First post, by JAKra85
My old IBM XT was sitting in the attic for ~10 years.
This is the No.1 PC in my retro PC collection:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
Today I brought it down, did a clean, disassembled made photos, reassembled.
Changed the videocard to ATi Wonder 1024 - ISA - 512KB (PN 109-00095-10).
One of the fastest videocards possible from ATi (28800-5) for this CPU.
This is a 16b ISA working in 8b ISA mode.
The PC Tools program reports only 256KB RAM on the videocard, not exactly sure why that is.
Has both VGA and EGA outputs.
(Tried IBM 5151 monitor and an LCD at the same time, does not work. 😜 )
The HDD was stuck, did not spin. WD40 on the axis and a 10 minute manual spin solved the issue.
The FDD was also suck. It did spin, but the stepper motor was stuck. WD40 plus some grease on the head rail a bit of back and forth movement solved the issue.
Motherboard:
Videocard:
RAM cards (2x256KB):
Working (again) IBM XT:
Will do a few more pictures tomorrow during daytime.
Also, planing a 8087 FPU upgrade soon.
Retro PC Gallery:
