First post, by UCyborg
Long story short, I'm done with Pale Moon. Not only prompted by instabilities that have been going on for months now, but also censorship in their community, which I consider to be the worse offense. They really aren't any better than the others. Which makes the point of supporting their project from the ethical standpoint null and void. I've been using Pale Moon for years, even being patient with its rather laggy and 100% CPU core spike nature for the sake of some of the other conveniences and it will take some adjustment to get used to another browser, but I'll deal with it.
I'm leaning more towards something Firefox-based as I find Chromium in general chronically inflexible. While I haven't checked Vivaldi in few years now and it was impressive in its own right, AFAIK it still inherits many shortcomings, things like inability to copy profile between machines and more restrictive extension system, eg. uBO is more functional on Firefox, you can move extension buttons around, there's still some tricks you can do with userchrome scripts etc. I guess my needs are rather specific so might be why Vivaldi doesn't move me as much.
I already keep both Chromium and Firefox-based browser as a backup, that is FireDragon on Mozilla side and Thorium on Google side. Might just keep them if nothing better is found for my needs, with FireDragon as the main browser. I'd be interested if anyone knows any Chromium fork that diverges from stock in any meaningful way or at the very least lets you copy profile between machines and not lose data. I only know 3 that can do the latter with added cmd-line parameters / flags, they are Ungoogled Chromium, Thorium and Supermium.
I realize I'll never have all the bells and whistles I can have with Pale Moon, so I'll list the most important things I'm looking for first.
First, it should at least launch on my favorite computer, so no SSE 4.1 or AVX requirement enforcement. SSE3 is fine. If it throws illegal instruction on AMD Phenom II for basic operation, then it's useless. I'm fine with Windows 10, so won't ask for it to run on Windows 7 or even XP (yikes!).
ClearType font rendering, which appears to be mission impossible to find in current browsers and major reason that has kept me on Pale Moon for so long. But, as it is, I guess there's no choice other than trying to emulate it via userscript hacks adjusting CSS properties dealing with contrast. I use non-default settings on Windows with slightly bumped contrast. SeaMonkey is the only other one I'm aware of that still has normal font rendering, but sadly, their engine is way too behind to be practical. It should at very least be able to access all my sites to pay bills and the app at work, so the engine should support dynamic module imports, newer class syntax so things like class a {b;#c} don't throw errors etc., otherwise, this one would be easy to switch to.
Sane session save on quit / restore on launch with NOT loading everything, just the selected tab. Chromium is just pathetic at this, extensions can only rely on unreliable hacks to stop tabs from loading and that doesn't work at random. I recently tried one of the tab session management extensions rather than relying on native session restore + Lazy Tabs and it was worse, tabs didn't have navigation history preserved. Seriously?
Something more than barebones tab management. If nothing else, context menu with an option to unload tabs on demand and some visual indicator which tabs are active or not. Seems Firefox is much better in this regard with Tab Mix Plus.
Also, tabs below URL bar. There was one good project that tackled many visual aspects, CustomCSSforFx, but it's a lot of work to maintain and the author stepped down. FireDragon browser has some of these out of box, so as long as it is maintained, things will be better out-of-box without manual messing with CSS.
Integration with KeePass that preferably also supports entering TOTP codes. This one is easy at least, KeePassXC-Browser works OK on both Chromium and Firefox. Meant for KeePassXC specifically rather than the original KeePass, but KeePassNatMsg plugin on KeePass side fills the gap.
Preserving modification timestamp of downloaded files. No browser really does this AFAIK, but until recent releases, it was easy with Firefox with "legacy" DownThemAll! extension. But this one probably needs a rewrite to work on current Firefox... It seems there's an extension for both Firefox and Chromium to send downloads to JDownloader2, but this one is an overkill, especially since it needs not so light process constantly running in the background for seamless experience. Download with Wget for Firefox might be an acceptable compromise.
These would be the most important. Now, some nice to haves.
Colorful tabs - there isn't anything like the old ColorfulTabs extension, is it? You can have tabs randomly colored, colored by domain, manual...
Navigation sounds to have audible cue when using backward / forward functions. There's a nice legacy extension for it, reads settings from Windows registry and plays the sound you've set there. I tried one or two "modern" extensions, they had sound hardcoded (suppose could rip it open and replace it, but it's ugly) and the one on Firefox launched WebAudio context running in the background, which tends to force high resolution timers, which tipped me off a bit.
NPAPI - I don't buy the whole insecure deprecated BS. I'll take proper PDF reader in a browser tab over PDF.js any day. And you get to run Flash too, forget the fake, slow and incomplete Ruffle. Or Java. There's probably more, but yeah, the powers that be decided to kill it. Apparently NPAPI is alive in China and 360 Extreme Explorer supports it. But it's another Chromium...
Flag display indicating the country where the server is from. Seems only Firefox has saner extension for it that doesn't query online service for it all the time.
Well, that's all that comes to mind right now. Any thoughts?
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1 of 13, by The Serpent Rider
LibreWolf, just a privacy focused Firefox without additional bloat. If you want something similar to Vivaldi but on Firefox engine - Floorp.
uBO is just dead on Chromium, except Brave. They maintain compatibility for 3 major extentions: uBO, NoScript and Adblock.
Vivaldi can be completely portable, it's an option in the installer.
Reply 2 of 13, by ElectroSoldier
They're all pretty much the same, it just depends on what bugs you are willing to live with.
You would be better off asking google for a list of the top 10 common web browsers and try and use each one until you find one that works for you rather than ask what they like.
All you will get is a list of little known browsers that have little in the way of support of any kind from people who want to show there hip.
Reply 3 of 13, by Robbbert
Windows 10? I'm using currentFirefox, probably because I'm used to it. Just turn off the AI stuff.
Latest Edge and Chrome are also installed on this 15-year-old machine (HP 6000), but I barely use them.
Reply 4 of 13, by UCyborg
The Serpent Rider wrote on 2026-06-06, 06:06:
I know about Floorp, but unless something changed recently, it needs SSE 4.1 at least. I came across FireDragon, which is based on Floorp and launches on my Phenom II. For some reason, turning off smooth scrolling doesn't do anything, haven't checked if this is inherited from Firefox... By default, default config is a bit too much LibreWolfied for my liking out-of-box, but fortunately, can be tweaked. It even forces intl.accept_languages on to en-US... I mean, c'mon...
Are you referring to this? They explicitly mention encryption which causes extensions to not survive migration, cookies too last time I checked.
ElectroSoldier wrote on 2026-06-06, 06:25:
That's my general impression as well. Honestly, I'm not even sure anything will come out of this. Even though I'm really tired from sluggishness of Pale Moon (and additional issues that cropped up with time), any time I tried to switch, I figured it was better for me to just suffer with Pale Moon.
Yeah, it seems hardly anyone relates to what I want in a browser. And I didn't even mention the theme that inherits operating system's underlying theme! I have Aero like theme on my Win10 + DWMBlurGlass and GlassMyFox extension in Pale Moon. So menus, dialogs and controls in the browser get appearance as if I was still on Windows Vista / 7. Plus the transparency that extends from title bar to the toolbars and status bar.
Modern browsers are so lame and soulless.
Reply 5 of 13, by DaveDDS
I still use Chrome on this Win7 machine - it does say it will not get updates - but so far it's continued to work fine!
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 6 of 13, by UCyborg
Chromium tends to take longer before compatibility issues arise. Might have something to do with them pushing draft standards into use at early stage.
People getting upset quickly on the internet seems to be common. When I wrote this post here, I thought my recent post on PM forum was deleted, but it was merely moved. Still, easy to trip someone over there, saw from my own posting a while back and from other people too.
Reply 7 of 13, by UCyborg
In any case, there doesn't seem to be any choice if you don't want to have to bother with switching browsers as much other than use one of the big ones.
I figured FireDragon's firedragon.cfg is responsible for enforced smooth scrolling. I commented out a whole bunch of other things there, just prefer closer to stock settings.
Why is preserving timestamp of downloaded files such a challenge? Download with Wget is buggy, doesn't seem to initialize properly, have to disable / re-enable integration with its button before it starts working. And even then, the way it works is ugly, it interrupts built-in download manager in a way that leaves .part file behind. And when I tried to download something when logged into NextCloud instance, wget complained that authentication failed. An odd case where probably timestamp preservation wouldn't work, at least the one I was in seems to not send the real one, but, it still breaks seamless integration.
I've been using FireDragon more at home, but, I don't know. There just aren't any normal web browsers left.
Reply 8 of 13, by DaveDDS
My "solution" to the whole auto-update, change how things you're used to work every few weeks - I got a Chromebook (and yes,I know it constantly updates - but it in one system I don't use for anything else.
I haven't yet had to switch to it "always" - but I know it's coming... and it can talk to my desktop for file access, and can read/write a USB stick - so I will still be able to UL/DL stuff as I need.
They are super cheap too!
Reply 9 of 13, by UCyborg
The thing with modern web is, you need a browser with an engine that can stomach all the JavaScript and CSS sites throw at it. And unless you only do phpBB forums, Pale Moon is too damn slow at best and some sites break at worst.
Reply 10 of 13, by VileR
I'm not quite done with Pale Moon yet, but I'm probably getting there as well so I understand the frustration. Part of why I'm obstinately sticking with PM is that I feel it's exactly the kind of project that's worth supporting. Most alternatives aren't even trying to make better browsers, because they're too busy coming up with new ways of being even more like over-the-top cartoon supervillains (short of eating actual babies, I guess).
But yes, its current status is not promising. PaleFill used to be a big help at one point, but it doesn't seem very actively maintained anymore. Browsing the PM forums now (your thread included), people seem to be recommending an ever growing range of yet more extensions and hacks just to keep up with web compatibility for a few more weeks. I completely get the devs' stance there, and recognize that such a tiny team can't simply wave a magic wand and make up for web developers being lazy. But when it becomes a full-time job to just keep my browser from barfing at ~30% of the sites I visit, my good will can only take me so far. I'm too old for this shit.
As for alternatives, I guess Brave seems the "least worst" so far (and that's not saying much). But I'm yet to try Vivaldi.
Have you (or has anyone) looked into Ladybird? That too seems promising in some ways... but I doubt it's going to aim very hard at targets that aren't the modern 'average user', i.e. put the same emphasis on customizability and flexibility that Pale Moon has inherited. So far, can't really tell though.
Can you elaborate a bit on the ClearType issue? I've noticed annoying font rendering hiccups in Blink-based browsers, but they didn't seem to be down to ClearType support- I still get subpixel anti-aliased rendering which seems to respect customized settings, but maybe I just don't follow what exactly you're pointing at. Blink *can* utterly fail at ClearType in specific situations (overzealous rendering optimizations spawning new layers with new rendering contexts, which for some reason disables sub-pixel rendering completely), but I haven't encountered it that often in practice.
Reply 11 of 13, by the3dfxdude
Ungoogled chromium still has manifest v2, and so ublock origin is still going on that. I can't say I care for any chrome browser still. But at least it works and is compatible. Brave would also work, but I find that one a bit weird.
I have not heard that LibreWolf has accomplished anything useful other than what you could have done by customizing firefox yourself.
I think ladybird proves that a web browser can be written from scratch by a small team. But it's not clear that they get it, especially in terms of being lightweight if they start adopting things like rust and vibe coding, they are then pretty much like the other two engines.
Reply 12 of 13, by eM-!3
I'm only using browsers which allow me to have all their data inside a directory that I can copy and use between computers. Firefox is the one that is known to work without problems but you ask for Chromium based browsers:
- Brave - for me it's a top pick with real uBlock Origin still working but it's harder so set it up. Brave have a lot of bloat with some cryptocurrency wallets, AI assistant and their own inferior adblocker. It will take time to disable all the crap they are throwing at us but at the same time maybe you will find their adblocker is enough for your use case. For me it wasn't.
- Chromium port by Hibbiki from https://chromium.woolyss.com/ - this is virtually just like Chrome.
Both are reliable and they don't lag with updates like other projects. These two I'm certain because I use(d) them.
I'm almost sure that Ungoogled Chrome is another one as they were the ones who made patches needed to make it portable.
Now you need to know it's not as easy as downloading these browsers. You need to run them with options which turn off all Google crap which ties your profile to the machine and user. I have my own batch file for it and I have to use it every single time I run Chromium based browser. You can find some options needed on this page: https://portapps.io/app/brave-portable/
Keep in ming that one thing is to run a browser by double clicking an icon on your desktop, but you might need a special way to run it when you click a link in other application. You need to make sure it will use these additional portable option then.
I did try Thorium but I don't trust their portability. It was supposed to work but it ruined my profile after update so I abandoned it. I think there are also some projects on Github which can make Vivaldi and regular Chrome portable but I never tested them, and even if their way works today it can stop working tomorrow and you can end up with a broken profile after browser update.
Reply 13 of 13, by UCyborg
VileR wrote on Yesterday, 22:28:
I agree. I'm still divided. FireDragon (Firefox) works, but it's a hog. I miss DownThemAll! and native theme, but on the other hand, I get updated uBO and nice SponsorBlock extension for YouTube. Oh and SteamDB too! Not that I browser Steam Store much, hardly still play any games TBH, but I find that extension a nice touch. Non-broken Reddit Enhancement Suite too, with the old one, loading next page doesn't work on all subreddits.
I tried to improve old uBO a while back, but I'm not really good at programming and having a second unpaid job after already being exhausted from the first one...that and I lose interest in just about anything I try.
There was a time when it seemed adding Web Components would have solved everything.
But fast-forward to 2026 and ES2026 is a thing. And UXP doesn't understand any of these novelties. Probably will take while for them to be in widespread use, but still.
I like saying that for myself, though I'm (probably) not that old yet.
Just heard of it, but haven't tried. Might be a bit of culture shock since it's a new thing. And then there's the question about extensions.
Fonts tend to come out very thin, what's supposed to be black is more grey, which can be painful. I currently use this script for Firefox / Chromium:
// ==UserScript==
// @name Font Enhancer
// @namespace https://github.com/UCyborg
// @description Improves font contrast. Sourced from Chrome Super Font Enhancer.
// @version 1.1
// @author UCyborg
// @match *://*/*
// @grant none
// ==/UserScript==
'use strict';
const Thickness_Value = 0;
var isRunning;
function applyFilter() {
var excludedTypes = ['range', 'color', 'checkbox', 'radio', 'image', 'hidden'];
var AllElem = document.querySelectorAll(':not(script):not(style):not(area):not(base):not(br):not(col):not(embed):not(hr):not(img):not(keygen):not(link):not(meta):not(param):not(source):not(track):not(wbr):not(table):not(tbody):not(tr):not(ul)');
for (var i = 0; i < AllElem.length; i++) {
if (AllElem[i].nodeType == 1 && AllElem[i].nodeName == 'INPUT') { // apply shadow on INPUT elements
if (!excludedTypes.includes(AllElem[i].type)) {
applyShadow(AllElem[i]);
else {
for (var j = 0; j < AllElem[i].childNodes.length; j++) { // cycle through element nodes
if (AllElem[i].childNodes[j].nodeType == 3 && AllElem[i].childNodes[j].textContent.trim().length) { // is it a text node?
break;
function applyShadow(el) {
if (window.getComputedStyle(el).getPropertyValue('text-shadow') == 'none') { // do not run if text-shadow is already present
var Col = window.getComputedStyle(el).getPropertyValue('color').replace(/[^\d,.]/g, '').split(','); // text color array (R/G/B/A)
if (typeof (Col[3]) == 'undefined' || Col[3].split('.')[0] == 1) { // run if element does not have an alpha channel already applied
var Lum = Math.round(0.2126 * Col[0] + 0.7152 * Col[1] + 0.0722 * Col[2]); // luminosity
//var Opa = Math.pow((255 - Lum) / 255, 1.4) * 0.6;
var Opa = Math.pow((255 - Lum) / 255, 1.4) * 0.55; // smoother, less aggressive opacity
if (Lum < 100) {
Opa *= 0.85;
var weight = parseInt(window.getComputedStyle(el).fontWeight);
if (weight >= 600) {
Opa *= 0.5;
Opa = Math.min(Opa, 0.6); // clamp
el.style.setProperty(
'text-shadow',
`0 0 0px rgba(${Col[0]},${Col[1]},${Col[2]},${Opa})`, // set text shadow with alpha
'important'
if (Thickness_Value > 0) {
var Real_Thickness_Value = Thickness_Value / 10;
el.style.setProperty('-webkit-text-stroke', Real_Thickness_Value + 'px', 'important'); // set text stroke if > 0
Show last 28 lines
function waitAndApplyFilter() {
if (typeof (isRunning) != 'undefined') {
clearTimeout(isRunning);
isRunning = setTimeout(applyFilter, 100);
const callback = (mutationList, observer) => { // called every time BODY has changed
for (var mutation of mutationList) {
if (mutation.type == 'childList') {
waitAndApplyFilter();
applyFilter();
// Options for the observer (which mutations to observe)
const config = { attributes: false, childList: true, subtree: true };
// Create an observer instance linked to the callback function
const observer = new MutationObserver(callback);
// Start observing the target node for configured mutations
observer.observe(document.body, config);
eM-!3 wrote on Today, 10:37:
Same. Chromium goes out of the way to make profiles non-portable. I noticed when poking about in recent Thorium's profile files, even though the profile was made portable, cookie values in one of the databases were still not readable for us humans. Modern security practices. 🙃
If these options were added to chrome://flags page (normally, the portability ones should be there), you can enable them there for subsequent launches for persistence.
For other command line options, besides making sure your shortcuts use them, Chromiums tend to have dedicated entry in registry, through which other applications' requests to open a web browser should go through, eg. for Edge:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\MSEdgeHTM\shell\open\command
In Default value, you can put your arguments before "--single-argument %1". There's also MSEdgePDF and MSEdgeMHT.
I don't remember how these updates go, shortcuts could as well be overwritten. In any case, better to backup the profile before upgrading. And watch out for Chromiums that install scheduled task for auto-updating. Software updates keep coming with surprises, so I rather shun auto-update all together.
