as a bit of a diary for my tweaking and tuning.
Build thread: Re: Dual Athlon MP Rig Build and Repair | K7D Master in a Chieftec Dragon
1st result
2x Athlon MP Palomino 2000+ @ 1725MHz (138MHz FSB/34MHz PCI)
2x1GB DDR @ 138MHz
Nvidia 7800GS 256MB @ 4x, stock clocks
ASUS Xonar DS
Promise SATA + 128GBSSD
Clearly got some way to go! Next stop is to mod a pair of Bartons to see where I can get to, and possibly change my sound card as a gent in the build thread suggests.
file.php?mode=view&id=243437
geordiepingu wrote on 2026-07-05, 17:19:
All for the benchmarks!
Petrol head and serial PC tweaker
Reply 222 of 642, by geordiepingu
....And a bit more tweaking
Build Thread: Re: Dual Athlon MP Rig Build and Repair | K7D Master in a Chieftec Dragon
2x Palamino 2000 MPs @ 1750MHz, 1.80v
2x1GB DDR 2.5-4-4-8
140MHz FSB
Nvidia 7800GS @ AGP4x, GPU 455Mhz, VRAM 1305MHz
3DMark 2001SE: 10311
file.php?mode=view&id=243479
Reply 223 of 642, by supercordo
geordiepingu wrote on 2026-06-03, 19:41:
....And a bit more tweaking Build Thread: Re: Dual Athlon MP Rig Build and Repair | K7D Master in a Chieftec Dragon 2x Palamino […]
2x1GB DDR 2.5-4-4-8
140MHz FSB
See what you get with Cpumark and SuperPi.
Reply 224 of 642, by geordiepingu
So, for context (and to make myself feel better, even if I realise I've just placed 10th in the 3DMark01SE leaderboard), the 760MPX based K7D is really hard to get anything higher than 140MHz stable out of it. I am considering now whether I want to modify the 2.5v regs so I can manually overvolt the memory, as I cannot do that from the BIOS. I suspect I am running into the electrical signal limits at this point for the standard 2.5v DDR voltages, trying to get the timings and speed faster together. I did add some additional rudimentary cooling to give everything a fighting chance....
file.php?mode=view&id=243512
With that said, I have done a few things, tightened the memory timing, played with the AGP latency timing and the PCI latency timing. And as a bonus, I've ran Cinebench 2003 so at least there's a chance of showing off some of the multithreaded capabilities of the system, can't let all the single thread apps have all the fun!
Now my timings are 2.5-3-3-6, again not groundbreaking but pretty hard to tweak with the 760MPX chipset and 2x CPUs to feed. I would definitely benefit from modding these Barton 2500s and ditching these Palominos, then I'm not having to feed other components so much electricity.
Still,
3DMark2001SE : 10354
CPUMark: 146
SuperPi: 2m 9.359s
Cinebench Single: 217
Cinebench Multi: 402
Link to Cinebench 2003: https://www.guru3d.com/download/cinebench-2003/
file.php?mode=view&id=243509
file.php?mode=view&id=243511
file.php?mode=view&id=243510
file.php?mode=view&id=243513
Reply 225 of 642, by geordiepingu
STOP PRESS: Idiot me didn't realise it was still writing to my NAS. SuperPi Time is 1m 10.125s once I moved it to my SSD. Please pardon the double post, couldn't figure out how to edit the previous.
file.php?mode=view&id=243514
Reply 226 of 642, by supercordo
geordiepingu wrote on 2026-06-04, 09:29:
STOP PRESS: Idiot me didn't realise it was still writing to my NAS. SuperPi Time is 1m 10.125s once I moved it to my SSD. Please […]
Ill update the scores later today. Let's not used this thread as your personal diary.
Reply 227 of 642, by classic_cola
I no longer have the Radeon 9000 Pro I was using with my nForce2 board, leaving me with just the IGP for now.
Since nobody else has submitted a Duron Applebred score, does this mean if I participate I'll be #1 by default? 😁
Reply 228 of 642, by supercordo
classic_cola wrote on 2026-06-04, 22:54:
It does. But aim high with it. Someone will come along and knock you down to #2 really quick. 😉😉😉
Reply 229 of 642, by supercordo
Scores updated! If you guys ever see any typos on the score board let me know.
Reply 230 of 642, by The Sandman
Cinebench 2003 - Singlecore
ah, I see it's intended for multi cpu platforms.sorry
Reply 231 of 642, by supercordo
The Sandman wrote on 2026-06-05, 17:32:
FIne okay!!!!
Reply 232 of 642, by The Sandman
Cinibench 2003
Multi Socket's platforms +1
killing me haha
Reply 233 of 642, by supercordo
The Sandman wrote on 2026-06-06, 14:35:
Cinibench 2003
killing me haha
Gotta give the multi cpu guys a reason to post.
Reply 234 of 642, by The Sandman
without a super cpu and stuff you can do diy at home it's hard. Like 3850 vs 6800GT vs. 7600GT.
I really like it here. People starting to bring all the good stuff for the "Big Show"
Reply 235 of 642, by supercordo
The Sandman wrote on 2026-06-06, 14:51:
And i just got a GAINWARD BLISS 7800GS+!!!!!
Reply 236 of 642, by cyclone3d
supercordo wrote on 2026-06-06, 19:07:
That's the one that is really a 7800GT, correct?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 237 of 642, by supercordo
cyclone3d wrote on 2026-06-06, 21:05:
G71 with 20 or 24 pipelines. 7950 gt is 24 pipelines.
Reply 238 of 642, by PcBytes
As said, I'll have to sit a few rounds out GPU wise until later this month (around 12th onwards). I'll try sourcing a X1950 (assuming it's still there after I get paid) 256MB, although the card looks ridiculous in the actual state (someone literally stuck a whole socket 7 cooler onto the Rialto... )
Meanwhile I got the 7N400 Pro2 - will have to figure which BIOS might suit it for overclocking, as well as source some XP-Ms while I'm at shopping - the only 2500+ desktop I have left, it won't overclock for beans and the multiplier lowering does jack to aid in its OC-ing. I didn't think I'd ever get a chip that genuinely hates anything past 200FSB, and the 2400+ seems to stop around the 2310-2330MHz range.
Reply 239 of 642, by The Sandman
Guys, the focus on CPU Benchmarks plz. If there was a way some would come (show?) up with a 6090XT 😉 driven by an Athlon XP
